Results 1 to 25 of 25
    Nov 08 2010
    MD
    Does the S6 have a Soundaktor?
    I read a post that said it "definitely" does. It does not sound like it to me though I've only driven one car with it (SQ5) and it was much more of an off/on-switched sort of way that it cut in on acceleration. Plus I do not see a fuse listed that looks like one. Anybody know ... or care?
    2021 SQ8 Prestige - Daytona Gray Pearl
    2018 Q7 Prestige - Samurai Grey
    Past: '19 Cayenne S | '15 S8 | '17 Q7 | '17 Macan S | '14 S6 4.0T | '14 Q5 3.0T | '13 RS5 Coupe | '13 Q5 3.2 | '11 S5 Coupe | '10 Q5 3.2 | '05 allroad 2.7t | '02 A4 3.0 | '00 A6 4.2 | '99 A6 avant 3.0
    Jul 17 2014
    South Lyon, MI
    Its mentioned as "Engine Acoustics" if I remember correct. Check the fuse box C bay and fuse 5. It'll be listed in the owners manual DIY section. I removed the fuse and been using the car for about a week. I couldn't find any considerable change in the exhaust note. In dynamic it feels a bit more prominent but again I think its just my feeling. The difference is more pronounced in my B8.5 S4. You here more engine sound along with the exhaust. I prefer to have the fuse on for the S4 as the burps and farts are more louder with that..
    Active Member Two Rings RettlerT's Avatar
    Sep 21 2012
    Oregon
    Yes it does. This is from the engine manual:
    Sound Actuator System
    The sound actuator system consists of the Structure
    Borne Sound Control Module J869 and Structure
    Borne Sound Actuator R214. Various sound fi les are
    stored on J869 that are played as a function of vehicle
    and operating data (load, engine speed, vehicle
    speed) and forwarded to the actuator.
    The actuator generates the structure-borne sound.
    The sound is then introduced via the body and the
    windshield to the vehicle interior. The actuator is
    installed using a special bracket on the left at the base
    of the windshield. The bracket is the “tuning fork” of
    the system.
    Different vehicles and engines require different
    excitation for a balanced engine sound. Information
    about the engine installed and the body are
    communicated on the CAN bus and are evaluated.
    J869 recognizes independently in which vehicle it
    is installed. The driver can select different sound
    settings through the MMI.
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    There are definitely exhaust valves that open when you put it in dynamic or put the "engine sound" setting in dynamic.
    Citation: I had an AWE exhaust installed and the exhaust came with fake plugs for the wires by the mufflers for the exhaust valves. Since the AWE exhaust came with fake ones I have a soft code perma thrown that I can see via VAG-COM.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Nov 08 2010
    MD
    Thanks! I'll look for the fuse again. I'm just interested in what the car sounds like with and without if possible.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    If it has one it is no where near as pronounced as in the SQ5. I also read what RettlerT posted from the self study guide, but if it is there it is very subdued...
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Nov 08 2010
    MD
    Hrmm, I have to say I'm not convinced yet. Nothing in the fuse listing in my manual even remotely like "Engine Acoustics" or “Sound actuator/exhaust sound tuning” as I've read in another post on the S4. The fuse at C5 is "left rear door control module."
    Nov 08 2010
    MD
    Ack, wait ... fuse 4. I did not read the whole line as it start with AdBlue control module, but at the end actually says Engine Acoustics ... I'll be ...
    Senior Member Two Rings TunTap's Avatar
    Oct 17 2013
    LA
    You can adjust the soundaktor volume / turn it off with VCDS.
    '05 S4 Avant
    Gone: '13 S6 | '14 SQ5 | '13 S5 | '11 Q5 | '06 A3
    Nov 08 2010
    MD
    Thanks! Should have known. Any hint where to look?
    Quote Originally Posted by TunTap View Post
    Veteran Member Three Rings dennisg's Avatar
    May 11 2013
    United States
    Quote Originally Posted by Xtek View Post
    Miltek sells plugs with a resistor in them that eliminate the code. You have to clear it of course once you put the new plugs in. They are a little over 100 bucks as I recall.
    HRE ADDICT
    2013 S6 Phantom Black Pearl, self inflicted Black Optics, 20" HRE P101, brushed dark clear, CF Caps, Tikor lugs, H&R ETS, AWE Touring Exhaust... Eurocode sway bars. Disc Italia ceramic pads. Bel Stir Plus w/ radar mirror display, AL Priority quad "parking sensors" ;-). Hertz Mille speakers, 3 way front/2way rear, Audison Bit DMI, Audison Bit One, Audison Voce 5.1 amp, Audison Voce Quatto amp, Hertz ML2000 sub.
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    This is from the 4.0TT study guide. Also the parts show up in the S6 ETKA.
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Oct 17 2013
    LA
    Quote Originally Posted by KT88 View Post
    It's called something like "structure borne sound". I forget what the module number is. Once you get in - go to adaptation, and there is only one option there which is the volume.
    '05 S4 Avant
    Nov 08 2010
    MD
    Ok, thanks again. I'll take a look around. Probably find I prefer the sound with it on ... sheesh.
    Oct 17 2013
    LA
    I disabled mine right away on all 3 cars that I've had with it. The idea of fake engine sound is just pure depressing to me
    '05 S4 Avant
    Nov 08 2010
    MD
    Agreed, it IS depressing. I left all that beastly-sound and naturally-aspirated goodness behind. I'd be lying if I said I didn't miss it.
    So, volume now set to 0% and I'll wait until tomorrow to see how it sounds ... or not.
    For those so inclined:
    VCDS Beta 14.7.2 > Installed 2 tab > A9 Structurally Borne Sound > > Adaptation > Default volume = 100% > set new value for % to desired value
    Sep 22 2013
    2016 mercedes c300, 2016 audi q5 3.0,2016
    owings mills/MD
    Do you need to use VCDS to disable it or can you just pull a fuse like I did on my S4?
    Nov 08 2010
    MD
    I don't know. I'd use VCDS over pulling a fuse, but realize not everyone has that option. I just avoid pulling panels off the side of my dash if at all possible due to risk of creating buzzes/rattles.
    Quote Originally Posted by rottley View Post
    Nov 08 2010
    MD
    Much better without the fake burble, even though I'd much prefer some real burble to silence ... just my opinion. YMMV.
    Established Member Two Rings bardo's Avatar
    Oct 03 2013
    Orlando, Florida, United State
    I tried this, it's in there... but when i set to 0 - and said go... it said something about the values not being populated in vcd --and asked if i wanted to try to have vcd populate them (which fails) or hit no, for it to use 123 / 12345 or something. I was a bit afraid to set it to the 123/12345--can anyone confirm what they did if they had the same feedback?
    2013 S6 Oolong Grey / BC Forged HC09 20x10 / Wrapped trim / Black Optics Grill / Wrapped rear diffuser / awe-tuning exhaust black tips / APR Tuned / c-type wing / Painted Emblems / 12" free air sub + Hertz Amp
    2014 SQ5 Volcano Red / 21" wheels (wife's)
    Oct 03 2013
    bueler... bueler... :)
    Oct 03 2013
    nvm, apparently its ok to have it fill with arbitrary values... (for those that find that issue in the future)
    Veteran Member Three Rings KarimS3's Avatar
    Aug 12 2007
    2011 S4 S-tronic
    Washington DC
    In VCDS, what's the factory sound level? Can it be increased? My old man loves it and doesn't want to do any exhaust mods. Would love to crank it up a notch for him. He seems to like the sound of the soundaktor :)
    Feb 24 2011
    Derry, NH
    Not sure if anyone will have these answers, but here goes:
    I'd like to disable any "fake" sounds being generated by the Soundaktor, while being confident that I'm not also muting/reducing/disabling "real" sounds coming from the car. To me, that means pulling the fuse is out: the same fuse for the Soundaktor "speaker" also appears to control the electronic valves in the exhaust, which I'd like to keep active.
    Does anyone know if disabling via VCDS ALSO effects the exhaust valves?
    Over on the VW forums, many people are simply unplugging the Soundaktor in the dash, and leaving everything else as is. Anyone actually locate the Soundaktor on the C7?
    Finally, is there any connection between this and the active noise cancelling that the car is doing (primarily when switching to 4-cyl mode)?
    EDIT: For this last question, it appears the answer is no.
    2016 Cardinal Red Mercedes Benz C63 AMG S
    2018 Navarro Blue Q5
    *HEX-USB+CAN VAG-COM Available for those in Northern MA/Southern NH: Will Mod for Beer!*
    Oct 03 2013
    vcds changing volume to 0% does nothing to the exhaust valves--those are physical... they open and close as far as I'm aware (increase/decrease).
    you should use vcds to change it to 0 and not pull a fuse.
    volume cannot be increased that I'm aware of, it's already at 100... by default. You could try to increase it, but I don't know if vcds would consider it a valid value.
