    Jun 19 2014
    2000 Audi TT Quattro Coupe
    Milwaukee, WI
    New wheel question- 20x8.5 for use with the factory 265/35/20 tires? Recommended ET?
    I know my factory rims are 20x9" but looking at some of the Avant Garde rims and they come in 20x8.5 and 20x10. I don't care much for the stretched look. Also want to get the wheels as close to the fender or at a minimum the same distance as the OEMs.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Believe my AG's are 20x8.5 ET 32 on an A6.
    Pics from different angles for ref https://www.flickr.com/photos/463603...7644106254526/
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    Look up the specs on your tire at Tire Rack. They list a minimum and maximum recommended width for a particular size.
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by hackths View Post
    I wouldn't put 265 tires on an 8.5" wheel. Yes you can get it to fit, but doing so is of no benefit. You should really stay with a 9" or 9.5" wide wheel. Look for another wheel choice. On the other hand, 10" gives a bit of a stretch, but it isn't that bad. My M3 has 265s as stock size on 10" wheels. Alternatively, you can go to a 10" wheel and run 275/35/20 tires with no issue. I am assuming you have a 7 series car, because 6 series come with 255 tires as stock.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Jun 19 2014
    Milwaukee, WI
    You are correct VVG... I think I will go with 10" new rims for my current (and future summer tires) , and use my OEM's for winter duty since they are a bit narrower and I know I can get tires easy for them.
