Well I have some fun updates...
I finished up a few small things, primed oil pressure one more time and also fuel pressure via VCDS one more time. I then setup VCDs for logging some key sensors and then bit my tongue and turned the key to start it for the first time. 8-10 seconds of crank and nothing... ok, wtf. I see misfires on VCDS, full high pressure in the rail and oddly no RPM value, but my tach was working. Hrm.. once over in the engine bay, didn't notice anything out of norm. Checked for codes, nothing.
Ok, let's try again. Another crank attempt and still no start. Not even a sputter or anything. Wtf! I check everything over again! Push on all connections to the coils, check HPFP, you name it, I find nothing wrong. I then look through VCDS and notice there's 2 different RPM signals. Ok, I turn the other one on. I also turn on the camshaft signal too to see if I see anything there.
Attempt number 3 crank - within 2 seconds it attempts to start. It's really rough, sounds like it's struggling almost like a bad vacuum leak. Quickly look at VCDS, I see camshaft signal, fuel values all look good, but no crank signal still! Wtf! I tap the gas slightly and the engine smooths out. Hrm, vac leak then? I then feather the throttle and it sounds really healthy. Ok, fuck it, break in the rings then! I grab a piece of wood I had ready and wedged it between the seat and the pedal. Had it hold ~2500 RPM.
I check the engine bay, everything looks good. No fluids leaking, no issues found. I check VCDS, things look healthy other than no crank signal still. Ok... I check codes, 2 codes:
1. Too high pressure in high pressue fuel rail.
2. Loss of RPM signal on G23
Well now, this is starting to make sense. Because of the lack of RPM signal, injectors didn't fire. That marked misfires and caused the high rail pressure as the HPFP is still gonna keep pumping being it's mechanical off of the cam. Threw me off that the tach worked though, but I guess it's using the camshaft sensor to assume RPM. Also explains why the 3rd key crank worked, the ECU skipped the RPM sensor and used what it has to try and figure it out. Now... why do I not have RPM signal!?
I replaced the reluctor wheel. Brand new RPM sensor too as the dealership damaged my previous one (scroll back up in the history to see that). Great.. what is it. Please don't tell me I need to pull the engine again.
Break-in went great. No temp issues. Oil pressure was solid the entire time. Coolant flowed well. I shut it down and let it cool off. Short video clip:
https://youtu.be/E8z3uSzBQtI?feature=shared
Once cooled off, stuck my hand down to the RPM sensor connector, pushed on it and I heard a "click". Mother... you mean to tell me...
Cleared codes, started the engine, bam, RPM signal is there and starts up with zero issues. Idles perfectly.
Well, no one can be perfect :)
I then notice I have a very small oil leak under the turbo area. Great... I'll deal with that later.
Time to get the car road ready.
I have new StopTech brakes on order as these are all rusted out. But, it's 4-6 weeks. No one has them in stock. SOB... plan B, let's put the rotors through a rust strip. I got some really good review rust strip for parts and soaked each rotor for 24 hours. It did a pretty good job. I then used a medium grit pad on my air grinder and then a 80 grid pad to both the rotors and pads. Pads cleaned up nice, rotors, well, it will by me time I think. You be the judge by the pics.
Next issue - when I jacked the rear end up, something metal dropped out on each side. Well, take a look at the pic. The stock springs at the seat rusted out and broke completely off. Guess I'm doing my suspension now and not later. Thankfully I have a custom set of KW4s along with a ton of other goodies to install!
This past weekend, everything is back on and I'm ready to drive it! Goal to give it a few drives around the block to see how everything is. Been over 3.5 years since it's moved from the spot it has been and under its own power.
I put it in reverse (MT) and I can't feel proper engagement on the clutch pedal. Wtf... I lm feathering it anticipating a harder engagement with the clutch setup I went with and it's almost nothing. With like the last 1/16 of pedal throw left, I start to feel and notice engagement; the car starts to move. Give it a bit of gas abs it just revs free. I eventually figure out how to get it to move with barely any throttle. Get to the street, put it in 1st and I'm back battling trying to figure our engagement. At this point I've come to the conclusion the clutch isn't engaging fully. It's a partial engagement. I slow did 2 laps around my block which further confirmed my theory.
Back up the driveway, struggling to get it to move up the incline and it "hopping" in gear, I hear my wife "did you forget how to shift". Fuck off, I don't need your trolling shit right now and tell her the news of what I believe.
To make a longer story short, after emails back and further with Ringer Racing and JXB, running the JXB slave cylinder us causing this issue. The JXB is extended, something just over 1/4" more than stock. The clutch setup I have from Ringer Racing is built and designed so well, there's no need for this extension like on other clutch and OE setups. Well, at least we know what it is now and I'll be getting a USP metal one.
Big thanks and call put again for Mike at Ringer Racing, responding to me late at night via email on a Sunday night and Jay at JXB for helping too with this issue and also allowing me to return this slave cylinder.
I'm now figuring out every bolt I need to buy that needs to be replaced for suspension. I have the KW4 electronic dampening coilovers, all 034 motorsports front control arms, sway bars, etc. To install.
I have to figure out what is leaking on the turbo side
And for whatever reason, the car believes the right turn signal is bad, but it works. Odd...
Getting there in time...
Sent from my SM-N976V using Tapatalk
