Results 1 to 39 of 39
    Senior Member Three Rings mact3333's Avatar
    Mar 13 2014
    Pacific NW
    Some Interior Mods For B8 S4:
    1. B8.5 gear knob...ease of install 7/10...patience is key when twisting plastic rod...kind of expensive for just a gear knob and boot cover.
    2. B8.5 knock off pedal set...cheap yet look and feel great...a must given cheap price.
    3. BlendMount is very high quality and sturdy...perfect location for Passport Max...Blendmount is grossly overpriced but what can ya do?
    4. Kivic One wifi station to stream lossless music and potential to AirPlay Mirror iPhone and videos/apps.
    I would do 8.5 steering too but its just too damn expensive!
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    Blend mount is a great product, I can't recommend it enough
    996
    Model Y
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    nice job the pedals look just like factory ones in a b8.5
    Dec 23 2013
    Link to the pedal set?
    2011 S4 Prestige | Ibis White | Black/Silver Nappa | DSG | Sport Diff | B&O | Nav | 19" Peelers | Roc-Euro Intake | LED Conversion | Supercharged Badges | VAG COM | BlackVue DR500GWHD | Passport MAX
    Jan 02 2011
    2014 S4, 1989 325i
    Awesome. Can you give any more info on the kivic-one? What MMI cable are you using to connect this? How is it powered? You can airplay video like Google Maps?? Where did you get it- It's hard to find!
    Apr 04 2012
    MSP
    The shift knob and wheels are OEM for those inquiring. ECS tuning sells the pedal sets. I'm not 100% sure about the shift knob.
    OEM Flat Bottom Steering wheel is a must over all else. It's expensive but worth it.
    Veteran Member Four Rings csullivan's Avatar
    May 10 2010
    1997 Jeep Wrangler TJ
    Charleston, SC
    So if you have an 8.5...
    Apr 04 2012
    MSP
    Quote Originally Posted by csullivan View Post
    ...you've got the downgraded electric steering
    May 10 2010
    Charleston, SC
    Just getting an early start on the wave of the future.
    Mar 13 2014
    Pacific NW
    Best bang for buck is the pedal set from China for 88,00 shipped...on ebay...quality surprisingly good and its not something you stare at everyday anyway...installed it in 10 minutes too...heard nightmare stories of how its a PITA to do and takes hrs to do, but I just used brute force and slid gas pedal on top of old one and worked each side one at time.
    Brake was easy, just pull old one off, and use force to get new one on doing each side at a time.
    Dead pedal was harder as you really need to use force to pry old one off as they are held in with like 5 one inch plugs...the dead pedal I just forced on too and it snaps in place...start from bottom and towards lateral firewall...then use the force of your foot...I didn't bother using the clip at top as its being held in there pretty well now.
    The gear knob you gotta go OEM cause you don't want to mess around here cause if you screw it up(i.e.-the rod), your gonna need a new gear mechanism at 1100.00...german vendor on ebay sells for 320.00 I believe.
    Kivic one costs 300.00 but you can get it on ebay for 200.00 for Korean vendor.
    Blendmount is really expensive for our car(130.00) but man is it rock solid....friend just ordered Blendmount for his GTR and it was 80.00.
    But that Passport Max is really expensive, not sure if its worth it really.
    Like that flat bottom steering wheel but I can't pay 2K+ for it...you can get new wheels and tires for that price.
    Mar 13 2014
    Pacific NW
    Quote Originally Posted by acaudi View Post
    Bought MMI to 3.5mm jack cable cheap on ebay...there is a 3.5 mm jack on the Kivic...for power you need to run a power kit to passengers side fusebox and have a microUSB on other end...there is a microUSB port on Kivic for power...hardwiring is easy.
    Look for my Air Enabler thread for DIY pictures for doing power kit from fusebox to glovebox.
    Jan 14 2009
    pasadena md
    just a FYI if you have your vallet key snaped into its housing in the glove box you might want to remove it from the car. Someone could steal your car with that key.
    How did the cheap non audi cable work for the MMI no issues. im looking at getting a usb cable and wanted to make sure those non audi ones work
    Dec 23 2013
    Quote Originally Posted by chaos2984 View Post
    it's not a valet key, it's an emergency key... the housing is meant to stay in the glovebox and the emergency key stays with you.
    Jan 14 2009
    pasadena md
    yea. I thought it was a vallet emergnecy key also. I just keep the two together and in my safe so i dont loose them hehhee The housing isnt much good without the key lol
    Mar 13 2014
    Pacific NW
    do not try to use this product to airplay mirror if you buy a Kivic..it will not work...wishful thinking on my part...MMI to video/audio composite cable doesn't work...you are going to have to tap into the harness on back of MMI which is obviously not a easy thing to do.
    Does anyone here have any experience adding video such as back up or forward camera to the MMI system??????????
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    idk what you're talking about, i use the audi rca plug for my kivic and video works just fine...
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Established Member Two Rings adrianm8's Avatar
    Jan 13 2013
    Edmonton
    What did you use to hardwire the radar detector? I'm about to order the BlendMount and see they have two different cords on the site to choose from.
    Mar 13 2014
    Pacific NW
    Quote Originally Posted by richib86 View Post
    Can you show me with a pic with your cable and Kivic to MMI port?...you get my Kivic airplay mirroring to work with my iPhone 5S and I will paypal you 20.00 no joke haha....I have spent hrs trying to figure out how to do this...so you are using airplay mirroring with your phone???...I tried a composite(red,white,yellow plug) to MMI cable and MMI didn't recognize it...so what am I doing wrong?...hmmm.
    Mar 13 2014
    Pacific NW
    Quote Originally Posted by adrianm8 View Post
    I got the power cord kit from Escort/Passport...Im sure they are the same thing.
    I got this one.
    https://www.escortradar.com/store/di...tcord-red.html
    Mar 13 2014
    Pacific NW
    I used this to connect Kivic to MMI and it didn't work.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Nice build dude !
    just wondering where did you get the BlendMount?
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Mar 13 2014
    Pacific NW
    Richi helped me realize the reason Airplay Mirroring didn't work for me was because I have a 8.0 car and he has 8.5 car...guess 8.5 cars can recognize video input but 8.0 cannot...back to drawing board!
    50.00 bounty for anyone who can help me figure out a reasonable way to retrofit video capability on a 8.0 car!...
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    The flat bottom is theeeeee favorite thing about my car. I fully plan on taking it with me when I sell the car. Not sure what I'll give in return... perhaps a bag of chips.
    Senior Member Two Rings Shantb13's Avatar
    Jun 22 2014
    2002 vw jetta station wagen
    Fullerton , ca
    Quote Originally Posted by mact3333 View Post
    Where did you get the pedals ?
    Oct 17 2012
    NoCal
    Quote Originally Posted by A4 Centaur View Post
    Thanks !
    But I'm just wondering which type of rear view mirror should I choose?
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Why did you change from AE? I thought you were all about that thing in the other thread? Either way, this is a much cleaner install... isn't it? I think so. (One box, two cables... perfect.) BTW, tuck that Kivic in the iPod holder up top and have the cables come out the back, should be even cleaner then.
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    Nice work.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Mar 13 2014
    Pacific NW
    Quote Originally Posted by xuandatou View Post
    Thanks !
    You have to get the one for Audi depending on what your mirror looks like...they have pics...mine was the AUD -003 model.
    Mar 13 2014
    Pacific NW
    Quote Originally Posted by Shantb13 View Post
    Chinese knockoffs for 87.00 shipped.
    http://www.ebay.com/itm/221426072095...84.m1439.l2649
    Mar 13 2014
    Pacific NW
    Quote Originally Posted by SwankPeRFection View Post
    AE was working well and sounding great but I went to Kivic One so I could stream music and AirPlay mirror. My grandiose plans for mirroring has been halted as only the B8.5 support video using simple cable. I can still do it but I need to access rear harnesses with expensive MMI entertainment interface and install going to be a PITA.
    Welcome back btw...for the record, I voted for you to come back only if you didn't participate in any more Air Enabler threads haha...
    Aug 05 2013
    N/A
    lol, I don't think that was one of the options on the vote.
    So, are you saying you can do video streaming but the cable must be in the back where the SAT module and AMP are, in that area? You got any more info on this. When and if I do anything with this, I want a single box setup where I can push anything AirPlay to the MMI display on my B8. As long as the install is clean, doesn't kill off any existing functions/features (i.e. like remove DVD playback or something), I won't be too concerned about the price. It just has to be a seamless setup, ya know?
    Mar 13 2014
    Pacific NW
    I think it can be done...with these products below...one from UK and other from China off of ebay....actually Xcarlink said the unit in pic won't work...we need NTCS and not PAL...but they do sell a product very similar to the one in pic that will work according to them.
    Agree with you it has to be an install and done right...I am finicky too...Kivic is 200.00 and Xcarlink roughly 300.00...so 500.00 and a lot of hassle and time is what it will take.
    http://www.ebay.com/itm/281154707515...84.m1423.l2649
    Aug 05 2013
    N/A
    Why can't we just Y-split off the DVD video/audio outputs? Is the DVD output just internal to the entire MMI head unit or something? You'd figure that if you could have two systems outputting video/sound to the DVD side of things, all you'd have to do is select DVD and just make sure you're not pushing data out the two devices at once. I know it's kid of rigging it, but if the RCA splitter cables are available, technically speaking, it should be a clean plug-n-play thing.
    Mar 13 2014
    Pacific NW
    I don't believe there are any jacks on back of DVD or MMI system that look like audio and video 3.5 mm jack...everything is harnessed back there...these kits replace the harness I believe...guess you could tap into the video wire/harness but then you are cutting wires.
    This mod is so easy and clean for the 8.5 guys...we 8.0 guys are getting screwed left and right...pedals, steering wheel, gear knob, video capability...and prob a lot more too.
    Established Member Two Rings Ribbij's Avatar
    Mar 04 2012
    PA
    So kivic one will mirror video on an 8.5? I was going to do the AE mod but this seems to make more sense then. Do I need anything more or will it just work?
    Aug 05 2013
    N/A
    We do have better steering rack. Lol
    Oct 17 2012
    NoCal
    Appreciated !
    I think it is pretty safe to assume that S4 and S5 share the same type of interior rear view mirror
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Mar 13 2014
    Pacific NW
    Quote Originally Posted by Ribbij View Post
    yes, just buy a Kivic One and then you need that MMI to composite video cord I showed as a pic above on this thread...its like 15.00...now I haven't tested it myself as I have 8.0 car but Richi above says it works for him fine.
