Results 1 to 17 of 17
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    1.8T Fueling diagram
    Hey guys.
    As most of you know im doing the 2.7T swap.
    I am having trouble with the fueling.
    I have a 3.0L filter as it is not regulated and the 1.8 Filter is regulated to 3 BAR.
    and the 2.7T requires 4 BAR. This is to the best of my knowledge.
    The 3.0L has only 1 inlet and 1 outlet
    The 1.8T has 2 inlets and 2 outlets
    So far this is what I think is happening.
    As WAR MACHINE pointed out in his swap. If you do not connect the drivers side tank somehow, you cannot get the last 1/8 tank of fuel out.
    I am thinking of adding a tee to the passengers die on the inlet part of the filter but I am not 100% sure on exactly what all 4 ports do?
    Can someone help me clarify the fuel system on the stock 1.8t Quattro system.
    Feb 17 2004
    Liberty Hill, TX
    on the 1.8T, the 4 fuel filter connections are as follows
    rear center: return line, to driver side tank cover/suction pump
    rear outer: feed line from pump / pass tank cover
    front center: vent line to pass tank cover
    front outer: feed line to engine
    the return line from the filter feeds the suction jet pump on the driver's side of the tank, which transfers the fuel to the pass side of the tank (and directly into the pump baffle area)
    edit: here's a pic of the suction jet pump / transfer mechanism:
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Apr 27 2012
    Guelph
    Thank you for they diagram.
    I wonder if you have any advice on how one would go about converting to a return based system?
    My original idea seems to not be the best after seeing this.
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Quote Originally Posted by f1torrents View Post
    I did this when I converted to return fuel.
    http://www.audizine.com/forum/showth...eturnless-fuel
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Apr 27 2012
    Guelph
    That is a very interesting mod there.
    I am willing to add new lines in a attempt to keep the evap in tack however.
    Do you think this method can be modified to keep the evap?
    Thanks that's a great help
    Apr 27 2012
    Guelph
    Wondering if this is my solution?
    I will call them tomorrow and see if this "converts" to returnless or if it works with a already "converted" system?
    http://store.034motorsport.com/fuel-...audi-6-an.html
    Senior Member Two Rings 00passat's Avatar
    Jul 31 2012
    2005 Gmc sierra 2500hd 6.6 dirtymax
    Lancaster,ca
    I thought also that was a kit to make a b6 return but it is a fuel line size upgrade. It just makes the feed line larger, From what the ad says.
    Feb 17 2004
    Liberty Hill, TX
    I'm going to just add the 3.0 return line and use a 3.0 filter, plus a B5/passat rail. Evap will work as normal, only thing unused will be the vent line from the filter to the pass side of tank.
    Apr 27 2012
    Guelph
    So you plan on blocking the vent opening in the top of the pump lid on the passenger side.
    And run the return line into the existing port on the drivers side tank.
    Is that correct?
    If you run the 3.0 Return to the passenger side im thinking you will be like the others and not be able to get the last of the fuel out of the drivers side tank.
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Stock 1.8t is 4bar regulated.
    The listed 034 link is to upgrade your stock fuel line from the filter to the rail with a -6AN line. It retains the factory 4 bar filter like OEM.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Feb 17 2004
    Liberty Hill, TX
    Is that correct?
    correct. I can't see why this would cause an issue with being able to get all the fuel out of the tank though.
    Apr 27 2012
    Guelph
    The people that put the return in the passenger side have the issue with getting the fuel out of the drivers tank.
    But I think returning it to the drivers side will solve this.
    Hopefully
    Feb 17 2004
    Liberty Hill, TX
    Hopefully
    the stock 1.8T setup has the return going to the driver's side, if you change this then you won't get fuel <1/4 tank from the driver's side as there will be no mechanism to transfer the fuel to the pass side.
    why would you want to run the return to the pass side? just cap the vent line, and leave everything else as-is
    Apr 27 2012
    Guelph
    Yep, that was my thinking.
    However I think some people make the mistake and use the vent in the passenger side as the return.
    I will use this method as it seems the best way to get it done while keeping the evap.
    And I have a B5 return line but I believe those go to the passenger side so I will have to modify it slightly.
    Am I correct in assuming there is virtually no pressure in the return line. >1bar ?
    Aug 22 2004
    My setup keeps the feed line the same and uses the evap line as a return to the tank. My car is an 05 so my intake pump is b7 style so it actually uses a second feed line to syphon gas from the driver's side of the tank.
    USP CLUB MEMBER #7
    Apr 27 2012
    Guelph
    I like your idea, it's just that I would like to keep the evap system intact.
    I have been reading about several different ways and the adding of a return line to the drivers side is the most appealing to me at this point.
    Apr 27 2012
    Guelph
    WarMachine on here just did a 2.7 swap and I believe his mistake was not returning to the drivers side.
    In a post he made in my other thread...
    "- Fuel - You can simply Add a return line and use the 1.8t filter. I used the 3.0 filter as well, but I had to cap off the driver side pickup line. And I can't pickup the last 1.8th of the tank. I know how to fix it, just havent. You would need two T the two fuel lines before they go into the filter."
    Of course his "solution" is also incorrect. As per the diagram posted above.
