Results 1 to 14 of 14
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Adjusting Exhaust Tip Height?
    I have one exhaust tip that sits lower than the other. It's really obnoxious, and it's killing my OCD. I don't want to go and throw some washers underneath the hangar of the higher one to have it match up. There's about a half an inch difference between the two. I was just underneath it today, and all I saw to pull apart are the two hangars and the cross-brace.
    Any suggestions on how to even the two out? I'd prefer to raise the lower one, but I'm open to ideas.
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Oct 16 2008
    South Florida - Ft Lauderdale
    The rubber of the left bracket is probably your problem
    Replace it
    Phil
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    You could always do the tankdeer mod....He used zipties to get the tips to rise.
    If you want to get them even, just replace both rubber pieces on the bracket.
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Tankdeer mod was wildly successful. I'm hoping that the zipties hold up under the suspension and the heat. We'll see how it goes, but I'm happy for a 5 minute mod!
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Zip tie mod before and after
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Go get some zipties, they work fine, I've run them for thousands of miles no problem.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    It is actually the center cross bar right after the dif that needs to be adjusted. Giant pain in the balls by yourself.
    Veteran Member Four Rings xander3zero's Avatar
    May 30 2013
    Rhode Island
    Quote Originally Posted by PDX04a4 View Post
    Quote Originally Posted by PNW Avant View Post
    where did you guys attach the zip ties to bring the exhaust tips up? i just installed my CTS exhaust and one tip hangs lower than the other no matter how much i adjust the center cross bar...im thinkin I could try replacing the rubber on the hangers, but id like to try the zipties first...just wondering where you attached the zip ties, meaning where are they secured to on the exhaust and where are they secured to on the car? thanks
    2017 Audi S3
    Mythos Black Metallic | Dynamic Package | Tech Package | S Sport Seats | Bang & Olufsen
    Previous:
    2013 Allroad Premium+
    2006 A4 Quattro 6MT
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    right were the rubber hangar is
    May 30 2013
    Rhode Island
    Quote Originally Posted by groundround View Post
    so you zip tied from the metal hanger on the exhaust to the hole in the rubber hanger? do you still have the metal part of the exhaust inserted into the hanger? i tried to do zip ties like that and it didnt raise it all...
    edit: can anyone confirm that this fits? it seems like a lot of sites confirm its fitment but it looks different than the hangers I have.. the base of it looks curved where it should be flat?
    http://www.amazon.com/Vaico-W0133-16...=W0133-1626763
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
    May 30 2013
    Rhode Island
    Replace it
    Phil
    Phil do you happen to have the P# for the rubber? is it the same on left and right side? I see europaparts has both hangers on their site but id like to just replace the rubber part if I could. in my post above I linked a vaico hanger that supposedly fits the b7, but it looks different. Thanks.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by xander3zero View Post
    Yes, basically follow where the rubber hanger goes but with the zipties. Leave the hanger in place, just add the zipties for a little additional support. Been running them that way for 6 months without issue.
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
    Junior Member Two Rings
    Sep 07 2013
    Bradenton, Fl
    you need to loosen the clamp between the downpipe and the exhaust system and rotate the exhaust so you get even spacing at the rear, it works.
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    For reference...
    http://www.audizine.com/forum/showth...=1#post7341422
    I put in new hangers and a year later they sag again....going with zip ties soon.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
