Results 1 to 11 of 11
    May 11 2013
    Nnj
    turbo to manifold bolts
    Do you use any type of loctite or anti seize on these bolts when installing. ?
    Veteran Member Four Rings RedB5S4's Avatar
    Dec 06 2010
    BfiveSfour
    I'd like to keep my car.
    No just tighten the balls out of them.
    Stg. III+ K24 CaS4
    May 11 2013
    Nnj
    Ok thank you.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    I use copper anti-seize on the bolts that hold the turbo to the exhaust manifold.
    Sep 11 2009
    NE
    copper antiseize as per factory manual to facilitate removal down the road. Otherwise they might really be hard to remove.
    May 16 2008
    WA
    loctite will likely just burn off, but I would put some sort of high temp anti-seize, because lets be honest, eventually you will want even more power (we always do) and will have to pull the turbos again for larger ones.
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by julex View Post
    Hard to remove?
    Jan 05 2008
    Sweden
    I did this to mine.
    Feb 21 2011
    WA
    Quote Originally Posted by FreddeS4 View Post
    I did this to mine.
    That's amazing.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Not an 2.7T, but what I did to my 1.8T with FrankenTurbo:
    This was only my 3rd time safety-wiring, so please don't judge harshly! On the bright-side there haven't been any problems with it.
    Also haven't had any problems with the turbo bolts since using 034's high-temp antiseize. That stuff works wonders. Previously I had a bolt break off in the turbo, and nobody likes that.
    2001 Corvette (C5) Z06
    Jan 05 2008
    Sweden
    Quote Originally Posted by waB5S4 View Post
    That's amazing.
    Works like a charm!
