Results 1 to 9 of 9
    Sep 09 2012
    Sweden
    uh oh... found my key in the washer and now it's dead :(
    Hi! Yesterday i found my key in the washer. So i dried it out and tried it. The key and starter chip works. But the wireless remote doesn't.
    I have 2 spare keys at home from another car. ( got them when i bought a used ccm )
    Can i configure one of the remotes to my car? And will i need vcds?
    Please help me.
    Senior Member Three Rings SaabtoAudi's Avatar
    Apr 30 2012
    Erie, Pa
    What about replacing the battery? Maybe checking to see if the battery connections are still on the board in the key fob?
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    you should be able to take one of your spare keys and swap over the internal circuit board on the key to the key that went thru the washer, just make sure you keep your immobilizer chip from your old key. Then just follow the door lock programming from one of the DIY's on here to reprogram the fob like this one...
    http://www.audizine.com/forum/showth...i-flip-key-fob
    Sep 09 2012
    Sweden
    I have already changed the battery and still not working :(
    That diy did not work for me? I'v heard that some b6s need vcds. Can i have one of them unicorn b6s?
    Jun 28 2014
    MA
    Quote Originally Posted by mkjn View Post
    I recently changed my battery and thought m FOB was dead... followed OG's advice and put the key in the ignition, turned the key to on (but did not start), then hit the lock button. Probably not the same issue as yours, but worth a try!
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    I have already changed the battery and still not working... That diy did not work for me?
    Last summer I walked into the Gulf of Mexico with my key in my pocket. The red panic button cover is missing from my fob, so... immediate salt water bath. Like OP, I was able to open the car and start the engine with the key. Remote was not functioning.
    By the next day it was working. This was after I disassembled the fob, removed the now-dead batteries, washed the salt out with clean water, let it dry overnight, put new batteries in and resynced using the procedure below.
    Remote Control Synchronization
    - Press any button on remote
    - Within 30 seconds, use KEY to lock and unlock
    - Insert key in ignition
    - Turn to ON
    - Remove key
    NOTE: I have no original source for the above procedure, but I found it posted on an Audi site. I've tried multiple procedures. This one works for my 2003.
    Jun 18 2014
    Rhode Island USA
    the chip that's really important in the key fob is the immobilizer; that's the one that tells the car that it should run. the remote function is the only one you can program yourself
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by ri_toast View Post
    I programmed my keys myself, immobilizer and all...
    Before you put a new battery in, did you take the key apart and make sure everything was dry? Also, you may need VCDS to get the FOBs to work, you may not. If you try the methods outlined above and they don't work, you'll need VCDS.
    Sep 09 2012
    Sweden
    Yes i make sure it was dry. And still not working and have searched for diffrent diy's and non of them are working. Maybe a good idea to buy vcds now
