Results 1 to 40 of 54
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Elring or Victor Reinz?
    so i have already ordered everything i need for my head gasket job, except the actual gasket set itself.
    coolant, oil , oem head bolts, nicer torque wrench.
    now i cant decide over these two head gasket kits. one is elring one is victor reinz. both are exactly the same price.
    http://www.mjmautohaus.com/catalog/p...oducts_id=3732
    http://www.mjmautohaus.com/catalog/p...oducts_id=1914
    are they exactly the same? is one better quality than the other? just want to see what everyone here prefers.
    also is there anything else i should order? timing belt only has 30k on it so i'm reusing it til its time to replace it again.
    keep your fingers crossed that i don't find cracks in the head
    Audi Club Bay Area
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    When it comes to gaskets I have never had issues with OEM. I would recommend to not use aftermarket gaskets but if you did Victor Reinz is well known in the gasket world.
    If it was my engine I would use this. I know it cost more but do you really want a gasket to fail?
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Do not order from MJM. Trust me...
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Oct 29 2005
    10speed
    San Francisco, CA
    Elring 100%. VR is not that great
    - Clint
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    Victor reinz!
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Elring deff way better than VR
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Dec 19 2013
    Quote Originally Posted by PreciseD View Post
    IE is a well known brand for rods and such, but never heard anything about their head gasket kits.
    i did a ton of research on VR and elring and it seemed to be 50/50. some people on VWvortex were bashing victor reinz gaskets saying they fail quickly. some people said they are awesome and lasted them many years.
    i will be ordering my gasket set today, so all feedback i can get from fellow AZ'ers would be appreciated.
    Audi Club Bay Area
    Dec 19 2013
    also, does anyone know if i need to buy any sealants or head bolt lube? or does all of this come with the kits i order?
    Audi Club Bay Area
    Dec 19 2007
    York, PA
    Quote Originally Posted by gotboost View Post
    ive been ordering from MJM since ive owned the car. I've never had a single issue?
    Apr 07 2011
    Quote Originally Posted by Furly View Post
    You don't need any sealer for the head gasket or head bolts. You will need some gasket sealer for the valve cover gasket though
    Feb 05 2014
    Head bolts are not to be lubed unless stated by the manufacture. If you lube them you will need to lower the amount of TQ you use or you will over stretch them.
    Use clean motor oil for all other gaskets prior to install. Assembly lube is used for metal to metal surfaces.
    On a side note it looks like both Elring and Victor Reinz are the OE manufacturers for Audi, BMW and Mercedes gaskets, so either would be fine.
    Apr 07 2011
    I would like to mention that the FelPro head gasket that came with my kit looked completely different than the OEM one.
    Aug 21 2009
    Elring kits are more complete, and I remember when doing my HG the second time I went with Elring and was much more pleased with quality of their kit. I can't remember exactly what it was but I swore to only go Elring form there out.
    Apr 07 2011
    FelPro
    OEM
    Oct 29 2005
    10speed
    San Francisco, CA
    Let me make this clear for everyone, IE DOES NOT MAKE HEADGASKETS. MJM DOES NOT MAKE HEADGASKETS. ECS DOES NOT MAKE HEADGASKETS. All of these companies you buy from re-sell the small handful of companies that make parts for Audi. Elring and Victor-Reinz are two of the ones that make lots of gaskets, just like you can go to Advanced Auto and get a Mobil1, Mann, or FRAM oil filter, but they all work
    VR either works or it doesn't so obviously if it works people like it. However, it fails way more than Elring I can tell you that
    However, Elring is better.
    - Clint
    Feb 05 2014
    Yeah after looking at the kits I would agree with the Elring and I actually think they make the OEM headgasket.
    Dec 19 2013
    so looks like elring is what i will be ordering today.
    thanks everyone! its always good to see what everyones opinions and personal experience are with these sort of things.
    what sealant should i buy for the VCG? it does not look like it comes with the head gasket kits.
    i cant wait to get to wrenching
    is there any valves or anything that is easily accessible with the head off, that i should also replace while i am at it? i want to do as much as i can, since i do have some boost issues also.
    thanks all!!
    Audi Club Bay Area
    Feb 05 2014
    you should lap all your valves if you have the time.
    Dec 05 2007
    There will be the debate about lubing the head bolts. Some do, some don't. The kicker is I am running a victor reinz HG, stock head bolts with arp assembly lube (used on all my internal fasteners matter of fact) on a 530hp turbo with a 25psi 93 octane tune at the moment (where I feel safe before doing other things like securing the crank gear). Victor reinz gasket has also seen 600+whp on the 1.8t. Kicker number 2. I have an elring HG going on next time after I build a head. But...only because I picked it up for like dirt cheap on a fs ad.
    Dec 19 2013
    Smile
    noob question. but what do you mean lap the valves, and how does one go about this?
    i am sending the head to a machine shop to have it tested and machined if need be. but not familiar with valve lapping.
    Audi Club Bay Area
    Feb 05 2014
    Lapping the valves is basically using an abrasive paste on the sealing surface of the valves to make them seal properly.
    It's easy to do and a kit costs about 20 bucks.
    Dec 19 2013
    will the assembly lube come with the head bolts or should i order it? link?
    i feel it may be proper to use the assembly lube, at least a thin coat to get a more accurate torque.
    btw, are you running stock internals or built bottom end (rods etc..) ?
    thanks!!
    Audi Club Bay Area
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    I always say this about Ebay too
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Feb 05 2014
    thanks!!
    Audi uses DRY torque for head bolts. If you use WET torque you will need to lower the torque value to 70% that of the original. I personally would not change that spec and would not use lube on OEM Stretch Bolts. ARP can get away with using lube because their bolts and studs are not one time use.
    Apr 07 2011
    This^^ Seerlah is using ARP head bolts/studs. You will not be using ARP.
    Mar 05 2013
    CA
    Why 70%?
    Feb 05 2014
    Quote Originally Posted by Spike00513 View Post
    Why 70%?
    When you lube the threads of a bolt the friction goes down, thus it takes less rotational force (AKA torque) to apply the same amount of linear force on an object. If you Wet Torque the OEM bolts, which are designed to be Dry torqued, at the OEM Value then you will over stretch the bolts causing failure.
    ARP Studs/Bolts are NOT stretch or torqued to yield style fasteners so they can use lube on the threads. Even with this it is recommend to use larger washers between the cap of the bolt or nut and the head as over torquing on aluminum will cause failure.
    Dec 05 2007
    No. OEM head stretch bolts. ARP ones will go on next time around (already picked up). Used same stuff on my main bolts and rod bolts.
    OP, my bottom end is built (fully rebuilt with forged rods). Cylinder head is next on list. Too lazy to get finished, but started.
    Apr 07 2011
    Ahh my mistake.
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Elring is the main OEM for Audi
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Aug 26 2005
    I use only Elring head gaskets. I also always lubricate the head bolt threads. The torque turn tightening method eliminates variation in final tightening clamping force, and combined with the bolt stretch, the final clamping load on the head gasket is very uniform. With the torque turn tightening and the bolt stretch, the head bolts actually behave like a giant spring holding the head to the block. The head is designed to actually move around a little on the block with temp changes. ARP head bolts develop higher clamping loads on the gasket compared to the stock stretch bolts however, and will prevent head lift and reduced clamp load with very high cylinder gas pressures during the combustion stroke.
    Vorsprung durch Technik
    Oct 29 2005
    10speed
    San Francisco, CA
    and there you have it folks.
    /thread
    - Clint
    Aug 26 2005
    Any machine shop worth it's salt, will lap the valve seats during assembly of the head. Lapping can't be done after the head is assembled.
    Dec 19 2013
    old thread, got most of this stuff done already. i did go with elring because it came in my IE kit of parts i ordered. also replaced every single thing on the engine pretty much.
    don't think the machine shop cut the seats but they did leak test the new head and resurface it flat for me. i'll be putting my new supertech valves in there this weekend.
    very good info on head bolts diagnosticator! i'll definitely lubricate them gently. most people on threads i read, advised against it and said to just clean the threads on the block and torque the bolts down dry. but what you said makes perfect sense. and i do not want the head backing off the block any time soon.
    Audi Club Bay Area
    Mar 05 2013
    CA
    Are you replacing the valve stem seals while in there?
    I've heard of DIY valve-lapping w/ suction cup and/or drill, not sure if it works.
    Did you end up using a sealant on the HG? Clicky
    Dec 19 2013
    the head i got, came with springs and retainers, etc.. so i just have to throw some valves in there.
    do you suggest replacing the stem seals also? i'll have the head back apart to install the valves anyway.
    also, have never heard of anyone using a gasket maker to seal a head gasket. i was always under the impression it should just be a metal gasket between two perfectly flat surfaces.
    the gasket maker i've only seen used to create oil pan gaskets, and to dab on the corners of a valve cover gasket.
    Audi Club Bay Area
    Dec 05 2007
    HG goes bone dry onto clean surfaces. If they aren't clean, don't expect the gasket to hold. Same thing with flatness. And the suction cup is what they use to lap valves in. You do it by hand. Valve head on suction cup, lapping compound on seat and where it meets valve head, then simply go back and forth till the grit becomes more smooth. Clean, move to the next.
    Mar 05 2013
    CA
    My 3.0 oil level slowly drops. I figure I either need new valve stem seals, and/or main seal leak(s).
    On another car that I saw a shop do headwork on, they put in new valve-stem seals. From what I hear, it's easier to do with the head off, and may as well be done.
    If these engines run hot, and have high mileage, why not.
    Oct 29 2005
    10speed
    San Francisco, CA
    I've regretted not doing stem seals twice now on these heads. When they go they cause some pretty serious oil burning. They're a pain to do when the head is off, but when the head is on they're 10x more annoying
    - Clint
    Mar 05 2013
    CA
    Clicky 1
    Clicky 2
