Results 1 to 25 of 25
    May 18 2007
    golden, co
    The need for tunes to "adapt"...explain please
    I just had a GIAC tune put on my 2012 6-speed. When I picked it up, the installer said it would take a couple of drive cycles for the tune to fully adapt. I have also read similar accounts on the web.
    What exactly does that mean? If the tune has to adapt, doesn't that imply that every time your driving style changes, you're in for another "adapt" period?
    Just doesn't make sense to me.
    2012 S4 | Glacier White/Titanium Pkg | Magma/Black/Atlas Carbon | 6-speed | OEM Rotors
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    smh.
    It will take your ecu ~ 3 full warm - cold cycles to fully adapt to the new software. No its not every time your "driving habit" changes. It only means the initial adaptation from stock to tuned.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Established Member Two Rings paulo6's Avatar
    Apr 17 2014
    Ford Explorer, Honda Element. retired a Cobb Tuned E60 535xi for the S4
    Ann Arbor, MI
    I never understood this concept that the ecu (even base one with no tune) adapts to driving style...if car is not pushed hard normally then it will feel more sluggish than a car that is normally driven more aggressively, everything equal. So ya I'm curious ....
    Paul. S4 Prem+, Grey, Optic Black, Sport Diff, Nav+, BO
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    biggest thing is fuel trims have to adapt to that engine and environment. Thats what he means adapt.
    Veteran Member Four Rings steve0827's Avatar
    Mar 07 2011
    981 GT4, 997.2 C2S
    Southport,CT
    Hasn't this topic been answered multiple times?
    2012 Audi S4 (Gone)- Part-out Thread
    2016 Cayman GT4
    2010 911 Carrera S Convertible
    Veteran Member Three Rings EasternLI's Avatar
    Nov 21 2004
    2015 Jeep Grand Cherokee Overland High Altitude
    Sag Harbor, New York
    Quote Originally Posted by steve0827 View Post
    Almost every thread on this board has multiple previous threads about the same thing, seems nobody likes to search anymore so were jammed up with "what's the best tune" and "how is the ride on OE sport springs" all day
    2013 S4 l Monsoon l Black Nappa l Sports Diff l MMI Nav l B&O l Advanced Key l Carbon inlays l GIAC Stage 1 & DSG tune
    AKA: Ticketproof
    May 18 2007
    golden, co
    Sorry, I searched but got tired of wading thru the myriad of tune-related posts that don't answer this question.
    And I still don't get it. By definition, modern engine control systems are continually adapting to a laundry list of inputs (temperature, elevation, octane, etc). There shouldn't be a need for an additional adaptive period, they should work fine as right out of the gate.
    No big deal I suppose, it just doesn't compute for me.
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    there is no readaptation period when i went to stock to stage 1
    i felt it immediately
    going stage 1 to stage two i NOTICED the difference vastly
    i call shenanigans on the adaptation crap GIAC stage 2 file btw,
    2018 TTRS
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by EasternLI View Post
    Well said Eastern LI....you would think if one was buying a tune they would research and understand the adaption/tuning process if they are going to make such an $$$investment. It's funny that CP didn't said if the car is faster after the tune, or fun to drive or anything like that. Always something......
    2011 Deep Sea Blue S4
    7-speed DSG / B&O / MMI with Nav / Advanced Key / Carbon Atlas Inlays / Black Leather /19" Peelers/Push Button Start/Sport-Diff/Comfort Mode;)
    Modifications: Stage 2 GIAC w/Emmanuel Design Pulley, TCU DSG GIAC Tune, EuroCode Alu Kreuz, Roc Euro Intake, 034 Trans mount, Apikol mount, H&R front & rear sways
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    It goes something like this. Modern ECUs have multiple maps which they work with to get you what you finally get in terms of drivability/power of an engine. At the very basic level there are two maps, a base map and a correction value map. These maps exist for all variables that an engine has (fuel/timing/boost) at the very least. Once the ECU power is cut, the values the ECU has stored when taking the base map, applied the correction values map and gotten the final values the engine seems to like, this information is erased. It gets rebuilt as you drive the car and can take a few miles to get back to proper values as you'll have to hit multiple load points on each of these maps to get it all perfect. There are literally hundreds if not thousands of possible combinations once you hit all these load points.
    With that part understood, the next variable is what the tuner does in terms of modifying the tune to get additional gains. Are they modifying the base maps or the correction value maps or possibly both? If the tuner modifies the base maps, then the difference in output should be felt immediately with only a minor improvement over the adaptation period. If the tuner modifies the correction values map, then there will be no felt difference initially and only after adaptation will you feel an improvement.
    This is how I have seen ECUs from other platforms work in the past and I'm sure that while a bit more complex, the current Audi ones work the same way at the core concept.
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by paulo6 View Post
    yes precisely.
    it does not take much to 'wake' up the motor tho, 1-2 WOT should do it.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    May 18 2007
    golden, co
    Thank you Swank. Finally, a legitimate answer to an honest question.
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Quote Originally Posted by SwankPeRFection View Post
    Great post swank.
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Senior Member Three Rings Sukks2bu's Avatar
    Mar 12 2013
    Milton Ontario
    Great response, to add to this, the master mechanic at my dealership explained to me, that if you have Drive Select, comfort and dynamic mode have pre determined maps, while auto is constantly adjusting to the way you drive.
    2010 AUDI S4 DSG DRIVE SELECT UNITRONIC STAGE 2+
    Sep 21 2011
    North Carolina
    Hopefully your '12 doesn't start falling apart post-tune like mine did. Audi's 0 tolerance for aftermarket products is bullshit.
    Ordered August 1, 2014: Mineral Grey F80 M3 / Full Sakhir Leather Interior / 19" Light Alloy Wheels / M Adaptive Suspension / DCT / Carbon Fiber Trim / Carbon Fiber Roof / Executive Package / HK / LED Lighting / PCD Scheduled for October 22, 2014
    Current: 2012 S4 | Phantom Black | Black Interior with Nappa Leather Seats | DSG | Audi Rear Sports Differential with Audi Drive Select | 19" Peelers | Carbon Fiber Inlays | Supercharged Badges | APR Stage 1 | AWE Exhaust + Resonated Downpipes
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by jmacb8s4 View Post
    Could you go into detail about how your car started to fall apart post-tune?
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    Q7, Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    My dealer installed just about everything in my sig. 2012 CPO FTW
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by GeoJoe View Post
    So your AK, Intake, exhaust, etc started falling apart? I dont get it? Post tune made "everything in your sig" fall apart?
    2012 Audi S4 Prestige 6MT with Sports Diff and ADS in Monsoon Grey| 35% tint | Black grill swap | Ti package OEM 19" 5 arm rotor wheels | Alu Kruez | Flat bottom steering wheel | AWE intake | AWE Exhaust | Eurodcode Short Shifter | Eurocode Sways and End Links | StopTech BBK | TSW Nurbrugring wheels in 19"x 8.5 with Toyo R888s in 265/35/19 for track days | P3 Vent Gauge | and still holding on to that CPO warranty to 100k
    Jun 08 2012
    ATL GA
    Quote Originally Posted by z_curtis_s4 View Post
    Uh no... You're looking for jmac. My shit is tight.
    Nov 10 2013
    annapolis, md
    ok cool...I'm officially confused. good luck with your car, tune, etc.
    Sep 21 2011
    North Carolina
    I have documented this elsewhere throughout this forum. Not long after exhaust install and APR Stage 1 flash, I received a "Gearbox Malfunction" warning. Audi faulted the tune and tried to pin me with a $5k bill; we ended up splitting it. After 3k miles, flashed ECU and went Stage 2 with pulley upgrade. In less than 3 months after going Stage 2, one of my catalytic converters began to disintegrate, also not a cheap fix. Audi said they wouldn't be able to cover under warranty, even made a comment that the aftermarket exhaust would've voided my warrant in this scenario, not to mention the tune. Went straight to BMW and ordered a M3.
    Aug 05 2013
    N/A
    No offense, but your gearbox malfunction was most likely a defective drive select sensor in the DSG. There's a documented TSB for that. You should have pushed. The other stuff, could have been a tune issue on the CAT. There's no documented failures of them with or without a tune. Certainly no "known" factory defects that Audi is aware of. Your first issue should have been handled under warranty.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I don't think he was insinuating that his car started falling asleep BECAUSE of the tune. I think he was more just saying that he had bad luck immediately after he had effectively made the decision to forego his warranty.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Sep 21 2011
    North Carolina
    I am aware of the TSB and pushed for over a month on the gearbox issue. I'll never buy another Audi.
    Mar 04 2012
    And that seems totally reasonable given your experience.
