Hey guys, sorry if this has been covered before. So I am about to buy someone's stock OEM exhaust from a B8 S4, and plan to fit that into my car. So I know the S4 has 2 downpipes, so what I'm planning on doing is getting a Y-pipe adapter and I'll fit that in to my single downpipe that way. I'm assuming the A4 and S4 exhausts are both 2.25" pipe diameter? So they should clamp and fit together fine? And I'll get a 2.25" Y-pipe adapter and that will work?
Also I know I will need the heatshield and hanger for the other (right) side of the exhaust. I could only found another thread about this and found the following parts I needed:
AUDI B8 A4 PASSENGER SIDE HEAT SHIELD FOR EXHAUST - Quantity 1
8K0804172
CLIP FOR HEATSHIELD - Quantity 4
N90796502
HANGER ASSEMBLY - Quantity 1
8K0253144M
So my question, is that all that I need? Just those 3 things? Do the heatshield clips (which are clamping washers) just clamp on themselves or do I need a separate bolt or screw or something for each clip? Also, is that the proper hanger assembly I need, do I need any other bolts or anything for that hanger? Basically just concerned if I need some more extra bolts or any other hardware, if someone has done this before please let me know, looking to order the parts asap so just want to be sure of what I need before buying all this stuff. Thanks!
EDIT: So I found the AWE PDF file with the extra parts, seems like it's just those 3 above, and also fastener nuts (N90348411). Just wondering, is that all I'll need, no other hangers or bolts or anything else anywhere?
