Results 1 to 8 of 8
    Established Member Two Rings 2fnquik's Avatar
    Nov 07 2013
    Quincy, MA
    S6/S7 Real horsepower?
    Based on calculators that factor in 1/4 mi ET / trap speed and weight, the S6 should have 470-500hp at the crank! I know APR mentions 480 stock on their website. I'm confused about dyno #s of AWHP due to what particular dyno is used and whatever drivetrain loss that is "estimated". Thoughts?
    2014 S6- APR Stage I, Roc-Euro
    2016 Cayman GT4- Tarrett suspension bits, wheels studs
    2014 911 C2S Cabrio
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    i dynoed 399 awhp when i did stock runs
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by sciblades View Post
    With 20% power lost factor, it's about 478.8HP at crank. That's pretty much what APR said.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Veteran Member Three Rings Packy's Avatar
    Dec 12 2011
    2009 Audi A4, 66 Corvair Corsa Turbo (future project car).
    Arizona
    I'd like to know what the real HP is on the RS7. If Audi uses the same "core math" it should be over 600 factory.
    2013 S6, 2009 A4,
    Veteran Member Three Rings KarimS3's Avatar
    Aug 12 2007
    2011 S4 S-tronic
    Washington DC
    Quote Originally Posted by Packy View Post
    According to APR, 582hp stock.
    Mar 31 2014
    Oregon
    I was told by the dealer (for what that is worth) crank HP is 480 and it is understated as this engine is used in the V8 Bently where it is rated around 490 HP I believe. They did not want to have the HP the same when the car values have a 100G spread. I happened to see a Bently last week and the rear brake light was also lifted from the 7. Who knows how many more common parts. When I did research the 0-60 time listed did not add up as it was too low considering the weight of the car and the HP listed when combared to other cars. Then I found out it was understated.
    Next year they raise it to 450 HP I read. Still the same engine.
    Nov 07 2013
    Quincy, MA
    Thanks for the replies.. Makes sense. Weird that they underrate, unless to keep for cannibalizing S8 sales or agreement w Bentley. Right now BMW 550i is rated at 445hp and 480tq and felt like a heavy pig when I test drove it
    2014 911 C2S Cabrio
    Dec 12 2011
    Arizona
    Quote Originally Posted by KarimS3 View Post
    So its fairly close on the RS, but way off on the S.
    I always thought Audi used a conservative rating on the S since the DSG was only rated to 450.
    2013 S6, 2009 A4,
