For the matter at hand. I ordered two orings from ecs using a parts diagram I found on here. I pulled both stainless flexible oil return lines at the oil pan to clean and reseal. On the passenger side line, there is a groove that accepts the new oring (and there was an old oring upon removal). I noticed on the driver side, there was no oring on removal. If I place a new oring on the line, where it looks like it might go, the flange will not seat all the way to the pan. There seems to be no way this will seal properly. Any ideas?
This is with oring in place
What it looks like with it pulled out where I would expect the oring to fit
How it looks after pulled out first time and cleaned with no oring
It seats fully on my daily driver, like I would expect and how it was pulled out of the engine I'm building
Sneak Peak
