Results 1 to 20 of 20
Thread: 3.0tdi Mods
    Senior Member Two Rings youngd's Avatar
    Oct 22 2013
    UK
    3.0tdi Mods
    Hello, there doesnt seem to be that much information on the 3.0tdi's so i was just wondering what are the modifications that you can do to increase the performance etc? Iv had the car remapped with DNA stage one which has transformed the car! Iv being considering a dpf gutting but not sure due to mot regs. Iv had a look in the air box and jammed the flap at the bottom open, all this seems to have done is increase induction sound slightly along with slightly better mpg.
    A4 3.0TDI V6 Tiptronic Quattro S Line, Stage One DNA Remap, Phantom Black Pearl, B&O, Auto Brake, Sat Nav, Audi Drive Select
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    We don't get the TDI here in the states so as far as mods are concerned there probably won't be much input from our end.
    Active Member Two Rings Stasbon's Avatar
    Apr 28 2014
    Moscow, Russia
    Revo stage 1 gives not bad gains - app. 300 hp and 620 of torque
    A4 B8.5 2013 2.0 quattro - Revo St.2 // Eurocode Rotamass lightweight pulley // aFe Power Pro Dry S // AWE quad outlet exhaust with AWE DP // Bilstein B6+H&R -35, H&R Swaybars // Rays Sportec Mono 10 Premium R19 // Interior & Exterior mods
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by Stasbon View Post
    I wish there was a plug-and-play mod for the 2.0T that would give that kind of output. Damn that would be fun.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Active Member Two Rings MattSK's Avatar
    Feb 24 2013
    Slovakia
    What u can do ist:
    1. Stage 1 - REVO are really good with TDI and you will get nice results.
    2. DPF removal - this is not recommended :( depends if the law in your country allows it or not. Here in EU they are strict on Emission.
    3. Milltek exhaust system
    4. Stage 2 REVO
    and more :) depends on you badget. U can have also 400 or more hp and over 700 of torque but it cost a lot.
    I have 3.0tdi 176kw and I'm going soon for the REVO stage 1. They have now also better prices so call them. You won't be disappointed.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Upsolute Chip or Alligator Chip
    Kerma Tdi.com has some turbo upgrade options
    Upgraded FMIC: Eurojet Engineering
    Mufflerectomy: Tdiclub.com
    Happy Modding!
    Mar 13 2009
    04 R32 FT450
    KLAS
    He's already chipped. That's what a remap is.
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    I wish we could get 3.0 TDI's stateside.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Mar 13 2009
    04 R32 FT450
    KLAS
    Quote Originally Posted by booost View Post
    True dat. The 3.0 TDI in my wife's Touareg is a beast.
    Jun 05 2009
    Scottsdale Arizona
    Quote Originally Posted by BrewDude View Post
    No kidding. LoL.
    Jul 16 2008
    Finland
    If you want to go all out, your best bet is:
    1.) DPF removal
    2.) New Exhaust
    3.) Uprated FMIC
    4.) Tune / remap made for your exact car, not some POS bulk software but made by someone who knows what they're doing.
    300hp out of a 3.0tdi is not possible without either compromising EGTs and / or Fuel to Air ratio. If the software is made for maximum power, chances are your lambda will be on the rich side every time to go WOT or maybe even part throttle, which in return means your DPF will get clogged super fast.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Feb 24 2013
    Slovakia
    Here is one example for you
    http://www.darksidedevelopments.co.u...v6-cr240-capa/
    or for more money you can do this :) same engine just different case http://www.a5oc.com/forums/a5-perfor...ge-2-no-2.html
    A4 B8 3.0TDI 176kW 2010 Phantom Black Special Edition, S-Line, Leather Interior, Keyless, Panno Roof, ADS, 255/35/19 RS6 Wheels...
    Jun 05 2009
    Scottsdale Arizona
    A full "mufflerectomy" will remove everything from the Down Pipe rearwards. You can run a Cat but eventually soot will fill the item as mentioned above. I think Bosio builds nozzles but you will have to check around on the EU or UK forums:
    http://www.audi-sport.net/vb/audi-s4...ification.html
    http://www.audi-sport.net/vb/audi-s4...injectors.html
    or here: http://www.myturbodiesel.com/wiki/td...-injector-faq/
    I ran Power Plus 520's in my common rail 2001 A4 Bora/Jetta and it made great power. Its a great addition to a chip or other power mod.
    Fred's Tdi page is a great place to get some answers quickly: http://forums.tdiclub.com/showthread.php?t=332687
    I don't know if your A4 3.0 is a common rail or Pumpe Duse. I think VAG went away from PD engines due to wear issues with the cam and followers. The nozzles for the 3.0 are probably as big as you can go already.
    Happy modding!
    Jul 16 2008
    Finland
    Quote Originally Posted by A4 Centaur View Post
    Happy modding!
    All the B8 TDIs are CR, they did away with the PD engines once the B8 came out. The 3.0tdi was also available as a PD engine and the links you posted all deal with the PD version. The CR version can be identified by a 4 letter engine code vs. 3 letters for the PDs. CAPA and CCWA are 176kW 3.0tdi CR engines.
    As of today, there are no bigger injectors available for the 3.0tdi unless you fab something really custom from another manufacturer's parts.
    Veteran Member Three Rings Amorphic's Avatar
    Jun 05 2009
    2013 A4 2.0T Premium 6MT
    BC, Canada
    So jealous of the 3.0 TDI's. I'd be all over that if there were over on our side.
    2015 Subaru WRX STi | Limited | Dark Grey Metallic | Sport Tech | Xpel Ultimate
    Sold -2013 Audi A4 2.0T | Premium | 6 MT | Brilliant Black | Xpel Ultimate | Tint: 35% Front 20% Rear
    Oct 22 2013
    UK
    "A full "mufflerectomy" will remove everything from the Down Pipe rearwards. You can run a Cat but eventually soot will fill the item as mentioned above. I think Bosio builds nozzles but you will have to check around on the EU or UK forums: "
    Well i was considering a "mufflerectomy" but apparently that seems to cause a drone particularly with the automatics, doesn't seem to be much of a problem with the manual.
    "What u can do ist:
    4. Stage 2 REVO"
    And regarding the dpf delete where the inside of the dpf is removed this will probably be my next move because in the UK the to pass a mot they just need to see the DPF and it will pass
    "Here is one example for you http://www.darksidedevelopments.co.u...v6-cr240-capa/"
    Luckily the garage which did my remap has just became a dealer for darkside
    But regarding the REVO remaps i was considering them but i heard some mixed reviews, I wanted to have a APR remap but the map for my car is only available at america
    Jun 05 2009
    Scottsdale Arizona
    Try an inexpensive resonator between the first few feet of pipe.
    Upsolute and ABT and Oettinger all make a tune for the TDi
    Apr 02 2012
    B7 RS4 Saloon
    Auckland
    I have the B8.5 avant S line with the 180kw (242 bhp) TDi and it is superb. I've fitted black 20" VMR wheels. I did not realise the USA does not get this motor - that's sad! I have ordered a miltek exhaust (with 100mm black tips to match the black everything else) and the ECU will be re profiled by Quantum straight after that. It goes really well now - I expect it to leap after this. 7 speed S tronic and Quattro mandatory for this motor - and I am a manual man (my RS4 keeps that side going).
    Veteran Member Three Rings TheHeiko's Avatar
    May 24 2012
    So jealous of you lucky dogs who get the 3.0TDI, especially in a Avant. It's an amazing engine. I've had short term use of several 2013-2015 A8s including one with the TDI engine and it was by far the best even compared to the big V8s. Loved it. Wanted it but in my Avant. :)
    Established Member Two Rings Tineo's Avatar
    Jul 08 2013
    Dairy Land, Asturias - Spain
    Stage I remaped my 6MT w/ CAPA engine
    original oem DPF. The torque is fantastic!!
    2008 A4 B8 3.0tdi Quattro Sedan 6MT EuroSpecs
    Ibisweiss | TLR remap to 301hp | S-Line interior | Rotor 19" rims | S4 front & rear brakes | Depo taillight LEDs w/ fulldynamic LED turn signals | 80mm exhaust tips | S4 blackgloss grill with blackgloss valence | S4 pedals | RSNAV 8.8" ...and more
