Results 1 to 17 of 17
    Jun 23 2013
    PacNW
    A4 and Allroad OEM Suspension Reference
    I've done a bit of reading on Audi suspensions and am sharing some general info here and also a more specific comparison of 2012 A4 and 2013 A4 Allroad suspensions.
    ----- General Info - All Audi Suspensions ------
    Audi uses different model codes for their several suspension lines:
    1BA = Standard suspension/shock absorption (normal A4)
    1BE = Sports suspension/shock absorption (sport suspension A4 including USA S-line)
    1BD = Suspension/shock absorption for special sports design (for S4,5 etc.)
    1BV = Sports suspension/shock absorption (for RS cars by Quattro GmbH and European S-line)
    1BL = Suspension/shock absorption - closed-loop (This is ADS)
    1BP = Suspension/shock absorption for special rough-road design (used on B8 Allroad)
    1BR = Comfort rough-road suspension
    To find the right suspension parts you need both the 'model code' above and the weight codes both front and rear.
    Audi has up to a dozen different weight codes per suspension line.
    For example, on stock suspension, a 3.2 A4 will have a different front weight code than a 2.0T A4.
    Likewise an Avant will have a different rear weight code than a sedan all else being equal.
    Audi takes your total vehicle weight into consideration so small changes like options (Navigation, B&O stereo...) can bump you up to the next weight category.
    Weight categories are shown by a code on the options sticker for each car.
    (Options sticker is on the inside cover of your "Warranty & Maintenance" book in your owners manual, and/or in the spare wheel well)
    0Y* is the rear weight code
    0J* is the front weight code
    (The * will be a letter not a number)
    Usually there are different springs for each weight codes (some are shared between model lines so for example 1BE, 1BL, 1BD may share).
    For each suspension line there are 1-3 different shock absorbers which each fit multiple weight codes.
    The springs have paint codes on them which indicate the part# and weight code.
    The shock absorbers have the full part number on a sticker on the shock body.
    The hard part is decoding what the weight codes mean.
    It seems that from B6 platform onward, the same weight code always corresponds to the same weight class (ie, comparing 1BE to 1BA -- unverified!)
    The part numbers change after some build dates listed in the parts catalog.
    The format "01.01.2000>>" means "after Jan 1 2000"
    The format ">> - 01.01.2000" means "before Jan 1 2000"
    ----- 2012 A4 and 2013 A4 Allroad Specific -----
    Below are the part numbers and importantly the weight codes and spring color markings for 2012 A4 and 2013 A4 Allroad.
    The diagram is identical for the 2 models.
    Jun 23 2013
    PacNW
    Front:
    Rear:
    Jun 23 2013
    PacNW
    2012 A4 Quattro Suspension - Front:
    POS ARTICLE DESCRIPTION REMARK QTY MODEL
    coil spring front PR-1BA
    1 8K0411105DB coil spring
    1 paint mark
    3 paint marks
    orange
    grey
    2 PR-0JC
    (1) 8K0411105DC coil spring
    1 paint mark
    2 paint marks
    orange
    pink
    2 PR-0JD
    (1) 8K0411105DD coil spring
    1 paint mark
    3 paint marks
    orange
    pink
    2 PR-0JE
    (1) 8K0411105DE coil spring
    3 paint marks
    orange 2 PR-0JF
    (1) 8K0411105DF coil spring
    4 colour strokes
    orange 2 PR-0JG
    (1) 8K0411105DG coil spring
    1 paint mark
    1 paint mark
    orange
    violet
    2 PR-0JH
    (1) 8K0411105DH coil spring
    1 paint mark
    2 paint marks
    orange
    violet
    2 PR-0JJ
    (1) 8K0411105DJ coil spring
    1 paint mark
    3 paint marks
    orange
    violet
    2 PR-0JK
    (1) 8K0411105DK coil spring
    1 paint mark
    1 paint mark
    orange
    white
    2 PR-0JL
    (1) 8K0411105DL coil spring
    1 paint mark
    2 paint marks
    orange
    white
    2 PR-0JM
    (1) 8K0411105DM coil spring
    1 paint mark
    3 paint marks
    orange
    white
    2 PR-0JN
    (1) 8K0411105DN coil spring
    1 paint mark
    1 paint mark
    orange
    yellow
    2 PR-0JP
    (1) 8K0411105DP coil spring
    1 paint mark
    2 paint marks
    orange
    yellow
    2 PR-0JQ
    (1) 8K0411105DQ coil spring
    1 paint mark
    3 paint marks
    orange
    yellow
    2 PR-0JR
    coil spring
    for vehicles with sports
    suspension
    front PR-1BE,1BD
    1 8K0411105DR coil spring
    1 paint mark
    violet 2 PR-0JB
    (1) 8K0411105DS coil spring
    1 paint mark
    2 paint marks
    violet
    grey
    2 PR-0JC
    (1) 8K0411105DT coil spring
    1 paint mark
    3 paint marks
    violet
    grey
    2 PR-0JD
    (1) 8K0411105EA coil spring
    1 paint mark
    2 paint marks
    violet
    pink
    2 PR-0JE
    (1) 8K0411105EB coil spring
    1 paint mark
    3 paint marks
    violet
    pink
    2 PR-0JF
    (1) 8K0411105EC coil spring
    1 paint mark
    2 paint marks
    violet
    orange
    2 PR-0JG
    (1) 8K0411105ED coil spring
    1 paint mark
    3 paint marks
    violet
    orange
    2 PR-0JH
    (1) 8K0411105EE coil spring
    2 paint marks
    violet 2 PR-0JJ
    (1) 8K0411105EF coil spring
    3 paint marks
    violet 2 PR-0JK
    (1) 8K0411105EG coil spring
    4 colour strokes
    violet 2 PR-0JL
    (1) 8K0411105EH coil spring
    1 paint mark
    1 paint mark
    violet
    white
    2 PR-0JM
    (1) 8K0411105EJ coil spring
    1 paint mark
    2 paint marks
    violet
    white
    2 PR-0JN
    (1) 8K0411105EK coil spring
    1 paint mark
    3 paint marks
    violet
    white
    2 PR-0JP
    (1) 8K0411105EL coil spring
    1 paint mark
    1 paint mark
    violet
    blue
    2 PR-0JQ
    coil spring
    for vehicles with electron-
    ically controlled damping
    D >> - 02.11.2009
    front PR-1BL
    (1) 8K0411105DR coil spring
    1 paint mark
    violet 2 PR-0JB
    1 paint mark
    2 paint marks
    violet
    grey
    2 PR-0JC
    1 paint mark
    3 paint marks
    violet
    grey
    2 PR-0JD
    1 paint mark
    2 paint marks
    violet
    pink
    2 PR-0JE
    1 paint mark
    3 paint marks
    violet
    pink
    2 PR-0JF
    1 paint mark
    2 paint marks
    violet
    orange
    2 PR-0JG
    1 paint mark
    3 paint marks
    violet
    orange
    2 PR-0JH
    2 paint marks
    violet 2 PR-0JJ
    3 paint marks
    violet 2 PR-0JK
    4 colour strokes
    violet 2 PR-0JL
    1 paint mark
    1 paint mark
    violet
    white
    2 PR-0JM
    1 paint mark
    2 paint marks
    violet
    white
    2 PR-0JN
    1 paint mark
    3 paint marks
    violet
    white
    2 PR-0JP
    1 paint mark
    1 paint mark
    violet
    blue
    2 PR-0JQ
    coil spring
    D - 02.11.2009>>
    front PR-1BL
    (1) 8K0411105FJ coil spring
    1 paint mark
    1 paint mark
    1 paint mark
    yellow
    violet
    green
    2 PR-0JC
    1 paint mark
    violet 2 PR-0JD
    1 paint mark
    2 paint marks
    violet
    grey
    2 PR-0JE
    1 paint mark
    3 paint marks
    violet
    grey
    2 PR-0JF
    1 paint mark
    2 paint marks
    violet
    pink
    2 PR-0JG
    1 paint mark
    3 paint marks
    violet
    pink
    2 PR-0JH
    1 paint mark
    2 paint marks
    violet
    orange
    2 PR-0JJ
    1 paint mark
    3 paint marks
    violet
    orange
    2 PR-0JK
    shock absorbers
    individual parts
    front
    2 N10106402 hexagon collar nut
    self-locking
    M12X1,5 2
    3 8K0412377C mounting upper 2 PR-1BA,1BE
    (3) 8K0412377D mounting upper 2 PR-1BL
    4 WHT001484 washer 12,1X20X4 2
    5 8K0412391F bracket left 1
    (5) 8K0412392F bracket right 1
    6 8K0412131E rubber stop for
    shock absorber
    81MM 2 PR-1BA
    (6) 8K0412131F rubber stop for
    shock absorber
    72MM 2 PR-1BE
    (6) 8K0412131G rubber stop for
    shock absorber
    D >> - 02.11.2009
    66MM 2 PR-1BL
    (6) 8F0412131 rubber stop for
    shock absorber
    D - 02.11.2009>>
    77MM 2 PR-1BL
    7 8K0412137A protective sleeve front 2
    8 8K0412127 protective cap 2
    (8) 8K0412127A protective cap 2
    9 8K0412109A underlay 4
    10 8K0412103C spring disc lower 2
    11 8K0413031AE gas shock absorber
    ***** caution hazardous ******
    SACHS 2 PR-1BA+0JB,
    0JC,0JD,0JE,
    0JF
    (11) 8K0413031CG gas shock absorber
    TENNECO MONROE 2 PR-1BA+0JB,
    0JC,0JD,0JE,
    0JF
    (11) 8K0413031AL gas shock absorber
    VWBS 2 PR-1BA+0JB,
    0JC,0JD,0JE,
    0JF
    (11) 8K0413031BF gas shock absorber
    0JC,0JD,0JE,
    0JF
    (11) 8K0413031CH gas shock absorber
    (use in pairs only)
    TENNECO MONROE 2 PR-1BA+0JG,
    0JH,0JJ,0JK,
    0JL,0JM,0JN,
    0JP,0JQ,0JR
    (11) 8K0413031BA gas shock absorber
    SACHS 2 PR-1BD
    (11) 8T0413031AE gas shock absorber
    (use in pairs only)
    SACHS 2 PR-1BE+0JB,
    0JC,0JD
    (11) 8T0413031AF gas shock absorber
    (use in pairs only)
    SACHS 2 PR-1BE+0JE,
    0JF,0JG,0JH,
    0JJ,0JK,0JL,
    0JM,0JN,0JP
    (11) 8K0413029N shock absorbers
    D >>*- 02.11.2009*
    left
    1
    PR-1BL
    (11) 8F0413029 shock absorbers
    D - 02.11.2009>>*
    left
    1
    PR-1BL
    (11) 8K0413030N shock absorbers
    D >>*- 02.11.2009*
    right
    1
    PR-1BL
    (11) 8F0413030 shock absorbers
    D - 02.11.2009>>*
    right
    1
    PR-1BL
    12 N10421304 hexagon head bolt (combi) M12X1,5X80 2
    13 N10106402 hexagon collar nut
    self-locking
    M12X1,5 2
    14 suspension forks
    see illustration:
    407-00
    Jun 23 2013
    PacNW
    2012 A4 Quattro Suspension - Rear:
    1 8K0511539E stone chip guard left 1
    (1) 8K0511540E stone chip guard right 1
    2 wheel bearing housing
    see illustration:
    505-21 fr.wheel drv
    (2) wheel bearing housing
    see illustration:
    505-10 quattro
    3 8K0512297C spring support lower 2
    4 8K0512149C spring support upper 2 PR-1BA,1BD,
    1BE,1BV
    (4) 8K0512141G spring support upper
    13 MM
    2 PR-1BR,1BL
    5 8K0511115DB coil spring
    1 paint mark
    grey 2 PR-1BA+0YD
    (5) 8K0511115DC coil spring
    2 paint marks
    grey 2 PR-1BA+0YE
    (5) 8K0511115DD coil spring
    3 paint marks
    grey 2 PR-1BA+0YF
    (5) 8K0511115DE coil spring
    4 colour strokes
    grey 2 PR-1BA+0YG
    (5) 8K0511115DF coil spring
    1 paint mark
    1 paint mark
    grey
    pink
    2 PR-1BA+0YH
    (5) 8K0511115DG coil spring
    1 paint mark
    2 paint marks
    grey
    pink
    2 PR-1BA+0YJ
    (5) 8K0511115DH coil spring
    1 paint mark
    3 paint marks
    grey
    pink
    2 PR-1BA+0YK
    (5) 8K0511115DJ coil spring
    1 paint mark
    1 paint mark
    grey
    green
    2 PR-1BA+0YL
    (5) 8K0511115DK coil spring
    1 paint mark
    2 paint marks
    grey
    green
    2 PR-1BA+0YM
    (5) 8K0511115DL coil spring
    1 paint mark
    3 paint marks
    grey
    green
    2 PR-1BA+0YN
    (5) 8K0511115DM coil spring
    1 paint mark
    1 paint mark
    grey
    orange
    2 PR-1BA+0YP
    (5) 8K0511115DN coil spring
    1 paint mark
    2 paint marks
    grey
    orange
    2 PR-1BA+0YQ
    (5) 8K0511115DP coil spring
    1 paint mark
    3 paint marks
    grey
    orange
    2 PR-1BA+0YR
    (5) 8K0511115GP coil spring
    1 paint mark
    1 paint mark
    1 paint mark
    D - 30.06.2008>>*
    rear
    green
    grey
    violet
    2
    PR-1BE,0YD
    (5) 8K0511115GQ coil spring
    1 paint mark
    1 paint mark
    2 paint marks
    D - 30.06.2008>>*
    green
    grey
    violet
    2
    PR-1BE+0YE
    (5) 8K0511115GR coil spring
    1 paint mark
    1 paint mark
    3 paint marks
    green
    grey
    violet
    2 PR-1BE+0YF
    (5) 8K0511115GS coil spring
    1 paint mark
    1 paint mark
    1 paint mark
    green
    grey
    white
    2 PR-1BE+0YG
    (5) 8K0511115GT coil spring
    1 paint mark
    1 paint mark
    2 paint marks
    green
    grey
    white
    2 PR-1BE+0YH
    (5) 8K0511115HA coil spring
    1 paint mark
    1 paint mark
    3 paint marks
    rear
    green
    grey
    white
    2 PR-1BE+0YJ
    (5) 8K0511115HB coil spring
    1 paint mark
    1 paint mark
    1 paint mark
    green
    grey
    blue
    2 PR-1BE,1BL+
    0YK
    (5) 8K0511115HC coil spring
    1 paint mark
    1 paint mark
    2 paint marks
    green
    grey
    blue
    2 PR-1BE,1BL+
    0YL
    (5) 8K0511115HD coil spring
    1 paint mark
    1 paint mark
    3 paint marks
    green
    grey
    blue
    2 PR-1BE+0YM
    (5) 8K0511115HE coil spring
    1 paint mark
    1 paint mark
    1 paint mark
    green
    grey
    brown
    2 PR-1BE+0YN
    (5) 8K0511115FB coil spring
    1 paint mark
    1 paint mark
    2 paint marks
    D >> - 30.06.2008*
    yellow
    grey
    brown
    2
    PR-1BD,1BE,
    1BL,1BV+0YP
    (5) 8K0511115HF coil spring
    1 paint mark
    1 paint mark
    2 paint marks
    D - 30.06.2008>>*
    green
    grey
    brown
    2
    PR-1BE+0YP
    (5) 8K0511115HG coil spring
    1 paint mark
    1 paint mark
    3 paint marks
    D - 30.06.2008>>*
    green
    grey
    brown
    2
    PR-1BE+0YQ
    (5) 8K0511115FD coil spring
    1 paint mark
    1 paint mark
    2 paint marks
    D >> - 30.06.2008*
    yellow
    pink
    orange
    2
    PR-1BD,1BE,
    1BL,1BV+0YR
    (5) 8K0511115HH coil spring
    1 paint mark
    1 paint mark
    2 paint marks
    D - 30.06.2008>>*
    green
    pink
    orange
    2
    PR-1BE+0YR
    1 paint mark
    1 paint mark
    1 paint mark
    D >> - 02.11.2009
    rear
    green
    grey
    violet
    2 PR-1BL+0YD
    (5) 8K0511115HN coil spring
    2 paint marks
    2 paint marks
    D - 02.11.2009>>
    rear
    white
    brown
    2
    1 paint mark
    1 paint mark
    2 paint marks
    D >> - 02.11.2009
    rear
    green
    grey
    violet
    2 PR-1BL+0YE
    (5) 8K0511115HP coil spring
    2 paint marks
    2 paint marks
    D - 02.11.2009>>
    rear
    blue
    brown
    2
    1 paint mark
    1 paint mark
    3 paint marks
    D >> - 02.11.2009
    rear
    green
    grey
    violet
    2 PR-1BL+0YF
    1 paint mark
    1 paint mark
    1 paint mark
    D - 02.11.2009>>
    rear
    green
    grey
    violet
    2 PR-1BL+0YF
    1 paint mark
    1 paint mark
    1 paint mark
    D >> - 02.11.2009
    rear
    green
    grey
    white
    2 PR-1BL+0YG
    1 paint mark
    1 paint mark
    2 paint marks
    D - 02.11.2009>>
    rear
    green
    grey
    violet
    2 PR-1BL+0YG
    1 paint mark
    1 paint mark
    2 paint marks
    D >> - 02.11.2009
    rear
    green
    grey
    white
    2 PR-1BL+0YH
    1 paint mark
    1 paint mark
    3 paint marks
    D - 02.11.2009>>
    rear
    green
    grey
    violet
    2 PR-1BL+0YH
    1 paint mark
    1 FARBSTRICHE
    3FARBSTRICHE
    D >> - 02.11.2009
    rear
    green
    grey
    white
    2 PR-1BL+0YJ
    1 paint mark
    1 paint mark
    1 paint mark
    D - 02.11.2009>>
    rear
    green
    grey
    white
    2 PR-1BL+0YJ
    1 paint mark
    1 paint mark
    1 paint mark
    D >> - 02.11.2009
    rear
    green
    grey
    blue
    2 PR-1BL+0YK
    1 paint mark
    1 paint mark
    2 paint marks
    D - 02.11.2009>>
    rear
    green
    grey
    white
    2 PR-1BL+0YK
    1 paint mark
    1 paint mark
    2 paint marks
    D >> - 02.11.2009
    rear
    green
    grey
    blue
    2 PR-1BL+0YL
    1 paint mark
    1 FARBSTRICHE
    3FARBSTRICHE
    D - 02.11.2009>>
    rear
    green
    grey
    white
    2 PR-1BL+0YL
    1 paint mark
    1 paint mark
    3 paint marks
    D >> - 02.11.2009
    rear
    green
    grey
    blue
    2 PR-1BL+0YM
    1 paint mark
    1 paint mark
    1 paint mark
    D - 02.11.2009>>
    rear
    green
    grey
    blue
    2 PR-1BL+0YM
    1 paint mark
    1 paint mark
    1 paint mark
    rear
    green
    grey
    brown
    2 PR-1BL+0YN
    1 paint mark
    1 paint mark
    2 paint marks
    rear
    green
    grey
    brown
    2 PR-1BL+0YP
    1 paint mark
    1 paint mark
    3 paint marks
    rear
    green
    grey
    brown
    2 PR-1BL+0YQ
    1 paint mark
    1 paint mark
    2 paint marks
    rear
    green
    pink
    orange
    2 PR-1BL+0YR
    6 8K0513035K gas shock absorber ZF SACHS 2 PR-1BA
    (6) 8K0513035AJ gas shock absorber MONROE 2 PR-1BA
    (6) 8T0513035M gas shock absorber 2 PR-1BE
    (6) 8K0513025J gas shock absorber
    D >> - 02.11.2009
    left 1 PR-1BL
    (6) 8K0513026J gas shock absorber
    D >> - 02.11.2009
    right 1 PR-1BL
    (6) 8F0513025 gas shock absorber
    D - 02.11.2009>>
    left 1 PR-1BL
    (6) 8F0513026 gas shock absorber
    D - 02.11.2009>>
    right 1 PR-1BL
    (6) 8K0513035AB gas shock absorber 2 PR-1BD
    7 8E0512137E protective sleeve 2 PR-1BA,1BE
    (7) 8K0512137A protective sleeve 2 PR-1BL
    8 8K0512131 stop buffer 2 PR-1BA
    (8) 8K0512131B stop buffer 2 PR-1BE
    (8) 8K0512131D stop buffer
    D >> - 01.06.2009*
    2 PR-1BL
    D - 01.06.2009>>*
    2 PR-1BV
    (8) 8F0512131E stop buffer
    D - 01.06.2009>>*
    2 PR-1BL
    9 8K0513353E shock absorber bearing upper 2
    10 N10286110 hexagon collar nut
    self-locking
    M10 2
    11 WHT002389 washer 34X34X4 2
    12 N10500802 bolt, hex. hd. with shoulder,
    self-locking
    M14X1,5X90 2
    13 N91066101 hexagon head bolt (combi) M10X35 4
    (14) 8K0511305K anti-roll bar
    D >> - 30.05.2011
    19,6MM 1 PR-1BA
    (14) 8K0511305AE anti-roll bar
    D - 30.05.2011>>
    19,6MM 1 PR-1BA
    (14) 8K0511305AB anti-roll bar 21,7MM 1
    1
    1
    PR-1BD,1BE,
    1BV+1SH,1SJ,
    1SA
    D >> - 14.11.2009
    21,7MM 1 1PR-1BL
    (14) 8K0511305T anti-roll bar
    D - 14.11.2009>>
    16MM 1 PR-1BL
    17 N10644701 socket head collared bolt with
    inner multipoint head
    M8X30 4
    18 8K0505465G coupling rod 2
    19 N90997802 hex collared bolt M10X65 2
    20 N10272302 hexagon collar nut
    self-locking
    M10 2
    21 N90997802 hex collared bolt M10X65 2
    22 8K0511533 stone chip guard 2
    23 8K0512135 protective cap 2
    24 1J0906102 grommet 8,2X40 1 PR-1BL
    25 1J0973802 flat connector housing with
    contact locking mechanism
    2 pin
    black
    1 PR-1BL
    30 DA001730A2 2-pack epoxy adhesive 50ml 1
    Jun 23 2013
    PacNW
    2013 Allroad Suspension - Front:
    1 paint mark
    3 paint marks
    orange
    grey
    2 PR-0JB
    1 paint mark
    2 paint marks
    orange
    pink
    2 PR-0JC
    1 paint mark
    3 paint marks
    orange
    pink
    2 PR-0JD
    3 paint marks
    orange 2 PR-0JE
    4 colour strokes
    orange 2 PR-0JF
    1 paint mark
    1 paint mark
    orange
    violet
    2 PR-0JG
    1 paint mark
    2 paint marks
    orange
    violet
    2 PR-0JH
    1 paint mark
    3 paint marks
    orange
    violet
    2 PR-0JJ
    1 paint mark
    1 paint mark
    orange
    white
    2 PR-0JK
    1 paint mark
    2 paint marks
    orange
    white
    2 PR-0JL
    1 paint mark
    3 paint marks
    orange
    white
    2 PR-0JM
    1 paint mark
    1 paint mark
    orange
    yellow
    2 PR-0JN
    1 paint mark
    2 paint marks
    orange
    yellow
    2 PR-0JP
    1 paint mark
    3 paint marks
    orange
    yellow
    2 PR-0JQ
    individual parts
    shock absorbers
    front
    self-locking
    M12X1,5 2
    shock absorber
    81MM 2
    7 8K0412137A protective sleeve 2
    9 8K0412109A underlay 2
    11 8K0413031BB gas shock absorber
    MONROE 2 PR-0JB,0JC,
    0JD,0JE,0JF,
    0JG,0JH
    (11) 8K0413031BC gas shock absorber
    MONROE 2 PR-0JJ,0JK,
    0JL,0JM,0JN,
    0JP,0JQ
    self-locking
    M12X1,5 2
    14 suspension forks
    <p>see illustration:</p>
    407-00
    Jun 23 2013
    PacNW
    2013 Allroad Suspension - Rear:
    see illustration:
    505-10 1
    4 8K0512149C spring support 2
    5 8K0511115FK coil spring
    1 paint mark
    3 paint marks
    rear
    brown
    violet
    2 PR-1BP+0YH
    (5) 8K0511115FL coil spring
    1 paint mark
    2 paint marks
    rear
    brown
    white
    2 PR-1BP+0YJ
    (5) 8K0511115FM coil spring
    1 paint mark
    3 paint marks
    rear
    brown
    white
    2 PR-1BP+0YK
    (5) 8K0511115FN coil spring
    1 paint mark
    2 paint marks
    rear
    brown
    blue
    2 PR-1BP+0YL
    (5) 8K0511115FP coil spring
    1 paint mark
    3 paint marks
    rear
    brown
    blue
    2 PR-1BP+0YM
    (5) 8K0511115FQ coil spring
    2 paint marks
    rear
    brown
    2 PR-1BP+0YN
    (5) 8K0511115FR coil spring
    3 paint marks
    rear
    brown
    2 PR-1BP+0YP
    6 8K0513035AC gas shock absorber rear 2
    7 4B0512137B protective sleeve 2
    10 N10295101 hexagon nut, self-locking M10 2
    self-locking
    M14X1,5X90 2
    14 8K0511305K anti-roll bar 19,6MM 1
    M8X30 4
    self-locking
    M10 2
    Jun 23 2013
    PacNW
    * Reserved *
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    Nice, thanks for sharing!
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    Jul 16 2008
    Finland
    Nice guide! 1BE is the standard -20mm sport suspension and 1BV is the S-line / Quattro Gmbh -30mm suspension.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Established Member Two Rings billybob_lee's Avatar
    Apr 19 2013
    2006 Lexus SC430, 2014 Toyota Highlander Hybrid Limited
    Huntington Beach, CA
    This is fantastic! I'm bookmarking this. Thanks for putting it all together for us!
    2013 allroad, Premium Plus, Glacier White Metalic w/full paint finish - Gone
    2014 allroad, Premium Plus, Phantom Black Pearl
    MMI Plus w/Nav | Sport Interior | Advanced Key | B&O | VMR V706 w/Michelin Pilot Sport A/S 3 (255/40-19)
    OEM RS5 Pedals, UV Privacy Sunshades, WeatherTech, Canvasback, OEM Warning Triangle, OEM A8 Leather OM Wallet, VAG-Com
    Jun 23 2013
    PacNW
    Glad it's useful!
    Quote Originally Posted by TDIaholic View Post
    In the USA Market, S-line is a package option for B8 A4 Prestige cars. Is the terminology different in Europe?
    USA S-line package on the B8 A4 adds the "sport suspension" which is the same suspension that is offered with the "sport package" on Prem+ models, and is -20mm.
    I think what you mean is the 1BV -30mm suspension is for RS/ Quattro Gmbh cars.
    I believe 1BD suspension for the S4 is also -30mm.
    Jul 16 2008
    Finland
    Quote Originally Posted by skis4hire View Post
    Over here in Europe if you order the full S-line package you get the 1BV suspension, so I guess there is a small difference as to witch package comes with witch trim level. We don't have Prestige, Premium, etc. just different packages. For example, if you order the sports package you get cloth upholstered sport seats, a 3-spoke steering wheel and the 1BE suspension.
    1BD should also be just -20mm.
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Finally found this thread - remembered it from awhile ago, from the Audi springs color coding craziness.
    I have an '09 3.2L P+ sedan - was with standard suspension 1BA rear weight code OYK front weight code OJJ, . I'm original owner since 7/09.
    I had KW V1 coil overs installed about 7/10 - never been happy with the harsh ride and would like to convert my suspension to 1BE (N/A S-Line Sport), 1BD (S4) or 1BV (Euro S-Line).
    IIRC difference between N/A S-Line and Euro S-Line is 20mm v. 30mm drop from standard - I'd prefer 30mm drop - unsure if S4 springs/shocks would work.
    BTW I have 19" rims - from OEM 17" rims.
    Can you possibly provide the spring and shock P/Ns and color codes for these possible setups?
    Any input from other members would be appreciated.
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    May 25 2011
    Norway
    Does anyone have experience with using springs from a lower weight code to make the car sit a little lower?
    I want to bring down the nose of my PR-0JF weight code 1BE suspension B8 TFSIq Avant a little, but I like the OEM ride quality.
    Using the info above, I could easily order springs for PR-0JE or even PR-0JD weight classes - but is there anyone who has tried this that can comment on what difference this would make?
    Quote Originally Posted by Greg Nelson View Post
    Look up your weight code in the lists above, you can easily find part# for 1BE with the correct weight codes there.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by kvitrafn View Post
    Difference is only like 30kg, so i guess you dont feel or see any real change!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    May 25 2011
    Norway
    That small a difference, huh. Is there a list of front axle weights and suspension ratings somewhere?
    Jul 30 2020
    Littleton
    Adding and reviving this very helpful post to:
    1) Add the code and weight rating chart from here: https://www.audizine.com/forum/attac...9&d=1568297541
    2) See what experiences anyone has had going with lower weight ratings? I have a '12 Avant Prestige with OJF and OYK setup and I'm wondering if going down the -2/front and -1/rear as others have suggested may drop is a small amount, say 5mm.
