There is no need to worry about the ABS system and VAGCOM is not necessary. The bleeding procedure via VAGCOM is only necessary when a brand new ABS unit is installed. I too have the motive power bleeder and have used it on my B5 and others multiple times.
The general rule of thumb is to bleed calipers in order from farthest to closest to the master cylinder (RR, LR, RF, LF). However, some find that air is bled from the system better going the other direction for a B5 (myself included)
There are instructions on the bottle of the bleeder, but most important thing is to not over-pressurize the brake system.
I choose not to fill the bleeder bottle with fluid, to make cleaning up easier because I'm lazy.
Then, I fill the master cylinder reservoir as full as possible. Attach bleeder cap to reservoir. Pump handle until gauge reads about 10psi. Then proceed to loosen the caliper bleed screws as you would with another bleeding. Keep an eye on the fluid level to make sure you don't draw more air into the system. You may have to occasionally pump the handle a few more times in order to keep the pressure at ~10psi.
When you need to add more fluid to the master cylinder reservoir, and need to remove the cap, make sure you depressurize the system by removing the cap on THE BLEEDER FIRST. Otherwise, you'll make a mess and brake fluid is nasty stuff. Especially if it gets in your eyes (blindness).
Originally Posted by
BaseDrifter
On a B5 you should always start at the furthest point from the reservoir and work forward. You do not need to bleed the ABS pump unless you let the master cylinder run dry, but yes, it requires VCDS to cycle the pump's bleeder.
I disagree. I have replaced my master cylinder with a reman unit and only a bench bleed was necessary. No VCDS was used.
