Pulled mine on ramps with an engine hoist. Also swapped my tranny out couple months back by placing car on stands, and dropping the tranny from underneath. Both not difficult. Part that will give you difficulty is getting the spline of the tranny input shaft to slide into the clutch assembly. Even though things may line up, it won't necessarily just slide right in. At this point you can use longer m14x1.75 bolts on the top two corners of the engine to bell housing and slowly bring the two together (all things lined up). There should be little to no torque necessary to bring the two together. If there is, then there is an issue and you should stop with that method.
Pics for reference
This was with my engine build, and I opted to place the short block in by itself first then placed the head on while shor block was in the car. I found this easier for me, while others find putting everything in at once easier.
