Originally Posted by
mr shickadance
im surprised you are surprised about this, pretty much any roof rack will cause damage like this. while they are pretty well bolted on, they still moved very slightly and when your car flexes over bumps and stuff, these roof racks will rub against your paint.
basically what you are seeing is abrasion and typical to what you would see happened if you imagine something constantly being rubbed on your car.
usually the instructions tell you to put something on it to prevent it.
The surprise comes from the relatively short time-frame over which the damage occurred, as well as my previous experiences with the rack.
This damage on the S4 happened after only 2 weeks of being on the car. It is significant and consistent, on all 4 areas where the mounting feet contact the paint. There is even marring where the outer, flexible portion of the feet, which have minimal pressure and are designed to keep out moisture, touch the paint.
I had a Thule rack on my B5 A4 for most of it's 14 years, and it never showed this kind of consistent marring. The paint was the santorin blue metallic, which would have shown marks like this. I performed no special car on the car, either. While there was some scratching of the paint over time, there were never any distinct marks like the ones on my S4.
I suspect the material used on the whispbar mounting feet is much different than I had. Because the marring is so consistent, even where the mounting pressure light (the outer edges) there is a chemical reaction of some kind happening between the rubber and the paint.
