Results 1 to 30 of 30
    Nov 10 2013
    annapolis, md
    What kind or size car ramps work for our B8 S4 cars?
    I'm just curious if anyone has used car ramps on your B8 S4 without scrapping the front end;and if so where did you purchase the ramps from? I have a auto zone and pep boys close to me which both sell ramps but I'm not sure if they will work. Anyone have any experiences? Otherwise I might just order some car ramps online. Look forward to your responses.
    2011 Deep Sea Blue S4
    7-speed DSG / B&O / MMI with Nav / Advanced Key / Carbon Atlas Inlays / Black Leather /19" Peelers/Push Button Start/Sport-Diff/Comfort Mode;)
    Modifications: Stage 2 GIAC w/Emmanuel Design Pulley, TCU DSG GIAC Tune, EuroCode Alu Kreuz, Roc Euro Intake, 034 Trans mount, Apikol mount, H&R front & rear sways
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    I use rhino ramps. As long as your car isn't lowered then it should be fine
    2016 M3 Mineral White
    2014 S4 Ibis White - Sold
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Race Ramps makes ramps for low clearance vehicles. Lightweight and great quality. Pricey though.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by milk242 View Post
    Nice my car is not lowered so I'm assuming they should work. Are these it? http://www.autozone.com/autozone/acc...er=366075_0_0_
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by Moose201 View Post
    Thanks for the reply. You weren't kidding about being pricey$$$$$.
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    Quote Originally Posted by z_curtis_s4 View Post
    I have the 12000lb ones. But I would think all rhino ramp inclines are the same
    Nov 10 2013
    annapolis, md
    Could be a silly question but with our cars on these ramps is it high enough to get underneath the car with a oil pan to drain the oil?
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    I was able to change out the brace to the eurocode brace so I would think you would have enough room
    Nov 10 2013
    annapolis, md
    Wow seriously about "installing the eurocode brace" on the ramps. I thought that was a big no no. I have a Alu Kreuz that I haven't installed yet. But my point is aren't you suppose to install the Alu Kreuz using jack stands or obviously a lift and not on ramps? sorry to get off subject for a second.
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    Oops I got my installs confused. I did my endlinks and sway bars on the ramps
    Nov 10 2013
    annapolis, md
    Cool. Just didn't want you to hurt your ride. How hard is the install for the endlinks and sway bars? Just curious for my future other mods.
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    Front sway bars and endlinks weren't bad on the ramps but I would recommend doing the back swaybar and endlinks on jack stands. I believe you'll need two same size wrenches for some of the bolts.
    Nov 10 2013
    annapolis, md
    Nice to know that I could do the install myself. The sway bars and endlinks will be in the far far future. Next on the list is some ramps for oil changes and getting around to installing my Alu Kreuz with jack stands.
    Aug 26 2012
    2013 S4 Ibis 6MT
    There's a posting in one of the oil change threads where Swank says he does oil changes with his car flat on the ground. Amazing that he can do that....ramps work great for this purpose though.
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    shouldn't a sway bar install always be done under load?
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    Quote Originally Posted by mr shickadance View Post
    Not sure. I just went with what was in the eurocode install instructions. Where they said that the sway and endlink install can happen on jack stands if you are not using the factory endlinks.
    Senior Member Three Rings kap09's Avatar
    Jun 22 2010
    2017 Grand Cherokee, 2015 Fiat 500e, 2016 eGolf, 1989 Jeep Wagoneer
    Choice of endlinks is the determining factor. When you compare the two it's obvious why. I didn't do endlinks for my sway install and honestly wish i had JUST so i could have had the car on stands instead of ramps for the extra space.
    2014 S4 | DSG | Ibis White | Sport Diff | MMI | Carbon Atlas | B&O | Side Assist | SC Badged
    GIAC Stage 2 v2 | GIAC DSG | Roc-Euro Intake | AWE 102mm | Brembo 380mm | Deval Rear | OZ Leggera | Michelin PSS | OE Sport | AluKruez | H&R Sways | 40% Pinnacle Tint | Hoen Endurance | VCDS Mods | Escort 8500 x50
    Past Rides
    2013 S4 6MT//2010 A4 Quattro//2000 BMW 323i//1991 Integra//1990 Jetta//1993 Civic
    @kap9 on Instagram
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Schwaben ramps are pretty nice. Check them out.
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by SwankPeRFection View Post
    Wow those are pretty sweet. Just looking for a pair that is reasonable in price$.
    Apr 04 2012
    MSP
    I'm rocking Rhino Ramps. Rear no issue. Front is a little tight with clearance. I'm lowered though.
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by MrFunk View Post
    Nice those are the ramps I'll probably end up buying. I am not lowered thankfully and think I should be fine with these ramps.
    Aug 26 2012
    2013 S4 Ibis 6MT
    Clearly those are rebadged Race Ramps. Great design, absolutely no movement when you roll onto them. The two piece ones are slightly more but definitely worth it for the added flexibility.
    Jul 08 2010
    tucson
    danbury
    weird, every sway bar install i have done has made it very clear that you need to have your car under load in order to not mess up the alignment, but maybe the s4 has a modified subframe or something fancy and german that it's not the case.
    eitherway!
    OP, right now, rhino ramps are on sale on amazon for 44.99 with prime shipping (i think) and if you are worried about not clearing the ramps, buy two 2x4's at home depot and lay them on the beginning of the ramps, as I write this I see how redneck it sounds, but honestly, it's not unsafe to do so, you are basically just extending the rhino ramp to get your clearance.
    [CENTER]Scott
    2011 S4
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    I posted this in another thread as well...
    2 pieces, works very well
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by phillips2024 View Post
    Where did you buy these "Race Ramps?"
    Mar 03 2011
    Southern NH
    Race Ramps RR-XT-2 67-Inch XT 2-Piece Race Ramp by Race Ramps http://www.amazon.com/dp/B003ZAHTC4/..._5du3tb13PWADG
    Veteran Member Four Rings svander's Avatar
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    I have the rhino ramps too. After installing the deval lip they no longer fit the front.
    Aug 26 2012
    2013 S4 Ibis 6MT
    I bought the two piece, 56" version on Amazon for $228.
    Veteran Member Three Rings mmmkam's Avatar
    Sep 29 2013
    NoVA
    Just picked up 4 12" race ramps tire cribs. Should leave more than enough room to work on most items.
    2014 S4 6MT | Estoril Blue | Prestige | Sport diff | Carbon atlas inlays | ADS | Alu-Optic package | Fine Nappa Black/Silver | Pwr Sun Shade | 19" Peelers | AG M590 19x9.5 ET40 | Xpel Ultimate | Gtech Coating | WeatherTech Floorliners | RS4 Grill w/ Matte Silver Surround | AWE Resonated Exhaust | Revo Intake | AWE Pulley | GIAC Stage II Tune | EC Shifter | EC Alu Kreuz
    Jan 14 2014
    Sacramento, CA
    Or, you could invest $85 in an oil extractor and leave the car flat on the ground.
    2014 S4, Ibis White, 6MT, B&O, Sport Diff, ADS, Alcantara, AWE cat-back, Alu Kreuz, Apikol rear diff bushing, 034 trans mount insert.
