Results 1 to 31 of 31
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Spark Plugs, difference between the Bosch and NGK pre/post facelift?
    Well the time has come for me to finally get new plugs.
    According to audi the spark plug for the pre facelift is a Bosch 101905631G
    the plug for the post facelift is a NGK 101905611G
    My question, is there any reason that the post facelift plug wont work in the pre? there is a $30 difference between the 2 sets.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    I replaced my OEM Bosch plugs (from the factory) with OEM NGK plugs from the dealer parts department. Same heat range. Go with whatever is cheaper.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    if you are tuned, you should consider going one step colder for whatever plug you plan on running.
    also, keep to the manufacturer guidelines, slightly off topic, but in the subie world, (and I am sure I will get my companies mixed up but) if OEM called for NGK, and you ran bosch, you would see issues with the install of the bosch due to the washers they used....you had to be oddly specific with plugs and oil filters for subies, but I don't think audi has that issue.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Feb 12 2013
    Boston, MA
    Quote Originally Posted by mr shickadance View Post
    There are no tuners that recommend this.
    Jul 08 2010
    tucson
    danbury
    it would not hurt, running increase boost and leaner conditions a step colder would help ignition.
    [CENTER]Scott
    2011 S4
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    I had a 600whp Subie before my S4 and never heard of this. I used NGK and Nippon without any issues at all. I was pretty deep in the Subaru world and never once heard of an issue with washers on a spark plug causing install problems? Granted most people stuck with NGK or Nippon since they are both OEM to Subaru.
    2024 RS3 Kemora Gray
    Feb 08 2006
    Petaluma, CA
    I've been using the NGK 101905611G (PFR8S8EG) for about 10k miles on Stage II. I noticed no difference in performance. They're the same heat range (8) as stock and only about $12/each.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    It actually can hurt fuel mileage and part throttle response. Absolutely zero reason to run 1 step colder plugs in an S4 with just a little more boost.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by integroid View Post
    folks at EFI told me that the Bosch plugs did not seat right, I took them at their word given their high reputation.
    [CENTER]Scott
    2011 S4
    May 14 2007
    Northern VA
    Please back this up with some actual data......
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Jul 08 2010
    tucson
    danbury
    increased boost + leaner conditions + high compression engine = potential pre-ignition problems
    solution for this problem colder spark plug.
    NGK's website
    It depends on the modifications. The term "modified" refers to those engines that have received bolt-on improvements that may or may not raise the engine's total compression ratio. These can include turbocharging, supercharging, nitrous oxide injection, the use of smaller-chambered cylinder heads, modified piston configurations, free-flowing cylinder heads, change of induction components and/or the use of different fuel types and octane. These kinds of modifications generally require a change from stock spark plugs.
    Modifications that will typically not require specialized plugs (in most cases the factory installed plug will be more than adequate) include adding a free-flowing air filter, headers, mufflers and rear-end gears. Basically, any modification that does not alter the overall compression ratio will not usually necessitate changing plug types or heat ranges. Such minor modifications will not significantly increase the amount of heat in the combustion chamber, hence, a plug change is probably not warranted.
    However, when compression is raised, along with the added power comes added heat. Since spark plugs must remove heat and a modified engine makes more heat, the spark plug must remove more heat. A colder heat range spark plug must be selected and plug gaps should be adjusted smaller to ensure proper ignitability in this denser air/fuel mixture.
    Typically, for every 75-100 hp you add, you should go one step colder on the spark plug's heat range. A hotter heat range is not usually recommended except when severe oil or fuel fouling is occurring.
    http://www.ngksparkplugs.com/tech_su...d.asp?mode=nml
    I know the first part of the FAQ is a bit misleading, but we are with our tunes adding a serious amount of HP, at stage 2, I would figure it's common sense to run a step colder but apparently not on this platform.
    [CENTER]Scott
    2011 S4
    Jul 08 2010
    tucson
    danbury
    another article calling for spark plug tuning, albeit lengthy, a good read.
    if you are lazy, read from the bolded "heat range"
    http://www.carcraft.com/techarticles/spark_plugs_tips/
    [CENTER]Scott
    2011 S4
    Account Terminated Four Rings
    Mar 08 2010
    San Francisco, CA
    NGK OEM replacement plugs are what you should do. Don't change the temperature. If you want to go high end, you can replace the coil packs with Ignition Projects for $900 for a set of 6.
    Sent from my Nokia 1520 using Tapatalk
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    If they changed manufacturer of the plug all together then audi didn't like what was going on. My guess was a lot of warranty for plugs was happening and even though audi probably wasn't paying for it they didn't wanted less warranty complaints. Either they wouldn't seat right like guy said that could leads towards them coming loose over time and cause other issues. Or they wouldn't last and need replacement under warranty and not as a cash job. NGK are just better all around plugs in general i believe.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Black Tokio Roki oil filter FTMFW bro! I had a stockpile of them and when I ran out, it was time to trade it in anyway.
    Jul 08 2010
    tucson
    danbury
    i thought the subie OEM filter was best? i ran a K&N oil filter which sprung a nice leak on me, and again, I was told by the service tech that subie didn't like non-OEM oil filters, i left that out because I think service techs don't really know what they are talking about/are more likely to push OEM over anything else but the sparkplug thing came from EFI Logics, I think they know their shit forwards backwards and diagonal.
    [CENTER]Scott
    2011 S4
    Aug 05 2013
    N/A
    You obviously weren't around the Subaru WRX/STI world when it first came over to the US then. Originally back in the mid 2000's, Subaru used Japanese made oil filters from a company called Tokyo Roki. They were the best filter hands down. Then they tried some crap white ones that leaked. Then as the newer model cars came around, they went with the other crap blue ones. Nothing came close to the originals and everyone would kill to get their hands on them. Here's a pic.
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Is that *your* kitchen counter? Think you have enough of those filters (19)? LOL
    Mar 01 2013
    Atlanta, GA
    The Black Tokyo Roki was the OEM made in Japan oil filter from Subaru. They later cheaped out in the US for the H4 motors and started selling a blue filter made by fram. Once they did that I started using the Black Tokyo Roki H6 filters since they were still importing those and they fit the H4 motors even though they were twice as big.
    Jul 08 2010
    tucson
    danbury
    getting back on subject, because it kind of surprises me that no one on here has even experimented with colder plugs.
    I have not really seen a counter point towards not running colder plugs other than "the tuners have not said to run colder plugs"
    I am not trying to be a smart ass, but only trying to invoke some actual discussion on the matter, I brought my side to the table, which condensed is basically, you are asking more of your engine, your engine in turn is going to run a little leaner, a little hotter, and in efforts to curb pre-ignition, running a step colder seems like a decent/worthwhile idea.
    thoughts?
    [CENTER]Scott
    2011 S4
    Mar 08 2010
    San Francisco, CA
    thoughts?
    I went down this line of inquiry also and I think one issue (among many) is the service interval would fall to like 10,000 miles from 60,000 (or 40,000 if you're tuned).
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by westwest888 View Post
    english please?
    [CENTER]Scott
    2011 S4
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    I run the standard ngk plugs
    After pulling them the heat range was perfect with no signs of detonation, no need to go with a colder plug
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Mar 04 2012
    Quote Originally Posted by saxon View Post
    I've heard similar results here. Unless someone has observed otherwise on their stock plugs, with pics preferably, I'd leave it be.
    Jul 08 2010
    tucson
    danbury
    Pics of plugs?
    [CENTER]Scott
    2011 S4
    Oct 16 2012
    pa
    Pics of plugs?
    Didn't take any, I will take them out soon to see how they are responding to meth
    Jul 17 2010
    996 Turbo
    Batavia, IL
    thoughts?
    No one is experimenting with colder plugs because no one has had any reason to. The 3.0TFSI engine isn't having any detonation or pre-ignition issues with a smaller pulley and a tune, so there isn't any reason to.
    I run 1 step colder plugs in my Z and I have added over 300hp. That is a modification level in which colder plugs should be used.
    Simply generating a bit more boost from the same supercharger that was installed from the factory is not.
    There are no tuners out there on any platform that recommend colder plugs for a simple pulley drop.
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by Vogz View Post
    I disagree, and so does ngk and given the understanding of heat ranges it's not like it's a crazy idea to bring this subject to the table
    [CENTER]Scott
    2011 S4
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Disagree all you want, it won't change the fact that colder plugs are simply unnecessary in this application. NGKs description is a very generic one and in theory sure it sounds good, but in practice, we are telling you why isn't not necessary. I also tried to tell you that it will negatively affect gas mileage and partial throttle combustion because cold plugs need more heat to clean carbon build up off of them. That's why you don't see manufacturers using the coldest plugs available in every application.
    If people were melting holes in pistons, then colder plugs would be one of the many things that would have to change to continue pushing the performance envelope forward.
    It's not a crazy idea, but we've already discussed it. Just let it go.
    One of the things that many people don't think about when modifying cars is the more shit you change, the more chance you will have of problems or undesired consequences. Don't change something until there is evidence that it needs to be changed.
    Aug 05 2013
    N/A
    Vogs is right in terms of drivability. If you go too cold, they'll foul up and cause a sputtering sensation on the first couple of power pulls after puttering around town.
    The thing with colder plugs is that you need to pick a range that helps a bit to move additional heat from the combustion chamber to solve some detonation issues but doesn't pull so much that it causes them to foul up when idling or other non forceful driving conditions. Because of this, you will NEVER be able to use heat range change on plugs to solve your detonation issues. This is why usually, most tuners will correctly tune an engine for maximum output while maintaining a level of safety in direct relation to what is needed to maintain drivability when not pushing the car.
    This is why you see drag cars and other purpose built cars run like crap when they're not just balls to the wall. You either tune for high output and sacrifice drivability or you tune for drivability and reliable output. You can't really have both in perfect mix, at least not a perfect level of both. Hope this makes sense to people.
    Apr 17 2004
    Socal
    Just changed the plugs out today for factory NGKs. Car's at 55k, plugs may have been changed at ~33k when I bought it CPO. Looks pretty much perfect.
