Page 1 of 10 123 ... LastLast
Results 1 to 40 of 364
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    MFSW Info for the B6 - Single Stage Airbag
    Had a couple of requests awhile back to gather the information together from my MFSW install I recently finished up. I know this information is out there, it's just takes some digging to pull it all up. Hopefully this helps some others out there!
    I debated for a long time on just throwing a B7 MFSW in and calling it a day. However, the dual stage airbag debacle kept me from making the leap. I decided to start researching alternatives.
    My project goals consisted of:
    -Finding a MFSW to augment my RNS-e
    -Finding a single stage airbag to augment not dying in a crash
    -Finding a MFSW/ single stage airbag combo that mated without issue
    -Keeping it cheap (this meant skipping the flat-bottomed wheel - didn't really care about this)
    Here's my parts list/source/price paid:
    - MFSW - from an A5 (2009-2014) - 8K0419091CB - ebay.co.uk (Ireland) $100
    - Single Stage Airbag - from an A3/S3 (8V) - 8V0880201N 6PS - eBay.co.uk (Hungary) $300
    - Single Stage Airbag/MFSW harness - 8U0971589C - (mine was included with the airbag I bought)
    - Control Module - from a B7 A4 - 8E0953549Q - salvage yard - $100
    - Clock Spring - from a B7 A4 - 4E0953541A - salvage yard - $60
    - 4 pin connector - from a B7 A4 - 4E0972133 - local/dealer - $5
    Total cost $565
    Tools needed:
    - Torx T8 screwdriver (Sears sells the one you need, 2.5" long - seriously, the Sears one is perfect)
    - Torx T27 screwdriver
    - Torx socket T55
    - Allen Hex socket 4mm
    - 10mm wrench
    - Small flat screwdriver
    - Lisle 56500 Terminal Tool - used for swapping wiring between connectors - (get it on Amazon, it's WORTH the 5-10 bucks)
    - VCDS
    - DIY instructions w/photos courtesy of DIYAudi
    Additional info:
    The unknown variables I faced at the beginning of my project were which steering wheel control layouts were compatible with the B6 and which wheels/airbags mated correctly with one another .
    First, from my understanding (gleaning info from the very few sellers that offer the flat-bottom MFSW package and various threads), there are only some MFSW button layouts that work with the B6/B7.
    I threw this diagram together in MSPaint to describe my understanding:
    I went with the button layout from the first wheel because I'd seen it physically work before and it's the layout that HazzyDayz/Europrice both sell in their packages.
    Once I knew which button layout to go with, I moved on to finding a single stage airbag that would mate with a MFSW. In my search, I found that the easiest wheel to source was an A5 wheel that had the hook style airbag attachment. The 8V0880201N 6PS airbag from the 8V generation A3/S3 has the hook style attachment and is single stage so it fit the bill as well.
    Photo of the MFSW with hook style airbag attachments:
    Notes on the install:
    1. There are a few different versions of the yellow connector that go into the clock spring. The one I got with my airbag needed to be trimmed just a hair to plug in correctly to the B7 clock spring. If you wanted to make this perfect you could pick up the correct connector from a B7... I didn't care and mine functions just fine.
    2. I did not need to code my control module with VCDS. It automatically set the proper coding with the MFSW installed. However, I did need to code the ABS module again as it had zeroed out (04275 for me). side note: I got excited when the ABS module zeroed out thinking that I'd be able to code properly for my larger B7 front brakes... it didn't.
    3. For my install, I needed to swap wires on two connectors. First, the 4 pin connector that plugs into the control module. Second, my yellow airbag/MFSW connector needed to have the wires moved around to get everything working. There are 12 pins and my wiring matched this photo (credit to vinny.dtw for posting this here).
    Pin Layout:
    1 | 2 | 3 | 4 | 5 | 6
    7 | 8 | 9 | 10 | 11 | 12
    1 - Brown (Ground)
    2 - Blue (Airbag)
    3 - Black (Airbag)
    4 - Green (Airbag)
    5 - Empty
    6 - Empty
    7 - Empty
    8 - White (MFSW Controls)
    9 - Purple (MFSW Controls)
    10 - Empty
    11 - Empty
    12 - Empty
    Closing notes
    Well, that's pretty much all of it. With some more patience on getting parts I know I could have done it even cheaper. I just got anxious.
    All in all, I'm extremely happy. I'm still getting used to remembering that I don't need to reach over to my RNS-e for every little thing. Now I just need to source a Bluetooth module to get some more use out of these fancy new MFSW controls I have!
    Let me know if I missed anything or if you have any questions!
    UPDATE: If you want to use a TT 8S wheel like the one seen below, you'll need a highline LIN1.3 to LIN2.0 (updated highline communication protocol introduced in 2009) adapter harness to get the MFSW to work with the B6. Gosser has a contact/mini write-up later in this thread here if you're interested in going this route.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    Money, thanks for the writeup! I've got an A5 S-line wheel already (with perforated sides), and also have the A3 airbag on the way (from Hungary, so probably from the same ebay seller); can't wait to get it installed. BTW, how long did it take to get your airbag?
    Fry Sauce, UT
    Quote Originally Posted by Steve Bassen View Post
    It took a few weeks. I know they get creative with the shipping method in order to get the airbag over. I'm not sure what all is entailed.. I just know it takes a bit longer.
    It's worth it though!
    - Steve
    NKAWTG
    Senior Member Three Rings k909068's Avatar
    Jul 21 2013
    The First State
    Nice write-up!
    Jul 21 2013
    The First State
    Solved
    Dec 15 2011
    Edmonton Alberta
    Quote Originally Posted by Spike00513 View Post
    It appears that there are multiple versions of your steering wheel, that work with your airbag. 8K0419091BL being the one with zero buttons on it whatsoever, your PN being the perforated S-line, and 8K0419091BN being the solid leather/non-perforated regular A5 (non S-line).
    Buttonless 8K0 419 091 BL:
    I hope the above wheel will work, since I just ordered it...
    I also think that there's another suffix part revision letter change, indicating that the wheel is grey leather.
    You can also buy a cheap B7 wheel and add the steering wheel controls in anytime...
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
    Fry Sauce, UT
    Are you planning on swapping the MFSW controls into this wheel?
    - Steve
    NKAWTG
    Mar 05 2013
    CA
    Quote Originally Posted by agentsmith988 View Post
    Maybe one day. oCarbon also makes a nice carbon wrap of the MFSW trim. I don't like how shiny the gloss black is, I think it's distracting. The buttons would help, but I still won't have the Audi soft-touch material (or whatever they use) on the bottom part of the MFSW trim. I'm sure the piece can be bought separately.
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    I have a new single stage airbag with harness for the newer round steering wheels above for anyone that wants a setup like the OP.
    http://www.audizine.com/forum/showthread.php/612734-2012+-Round-Steering-Wheel-Facelift-Airbag-single-stage
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Mar 05 2013
    CA
    Looks like the Euro SQ5 wheel fits too...not sure about US-spec ones..
    Maybe it's just me, but it looks smaller too, which I'm guessing makes the car more fun to drive, as long as it doesn't make it harder to turn. Which I doubt it would, since we have reportedly overboosted steering hydraulic steering..
    Aug 26 2005
    OP, PM sent.
    Vorsprung durch Technik
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    Thanks for the write up agentsmith. Ive been looking for a MFSW with a working airbag, and IMO that A5 wheel looks much better than the b7 one.
    Fry Sauce, UT
    Quote Originally Posted by Fouad1013 View Post
    No problem! I've had this setup for a few months now and love it more and more. And since adding the OEM Bluetooth module I get even more use out of it to activate SDS/select contacts.
    - Steve
    NKAWTG
    Oct 23 2010
    Cranberry TWP, PA
    Yeah, thanks for doing the writeup, it worked great for me when I did it a few weeks ago to mine, as well. Most time consuming part was just dremeling the B7 airbag connector to fit the new airbag harness.
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    How about this from an A6? Would be great since you'd get the added heated wheel feature.
    Fry Sauce, UT
    Quote Originally Posted by claudiovagkraft View Post
    Unless anyone has confirmed otherwise, I don't think that button layout would be compatible. If you could find a heated wheel with a button layout that is compatible (see one of my earlier posts in this thread for compatible setups) then I don't see why you couldn't get the heated function to work.
    - Steve
    NKAWTG
    Jul 21 2013
    The First State
    I did the upgrade today, no error code, no light. I can use the volume +&-, channel +&-, but no mute function(push the volume roller). Is this normal?
    B8 RS4 FBMFSW
    B7 SC+module
    Symphony2+
    Fry Sauce, UT
    Quote Originally Posted by k909068 View Post
    B8 RS4 FBMFSW
    B7 SC+module
    Symphony2+
    Here are the functions of that wheel in a B6:
    Mode: Opens Bluetooth phone book on the DIS (scroll with OK wheel and select with OK wheel click)
    OK Wheel (scroll): Channel/Track up/down
    OK Wheel (click): Seek/Scan and Answer/Hang-up for phone calls
    Voice: Activates Bluetooth SDS (Speech Dialogue System)
    iNav: Nothing
    Volume wheel (scroll): Volume up/down
    Volume Wheel (click): Repeat Navigation instruction
    So yup, it's functioning as it should. Mute can only be accomplished via the head unit itself (both RNS-E and Symphony) . Time to install some more goodies to get more use out of the controls!
    - Steve
    NKAWTG
    Jul 21 2013
    The First State
    iNav: Nothing
    So yup, it's functioning as it should. Mute can only be accomplished via the head unit itself. Time to install some more goodies to get more use out of the controls!
    Guess I'll have to get a RNSE for the mute function lol.
    Fry Sauce, UT
    Doesn't pressing the volume knob on the HU mute the audio on the Symphony II+?
    - Steve
    NKAWTG
    Jul 21 2013
    The First State
    Yes, it does work. I just thought I can mute the HU by steering wheel before retrofitting.
    Feb 17 2004
    Liberty Hill, TX
    you can't mute the RNS-E from the steering wheel either
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Jul 21 2013
    The First State
    Quote Originally Posted by Matt Devo View Post
    Lol, thanks for the info!
    May 22 2012
    Estonia
    Thanks for this writeup agentsmith988!
    Did this mod today. Parts as yours. All connections did as you described. Works great. As i use 1-din Alpine CDE-123R with UNI-SWC.2 not audi stereo, there is some differences. With B6 MFSW i had vol +&- and seek +&-. Also changed cd and usb tracks, but no preset station change on wheel. With new wheel -1)Left roller-stations seek up and down. Cycle through preset stations when pressed continuously. 2) Right roller - vol up and down. Push-mute. MODE - cycle through radio/disc/usb. So great improvement to me. Think i have to add BT module also. Again thanks a lot for this DIY!
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    control module parts 8E0 953 549 T work with this setup ? also yellow plug have 6 wires for controller and from steering wheel only 3 ?
    Established Member Two Rings UofU_USP's Avatar
    Dec 09 2013
    04 A4 USP 1.8T 6MTQ,09 Acura TSX 6MT
    SLC,UT
    Great threads/write up! Should have seen this before I ordered my new setup. I love it!
    Fry Sauce, UT
    Quote Originally Posted by xhackerekx View Post
    I believe the T module should work. As long as it's from a B7 I think that you're good to go.
    I'm not sure which plug you're talking about though...
    Quote Originally Posted by UofU_USP View Post
    - Steve
    NKAWTG
    Dec 03 2013
    wolverhampton
    Thanks for your brilliant write up on the mfsw upgrade,
    i am also like you with a B6 and wanting to do the upgrade but sceptical about going for the dual stage air bag on the B7 model.
    I have found a 2007 A5 steering wheel which looks identical to the one in your picture with the same button function configuration.only difference seems its smooth leather and not perforated.
    I dont know the part number of the wheel but do you think it would fit based on the information i have, so i can then purchase the A3 8v single stage air bag?
    Any advise would be much appreciated thank you
    martin
    Jul 21 2013
    The First State
    Quote Originally Posted by martyj200 View Post
    martin
    I think you're good to go, just make sure you source a right SW with this hook style.
    Fry Sauce, UT
    What k909068 said. You need that hook style to pair with the single stage 8V airbag. If you've got that and a compatible button layout, you're good to go.
    - Steve
    NKAWTG
    Established Member Two Rings StraqAttaq's Avatar
    Jun 16 2015
    Austin, TX
    I've been reading pretty much everything I can about doing this swap. Glad to see there is a single stage solution instead of trying to fit a dual stage airbag into my B6. Really great write up agentsmith! My question is actually in regards to the controls. I have a B7 MFSW and was wondering if the buttons would fit and function in the A5 steering wheel or if I would have to get new buttons?
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Quote Originally Posted by StraqAttaq View Post
    They are different. Also the controls from the A5 wheel will work on a B6. I have a few wheels and have tested them all.
    In case you are interested in this swap I have the airbags and steering wheels in for sale.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Jun 16 2015
    Austin, TX
    Thanks PreciseD. Was hoping they were the same. I'm actually having Nexon Motors build me a custom carbon fiber wheel but trying to get all the specs right before hand. I would need the airbag and now buttons for the wheel as they only build the core. They do offer the other parts but it's a lot cheaper finding them yourself. I don't see the items under your for sale section. I would be looking for the single stage airbag w/ harness and the control buttons, what would that run me?
    Feb 05 2014
    You will need to make sure you use the correct A5 buttons. I think the USA version has too many and will not work on the B6. They need to be EURO.
    Did you get my PM?
    Aug 26 2005
    B8 RS4 FBMFSW
    B7 SC+module
    Symphony2+
    This wheel has shift paddles, are you using with a tip trans or just not using them? If not with a tip, they can be removed, right?
    Fry Sauce, UT
    My wheel came with the paddles and I removed them. However, removing the paddles leaves little indents where they used to be. I had intentions of making a filler when I removed them but have since stopped caring. I never notice/see them anyways.
    - Steve
    NKAWTG
    Jun 16 2015
    Austin, TX
    Does anybody have experience doing this retro with an aftermarket nav/stereo? I ask because these days there are better systems than the Audi RNS-e and they are cheaper too. I don't care about having the OEM part in my B6 but do want to have the steering wheel function. My thought is that I would perform the retro as if I had an RNS-e and the aftermarket stereo/nav should work the same way. Is my thought process correct?
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    as long as the aftermarket HU responds to the same signals then yes it should work, there are some nice ones now on ebay(not drastically cheaper) but that look like the rns-e but have way more functionality such as built in bluetooth pairing.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jun 16 2015
    Austin, TX
    Exactly what I was looking at @Blitz2190. Thanks for the response.
    Established Member Two Rings sleuthnorange's Avatar
    Nov 15 2005
    Ford Explorer
    Waukesha, WI
    So I made the fatal error of not taking a picture of the where the wires go on the the 4 pin connector? I think I have it right but I want to be sure. There are only two wires: Its a yellow and a white wire. Can anyone hook me up with the pin out of that connector?
