Results 1 to 26 of 26
    Veteran Member Four Rings AudiB5owner's Avatar
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    Proper Jacking Points
    Hey,
    I know this might sound redundant, but many older threads have bad links to pictures. I just got myself a floor jack and was wondering what points to jack the car up.
    I realized how dangerous it was to raise the whole car one of four corners at a time due to the weight shift and heavy nose.
    Where do I place the jack to raise the whole front end and the whole rear end?
    Watching my car shift positions while jacking it is way too scary hahah.
    Thanks
    -Matt
    B5 A4 1.8T FWD
    Veteran Member Three Rings Koldham's Avatar
    Aug 12 2012
    Walnut Grove, Georgia
    i lift my rear from the rear diff housing right at the rear mounting plate thing. and I lift the front at the plate that ties the front cross member to the body. can only lift one side tho.
    1997 A4 1.8QTM AEB Pearl DD
    Deer Strikes:0 HELLASTOCK...ish WTB: pearl white body panels.
    1973 Ford Maverick Project Car(first car)
    200 I6 -> 302 V8, 3spd column shift, 8.8 with traklock. Bright Ass Orange.
    Veteran Member Four Rings bhusted's Avatar
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    The proper place to jack the car is on the pinch weld along the bottom of the doors. Get a pinch weld jack pad.
    | B5 4.2L V8 Quattro | Tein S-Tech | O.Z. Ultraleggera 18x8 | Stabila Course 22mm rear swaybar | Agency Power WRX swaybar links | S4 front brakes | A8 rear brakes | FX-R HID projector retrofit | Fog projector retrofit | RS4 Grill |Aero wipers |
    Oct 30 2009
    Miami, FL
    Quote Originally Posted by bhusted View Post
    But if you're lifting it at the pinch weld, how would you slip a jack stand underneath? For the back I use the diff crossmember, for the front I use the subframe where it goes under the oil pan.
    2018 S5 Coupe - stock for now
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    I was looking for a jack point to raise the whole front end or rear instead of the door pinch welds since the weight is so unequal on a FWD the nose wants to shift forward once I start jacking up the rear. I will check out those points you guys talked about, thanks!
    B5 A4 1.8T FWD
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    Quote Originally Posted by Mad Cow View Post
    I jack on the pinch weld and put my jack stands on the flat points adjacent to the wheels. My stands don't have the notch to fit over the pinch welds. My car is too low/jack is too tall to fit far enough underneath to reach the subframe.
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    I usually jack really carefully from the subframe if I'm trying to get the whole front up, Take it really slowly, per side I do by pinch weld but with my car lower now I have to jack from the door sill before the pinch weld, put a block of wood there, and then put the jack under the pinch weld again
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    I use the pitch weld to lift 1 side of the front so I can use a 2nd floor jack from the front of the car at the spot where the subframe connects to the body. The rear I use the center of the rear crossmember right behind the rear diff. Putting all 4 jack stands on the pitch weld at each wheel, which is how the car sits in the garage between trips to the track so there is no weight on the tires.
    Jun 10 2010
    Where do you all put your jack stands?
    I usually put them on the front subframe mounts.
    Feb 08 2011
    Right on the pitch weld on all 4 corners, that is how my car is sitting right now since I need to swap out transmissions again.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    my rears go on the pinch welds, and the fronts sit on the subframe
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Feb 08 2011
    Quote Originally Posted by GrapeBandit View Post
    Putting them on the subframe makes it a bit harder to get the transmission out. lol
    Orange County, CA
    Quote Originally Posted by M-Hood View Post
    Right on. I do the same.
    B5 Parts For Sale
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Why not raise the car a few inches with the jack that came with the car? Just enough to get a regular jack underneath?
    Quote Originally Posted by down_n_dapper View Post
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Quote Originally Posted by seanj130 View Post
    That is exactly what I have to do. I don't have a low profile jack and the two jacks I have don't fit under a car even on just sport suspension. I use the factory jack to lift it enough to slip the real jack underneath. The two "cups" on the bottom of the subframe support brackets fit perfectly into the jack cup, so I use those to lift. Lifting the car evenly is easy enough with two jacks, though a second person helps to keep me from running back and forth from side to side. Once the car is up I use jack stands on the inside edge of the pinch welds.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Dec 13 2010
    FL
    how is that? thats how I always drop the trans when I need to. its not like you need to lower the sub frame to get the trans out, the whole trans is to the rear of the sub frame anyways
    Feb 08 2011
    Makes it a tighter space to work on everything under the car to get the transmission out, but then I guess I just like the extra space to move around. I have put the jack stands under the sub frame that is under the engine before, but it just ended up denting it. Haven't had any issues with them under the pitch weld in the 50+ times I have had to pull my transmission. lol
    The front of the bell housing is at the back edge of the front sub frame crossmember. I lay with my feet out the front of the car when I take the starter bolts, block/trans bolts and axle bolts out, so the jack stands under the sub frame would be in my way. Just pulled out my transmission this morning in about 45 minutes, longer then normal but then it was was 100+ degs.
    Dec 13 2010
    FL
    I do the same...lay with my feet toward the front of the car and use 16mm wrench to get the 4 bolts on the bottom of block/trans that go in towards the back of the car...some ppl dont even use those bolts though
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    I run the front of my car up on race ramps, then jack up the rear, and put stands under the rear pinch welds.
    Edit: these are he ramps I have. I remove the rear portion when I need the extra room.
    http://m.summitracing.com/parts/bti-rr-56-2
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Dec 13 2010
    FL
    ^I dont even thi k the front of my car will allow me up those ramps lol
    Sep 06 2008
    Bellingham, WA
    They make longer ones.
    -Matt-
    Dec 13 2010
    FL
    Quote Originally Posted by Gumby View Post
    is that what she said?
    but all jokes aside, im good with a jack, but those ramps are cool too, they would especially come in handy for those with a tight garage
    Sep 05 2008
    Pittsford, NY
    My car is very low.. This is what I do: Jack car onto one ramp, do the same to the other side, then the same to the rear, then I add the jack stands..
    Best regards,
    Sean.
    Dec 13 2010
    FL
    oaml...spmar eht fo esoprup elohw eht staefed spmar otno rac a gnikcaj..oaml sdrawkcab sgniht od uoy ,sdrawkcab etouq uoy od ylno ton^
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I used to use this method. Now I just drive onto 2x4's and then onto the ramps. I'm not super slammed or anything though. I am low enough where I cant get my car onto a four point lift without jacking it up however
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Sep 05 2008
    Pittsford, NY
    Not at all, gives extra security when tugging underneath the car. Most jacks don't go that high, so you have to lift it, set it down the. Jack it up again with a wood block to get it even higher.
    ^not only do you quote backwards, you do things backwards lmao..jacking a car onto ramps defeats the whole purpose of the ramps...lmao
    Best regards,
    Sean.
