Required:
- Torx 30 screwdriver
- Angled needle nose pilers
- Flathead screwdriver
I picked up the PCV from Europaparts.com (http://www.europaparts.com/pressure-...6h103495e.html). Make sure whomever you're buying it from, you get a VIN# check to see which unit you need.
I choose to use a screwdriver over a socket bit since you're screwing the bolts in to metal, it's more controlling.
Step 1: Remove plastic engine cover. Locate the bolt that holds the coil pack harness and remove it. Make sure you set the bolt aside and not get it mixed up with the other bolts.
Step 2: Using a flathead, gently clip out the 4 connectors to your coilpacks. Make sure you hear a click and pull them away slowly. There's not much room for the harness to move and it will probably just sit on top of your coils.
Step 3: Locate the intake tube to the PCV unit. Using your fingers, press down on the top and bottom part (it's raised and has a notched surface) of the clip and pull the intake tube out. You can rotate it to the right and get it out of the way. Make sure you cover the opening with a towel or glove.
Step 4: Locate the torx bolt that holds the breather tube and remove it. Also, set this aside from all other bolts to not mix it up.
Step 5: Gently, lift up on the coil pack harness and slide out the intake from the breather tube. It's a flat rectangle shape and should slide right out from the PCV. Also, slide out the two coilpacks as you need to access the torx bolts to the PCV.
Breather tube looks like this,
Step 6: Remove all 9 bolts that hold the PCV assembly in place. Use the needle nose pilers to get the ones out from the back.
Step 7: Lift PCV out and replace with new unit. If have left over oil anywhere, take some and LIGHTLY grease the new seal. Just like you would when replacing an oil filter.
Reinstall all bolts to the PCV.
Attach breather tube, screw back in bolt. Attach PCV intake tube.
Install your two coil packs back in. Clip your coil pack harness back in.
Reinstall coil pack harness bolt and engine cover.
Should take anyone from 30-45mins. Pretty simple and straightforward.
