Results 1 to 39 of 39
    Mar 05 2013
    CA
    Interior door-handle red LED back-lighting
    Has anybody done this?
    2012 A3:
    Apr 15 2014
    Ottawa/Gatineau Canada
    I think my 04 B6 has this stock.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    Very easy to do that.
    Veteran Member Three Rings G.AUDI's Avatar
    Dec 07 2008
    MK6 GTI
    SGV, CA
    Do tell...
    Jun 30 2013
    Bowmanville
    Quote Originally Posted by Luxus Panzer View Post
    Pics or bust, my 04' does not.
    Mar 05 2013
    CA
    So my 04' 3.0L actually does have this, I just couldn't see it because the interior lighting was on the dimmest setting (adjusted via +/- on left instrument cluster buttons).
    Will take pics.
    For those of you who don't have it (if you didn't just overlook it like I did), I guess this means it can be retro-fitted...somehow...
    Veteran Member Three Rings NathanGrayW's Avatar
    May 17 2014
    Akron
    My 04 USP has this stock aswell
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    ... now this makes me wonder if my 04 1.8 has this... its 6spd so its in the same realm as u guys!
    19' Glacier S4 Black Optics
    Aug 27 2013
    Philly
    my 03 3.0 has this....I thought it was standard
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    it is standard feature! BTw i have a 02 us spec.
    Joooe Mamma!
    Aug 27 2013
    Philly
    can we make this brighter? Maybe wire in a rheostat somewhere along the line?
    Veteran Member Four Rings Jermunji's Avatar
    Jun 11 2013
    2006 Lexus “Landcruiser” LX470| 2001 GTI | 1987 bmw 325is
    The Mines, CO
    I'll have to check my '02. Doubt it has this tho
    "If you don't look back at your car while walking away, you bought the wrong car."- Anonymous
    "Us enthusiasts are numb to cost efficiency, otherwise we'd all be driving FRs or Imprezas"- Atid
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    I have it, don't know why you would want it brighter though...mine is just short of blinding when it's really dark out.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Established Member Two Rings Micahseth's Avatar
    May 26 2014
    DFW
    Quote Originally Posted by Spike00513 View Post
    Will take pics.
    I noticed mine too. How do you use the -/+ to adjust brightness?
    '05 A4 1.8T S-Line
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by Micahseth View Post
    '05 A4 1.8T S-Line
    Press the plus sign to increase brightness, press the minus sign to decrease brightness.
    Senior Member Two Rings Slowaudi908's Avatar
    Apr 14 2014
    Audi A4 B6
    I wish my b6 had this. I should of bought a 04
    Aug 27 2013
    Philly
    Quote Originally Posted by Slowaudi908 View Post
    so has it been confirmed that not all b6's have this?
    Established Member Two Rings b6a4sreca's Avatar
    Feb 25 2014
    United States
    Quote Originally Posted by War Machine View Post
    Turn the headlightheadlights witch to the parking lights (one click to the right) and it will come on
    Senior Member Three Rings blownb6's Avatar
    Apr 08 2012
    Ontario
    My 02 us spec has them so must be standard
    Veteran Member Three Rings Toronto5.5's Avatar
    Apr 03 2011
    I have an 05 1.8t USP and don't have this.
    Mar 05 2013
    CA
    Pic of them on in my 04':
    The strip is only visible (as shown in above pic) if I take the picture from below. From a normal occupant perspective, there's only the faintest glow onto the door handle (like shown above). I think it might look better if it was brighter.
    When pressing the "+" button on the cluster, all of the interior lights increase in brightness. While everything gets super bright at max setting (distracting during night driving IMO), the door handle lights increase in brightness marginally. I wonder if the door lights can be made brighter, without also increasing the brightness of the rest of the interior (personal preference).
    I'm not sure if it's powered by LED(s) or incandescent bulb. The following picture is the reverse side of it:
    Quote Originally Posted by cschuster View Post
    Like said above, mine gives off the faintest glow at max (+) setting. Nowhere near blinding when dark out IMO. I almost have to put my head to the door handle to see it. Maybe they are bulb-powered and my bulbs are dying? - (if that's even possible, I always thought bulbs either do or don't work, and there is no dimming in between to signify pending failure, except for HID headlight projector bulbs which dim and get blue over time)
    Apr 03 2011
    ^ oh yeah I have that but it's barely noticeable.
    Dec 19 2007
    York, PA
    im pretty sure my '03 does not...1.8t 5speed sport...but ill look.
    Senior Member Three Rings SaabtoAudi's Avatar
    Apr 30 2012
    Erie, Pa
    Quote Originally Posted by n7plus1 View Post
    My 03 1.8t 5 speed does, I just checked at lunch. They were dim, but I do have these.
    Aug 26 2007
    just checked, can confirm mine has this.
    2004 1.8t 6spd
    Although they are super dim and not noticeable at all at night. Cluster lights set on max brightness.
    Oct 02 2006
    Wadsworth,OH
    Interesting... Now I wanna check when I get out to my car after work. And see if I can increase the brightness of the dash lightning.
    Jason
    Established Member Two Rings Four-Play's Avatar
    Nov 07 2008
    Asheville NC USA
    Wow my car has this as well, I learned something new about my car today Which is an '02 1.8.
    The lights are veeeeery faint, only lighting up like a millimeter of the top ridge of the door handle. Just enough to help locate the handle when it's dark. And they do change with the +/- buttons.
    I had seen that little bit of red light before, but I always thought it was just a reflection of all the other red ambient light that our cars have in the cabin.
    Cool thing to know
    Shawn
    Aug 26 2007
    Ok so who's doing the bright door handle led diy! Haha
    If it's possible to take them out whithout taking the door apart I'll do it
    Jun 11 2013
    The Mines, CO
    Quote Originally Posted by Four-Play View Post
    Awesome, I'm looking forward to seeing this when my audi comes back from the dead.
    Quote Originally Posted by FromS60toB61.8t View Post
    This. Somebody figure this out so I can do it on my spare time.
    Dec 19 2007
    York, PA
    door panels are easy to get off.
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    03 1.8T has them for me pretty bright
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
    Apr 07 2011
    Never knew this little trick. Should definitely be in the Easter Egg thread. I'm gonna try later on tonight on an 02.
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    I have them too, 04 USP Avant. As stated above, you don't notice the light at all, it's when you you put your hand in the recess that you seethe red glow on your fingertips. Same as the red lights in your overhead console by the sunroof switch. They shine down onto your center console but it's so faint that you only realize they're there after you block the light with your fingers.
    Aug 27 2013
    Philly
    Quote Originally Posted by claudiovagkraft View Post
    see, my center console ones are very bright. Ideally, my door lights would match my over heads.
    Senior Member Two Rings Jfonse81's Avatar
    Apr 15 2019
    coming soon RS4
    Nyc
    Reviving this post :
    I have a B8.5 and the stock light you cant barely see it so I instead modified it with a red 3mm led bulb and now you can definitely tell . I'm very satisfied with the results and its really inexpensive and not hard to do.20191204_220508.jpeg20191204_220526.jpeg20191204_220515.jpeg20191204_220535.jpeg20191204_220540.jpeg20191204_161720.jpeg
    Sent from my SM-G973U using Audizine mobile app
    Jul 28 2020
    LA
    How’d you get the bulb out of the OEM LIGHTING MECHANISM
    I took of the door panel and got access to the lighting mechanism but there doesn’t seem to be a way to remove the bulb inside? It’s stuck in the clear plastic piece and connected to the black piece with the yellow box on the end housing the wires. Would you mind telling me how you got the old bulb out to put the new one in the clear plastic projecting mechanism? I’d really appreciate it as I have the door Panel already off the car. I purchased a 3mm red led with a resister for the replacement.
    Best,
    CONOR
    Apr 15 2019
    coming soon RS4
    Nyc
    If my mind recollects , in order to remove the oem bulb , you have to pull the whole plastic clear housing where the bulb goes . Then cut the oem wires and soldered it to the 3mm led bulb . Also the plastic grommet that comes with the 3mm bulb, I reversed it and drilled the hole bigger with a drill bit so the 3mm bulb will fit properly, see photos
    Quote Originally Posted by ConorB View Post
    Best,
    CONOR
    Jul 28 2020
    LA
    Thanks so much for the response. Was a shot in the dark reaching out on here
    Quote Originally Posted by Jfonse81 View Post
    Apr 15 2019
    coming soon RS4
    Nyc
    No problem! Once you figure it out and do one side , the other side its a breeze . And the results are impressive, the way it should've came from manufacture. Good luck
