Results 1 to 32 of 32
    Veteran Member Four Rings SpoolBus's Avatar
    Aug 07 2013
    ATL/GA
    AC Stopped Working.. $2,739.62 later were good..
    So thought I would share, had the ol' AC compressor explosion, compressor throwing metal throughout the system.
    1- AH Compressor $1,1160
    1- Q Drier $245
    1- Restrictor $38.76
    2- A Washer $38.76
    1- Spacer $2.36
    2- C Washer $4.24
    2- C Washer $8.40
    18- 134A Ref $21.60
    2- Clip $4.68
    2- Clamp $2.12
    Parts= $1,515.62
    Labor= $1,224
    3 hour system flush to get the metal out of the system.
    Total= $2,839.62 (after $100 deductible)
    So pushing through the problem areas within less than 1 yr ownership (control arms replaced, VC gaskets replaced, power steering replaced, AC replaced, valley pan gasket replaced x2, glove box, arm rest, window regulators, failed passenger pre cat, new coils)
    BTW the AC repair took 11 days..Woot woot...love hate relationship.
    I had the same issue with the AC compressor, but quite the difference in the repair cost/time. I had mine done in just a couple hours, and it was a mere $1800. I don't have the price breakdown with me, I'll update this later with it after I grab it.
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    Haven't had my AC working on one of my b6's for years. Thats a hefty bill, yikes! Just so you know JHM has AC compressor on sale for around 7 bills if i recall
    Glad she's back up and blowing cold air! Im not looking forward for whenever i take care of my AC.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    I did it for $400 myself. Wasnt too bad. About 7 hours total. Why did it take 11 days
    Veteran Member Four Rings gcoy's Avatar
    Apr 06 2009
    2005 B6 S4 6mt Avant & 2001 B5 S4 6mt Avant (Sold) & 2007 VW Passat 3.6 4Mo wagon
    Boise Id
    Wow, That sure seems steep... but living in Atlanta, I'm sure AC is priceless...
    Aug 07 2013
    ATL/GA
    Yeah 93ish temps in the worst traffic in the SE = bad.
    Price was steep but done by Audi and covered for 12 months no question.
    Also surprisingly my 3rd party paid all of it (I only paid the $100 deductible).
    I also had a 2014 A4 S-Line for the 11 days so wasn't so bad (supposedly the machine to flush the system broke, ha machine working on my broken machine broke..just bad luck I guess)
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    No condenser replacement? Odd....
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    Holy cow that's pricey. I'm going to stop using AC, don't really need it anyway and I don't want that bill. Just need to run it now and then to keep the hoses from getting brittle.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    it is drive shaft driven by the main chain... so it runs continuously, although at a lower pressure when in eco mode
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    Well, that's not very cool.
    No longer my "DTM" S4
    Rolling STOCK B8.5 S4 for over a year and happy!
    Veteran Member Three Rings cheetah993's Avatar
    Mar 29 2012
    Plattsburgh, NY
    Quote Originally Posted by event View Post
    Haha I see what you did there.
    My engine rebuild: http://www.audizine.com/forum/showth...Engine-Removal
    JHM Lightweight Flywheel--Stage 4 Clutch--034 Street Density Engine Mounts--034 Street Density Transmission Mount--034 Snub Mount--034 Zero Tolerance Bracket--USP Metal Slave Cyl/Metal Clutch line--JHM Short Throw Trio Package--JHM intake Manifold Spacers--JHM tune 93 octane--2.5" 200 cell downpipes--Magnaflow catback--Avant Garde M310 18" Rims--Cross Drilled, Slotted Rotors
    Established Member Two Rings devilbones's Avatar
    Sep 27 2012
    Bristow, VA
    Quote Originally Posted by SpoolBus View Post
    Which company do you use?
    Mar 29 2012
    Plattsburgh, NY
    Feb 18 2014
    Arizona
    Quote Originally Posted by RPMtech147 View Post
    Hey man glad to hear from someone that diy'd this job!! This is my 2nd summer without a/c in AZ so it sucks big time, I know TX is bad too. I've had the temp gauge in my car showing as much as 120F before when I was driving without a/c! But I gotta love how cool it looks to be driving such a nice car that has such a big problem not getting fixed. lol to be honest I could've taken it to a mechanic right away but I would rather do it myself, I've just been really busy and unable to find any good answers to a couple questions I have about diying the job.
    I wasn't sure it was even possible to diy because I read somewhere that it requires a special Audi tool to fill the new refrigerant and oil? Were you able to evac and fill the system with the typical vacuum pump and a/c manifold gauge setup? If so that is great news to me! That's the main thing I've been trying to find out and there's no diy specific to our cars, maybe if I can get some good advice from you I'll write up a diy...
    Also I'm not sure how to flush it all out without using the special Audi tools that they use in the elsa manual, how did you flush the system?
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    This is my 3rd summer without AC. But I'm in Canada so tolerable :)
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Aug 19 2012
    2002 Laser Red B5 S4 Avant 6MT
    Boston, MA
    Quote Originally Posted by Axel- View Post
    Yeah, I don't have working AC either. But with an '04 B6 with 186k miles, no way in hell I'm gonna bother shelling out 3k to fix it.
    I don't know if anything is broken or if an 'AC recharge' can would fix it. I asked a friend to recharge it but he said the can exploded and he gave up.
    Daily 2018 Subaru Impreza hatchback
    Previous: 2004 Brilliant Black B6 S4 Avant 6MT
    Jan 29 2010
    north ga
    ...You and me both Axel. I've had no A/C in hot-ass Georgia for the last 3 years
    Aug 07 2013
    ATL/GA
    Quote Originally Posted by devilbones View Post
    Old Republic, was brokered by SafeCo
    They have not been the easiest to deal with but this claim was flawless, Audi was even surprised they didn't send an inspector out, just paid.
    Cost me $100 deductible
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    That is within $100 of what it cost me to have done 3 years ago....but living in Fairfield County does not help.....I do 99.9% of the work myself but I know nothing about AC systems and did not want to personally risk taking out the new compressor if I did not do the job correctly so off she went to the garage. Our S4 is not our DD'er and gets used for mostly family vacations and road trips, having no AC on the highway is not something we could live with.
    I will say ever since the compressor was done the AC blows as cold as a '70's GM car.....for you youngons that means it is COLD....LOL.
    Cheers,
    Jim
    Senior Member Three Rings 98champ's Avatar
    Jun 30 2009
    '01 Silverado toy hauler, too many skis and a couple of wakeboards
    Amesbury, MA
    I'd love to do this with a $100 deductible, but at the price they paid all said and done I'll continue to sweat in traffic for the 3rd straight summer and more to come...
    His: 2005 Brilliant Black // Hers: 2009 A4 2.0T Brilliant Red
    Yellow Fogs / 6000k Headlights / Magnaflow Catback Exhaust / Hotchkis RS4 Sway Bars / Sterns End Links / JHM Short Shifter Trio / RS4 Shift Knob/E-Brake/Pedals / OEM 19" RS4 Wheels
    Nov 11 2010
    Rochester, MN
    How much did you pay for the original extended warranty? When I bought one with my first Audi(99.5 A4) I paid about $2,000. But that warranty paid off in spades to the tune of at least $6,000 over the years.
    19" B8 S5 Peelers
    Jun 21 2009
    OR
    Quote Originally Posted by BCsniper View Post
    I remember not having A/C in one of my previous cars in Texas... baby powder and towels were my friends... My condolences.
    Senior Member Two Rings viridia's Avatar
    Apr 13 2011
    ham best meat
    Quote Originally Posted by 2004B6S4 View Post
    I did mine about a month ago and can offer some insight here. Yes, it's a normal recharging procedure with manifold gauges and vacuum pump. The Harbor Freight set works great.
    The orifice valve's mesh screen was caked with metal on my car, so I purchased a good used compressor. Car needs to be in service position to install a new compressor. Also, the water pump and left engine mount/bracket need to be removed. Filled compressor with a couple ounces of PAG and turned over by hand before installing.
    Used a $50 eBay flush gun, air compressor, and acetone to flush the lines. Installed new o-rings, receiver drier, and orifice valve and buttoned it back up. Can't remember exactly what the charge is, somewhere between 12 and 20 oz (says on the underhood sticker though).
    87 4k, 90 f350, 91 v8, 93 v8, 04 s4, 0a3 transmission
    Aug 07 2013
    ATL/GA
    Quote Originally Posted by SlickFix View Post
    The warranty was $4,400 for coverage on everything for 4 years/110,000 miles. After I paid they cut it to 2 years/110,000 and refunded me 1,500ish but kept the coverage the same.
    When they found out it was a B6 S4 they must have said "Hail NO"
    With this service they have paid out roughly $4,300 total so far.
    Agreed on the cold as hell AC now..it'll freezer burn exposed skin!
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Nice... get that warranty to pay for everything it will now... lol
    Feb 18 2014
    Arizona
    Quote Originally Posted by viridia View Post
    Awesome, thank you a lot for that info! I'm gonna start ordering all the parts and tools I'll need now.
    I usually prefer to go with genuine parts for nearly everything, I'm pretty sure GAP loves me by now... or if I can find the same part from the same manufacturer but without the Audi box for a little cheaper I'll go with that, which I believe is what JHM has. But with the compressor I'm not sure I can stomach the enormous price difference between the GAP/JHM parts and the cheaper aftermarket brands at rockauto, I think the compressor alone is like a 3-4 hundred dollar difference iirc.
    Does anyone have any experience with a cheap new compressor that they can recommend? I don't think I want to risk a used one since it may not last long, considering the amount of labor and cost in redoing the job if it were to go out on me again right away
    Oct 27 2013
    New Jersey
    Check out r&y compressors out of Miami. They have remanufactured compressors for around 250$. Just put one on my car and it works fine. Also when I did the job I removed the front support and left the water pump on and removed the drivers side sub frame and motor mount.
    Feb 04 2013
    good info here. thx
    my ac is gonna need some work. blahhh... sometimes doesn't coolnow hearing rattling noises. goes away everytime i turn off the ac
    boring run of the mill stock b6 s4 avant
    May 18 2012
    MD, USA
    I'm about to do mine in my B6 S4. Just ordered all the parts. Please say a blessing for me! I will hopefully have some sort of writeup, but it depends on how much time I have.
    - B
    Established Member Two Rings Ritt's Avatar
    Feb 11 2013
    B6 S4
    NH
    Wow, I was going to say skip it... but I see you live in ATL so this is a must.
    Established Member Two Rings brandonrsx's Avatar
    Oct 27 2009
    04 B6 S4
    Yuma AZ
    Check ebay they have brand new ones for 335.00 just bought mine.
    2004 B6 S4 EVOMS CAI, Stasis SL, JHM f+r l/w rotors, HRE 441R's,235/35R-19 Bridgestone Potenza RE-11 XL
    , JHM L/w crank pulley, JHM clutch n flywheel, JHM catless long tube headers, JHM intake spacers, H&R sway bars, FI non res cat back Exhaust, CF interior trim, JHM TRIO package shifter, Apikol rear diff mount, Apikol snub mount, JHM TUNE
    Senior Member Two Rings blaelock's Avatar
    Sep 07 2013
    San Diego
    My AC compressor broke in my S4 and it was the last straw for me. Dealer quoted around $3,000 for the repair and the prices for the compressors elsewhere were quite expensive. And the labor for this job is quite involved. I ended up driving the car to Phoenix w/ no AC and trading it for my current M3.
    2012 BMW 135i Dinan S2
    1985 BMW 325e
    2003 Honda Civic EX
    2011 BMW 135i 6MT
    1999 BMW M3 - Techno Violet Metallic on Mulberry
    2005 B6 S4 quattro Sedan 6MT Light Silver Metallic on Ebony Recaro Leather
    2004 BMW E46 330i Bilstein/Eibach B12 Pro Plus Suspension & Sway Bars
    1986 BMW E28 535i
