Results 1 to 19 of 19
    Jun 17 2014
    A/C suddenly stopped working
    2013 S4 5500k miles
    So I was leaving work the other day and it was bloody hot out so naturally I fire up the AC, but after 5 mins or so I notice it's still blowing out warm air. The AC button stays lit but no cold air. Does anyone know what this could be, or if it's a common issue? It's under warranty so it's not a big deal but I was just looking for some insight before going to the dealer
    Thanks
    Mar 31 2014
    2013 Porsche Cayenne Turbo
    How does your car have so few miles on it after 2 years?
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    I do. Sux to be you thats what lol. No i don't know. But start the car turn on the A/C and open the hood and see if you can see if the A/C compressor clutch engages and the compressor is spinning. Their is a plate on the front of the the compressor in front of the pulley and only spins when the clutch is engaged If the Clutch is engaged with the pulley the problem can be one of 2 things either the blendoor isn't working right but thats unlikely since their are 3 of them in the car. The other thing is that the compressor shaft broke.
    but if the compressor isn't engaging at all it probably an electrical problem somewhere or you lost all the freeon and have a leak somewhere
    Jul 14 2013
    British Columbia, Canada
    do you have it to the setting where its pulling fresh air or is it recirculating? My car had the same issue and I changed it to recirculate and cold air began to flow.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Had the same thing happen to my A6. My car however, was idling with the AC turned on max. It was explained to me that the unit can freeze up if not moving. After about 5 minutes worth of driving (not stop and go), it started blowing cold air again.
    2013 Ibis White S4||P+||DSG||Sport Diff||B&O||Black-Chestnut Interior|| Unitronic Stage II+ & TCU Stage II||Luft-Technik Intake||20% Tint || KW H.A.S. Kit||TSW Bathurst ||Magnaflow res X-pipe||Copious amounts of Xpel| PIAA Plasma Ion Yellow Fogs||ECS 2-Piece Wave Rotors
    Oct 20 2008
    Denver
    Quote Originally Posted by Laxinthe303 View Post
    my thoughts exactly
    Jun 17 2014
    I gave it a solid 15 mins while driving and it was a no go, it used to blow cold without recirculate on but I'll try that after work.
    Jun 17 2014
    I've only had it for about a month someone traded it in. No idea how the previous owner barely drove it but the car was flawless inside and out
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    Quote Originally Posted by Mark_S4 View Post
    2013 S4 5500k miles
    Thanks
    My car did the exact same thing 3 years ago...just stopped cooling. Fans and all other aspects were operational.
    It surprisingly came back on the next day...no issues identified by the dealer.
    However, this all happened in the first week after my tune...so may have been an adaptation issue.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Jul 14 2013
    It should blow cold air without recirculate but for some reason i had to turn it on and then wait a minute and turn it off, after that it was fine. It hasn't happened since. I would ask your dealer anyway as thats what Im going to do just to put it on their radar.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Could be so many things... You can pop the hood and listen for the AC compressor to engage/disengage when you turn the AC on and off. Could be a blown fuse as well...
    Either way there is no reason on earth why your AC should not be running with so few miles. Unless you got in an accident and they didnt repair your car properly.
    Jun 17 2014
    No accidents, I'll give the suggestions here a try and report back when I know what the deal is
    Jan 31 2014
    Austin, TX
    I had same thing happen a few months ago on mine, 2013 with 12.5k on it. Took it to dealer, AC sensor or something, whatever it was they fixed it in a few hours and it was under warranty. Maybe it's the same issue.
    2013 S4 Glacier White Prestige | DSG | B&O | ADS/Sports Rear Diff | AWE Exhaust | Roc-Euro Intake | H&R OE Sport Springs | Alu Kreuz | Eurocode F&R Sway Bars | Eurocode F&R Endlinks | Black RS4 Grille | 19x9.5 VMR V710 Gunmetal | Michelin Super Sports
    Jan 14 2009
    pasadena md
    You shouldn't need recirc with these cars unless its above 95 and sitting in stop and go traffic. I never use recirc in any of my audi's since the a/c uses a TXV system and is very efficient and doesn't need recirc all that often. The freezing up happens sometimes but shouldn't happen all the time. I can see it happening on very humid days and such. But the system should prevent that from happening.
    May 27 2013
    West Chester, PA
    Quote Originally Posted by 408Tyler View Post
    Could be a low or high pressure switch, if that goes out the car wont run the compressor to prevent damage.
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    X2
    Jun 17 2014
    In case anyone was wondering, took the car in today and it was the AC Pressure Sensor that was faulty. It's running well again now
    Jun 13 2009
    when it happened to me...my ADS switch did not work as well.
    anyone else notice this?
    2023 Q5 2.0 Technik
    Veteran Member Three Rings Amorphic's Avatar
    Jun 05 2009
    2013 A4 2.0T Premium 6MT
    BC, Canada
    I think there was a TSB for this on the A4 as well. I had something fixed on my last service under warranty.
    2015 Subaru WRX STi | Limited | Dark Grey Metallic | Sport Tech | Xpel Ultimate
    Sold -2013 Audi A4 2.0T | Premium | 6 MT | Brilliant Black | Xpel Ultimate | Tint: 35% Front 20% Rear
