Originally Posted by
Nanopg
Hi, I was able to figure out how to remove the roof liner and the sunshade. I was able to save the sunshade only that I am now trying to figure out how to re-glue the fabric to the metal strips. I'm just still wondering if is worth the hassle or if is even possible to sucessfuly accomplish it.
Removing the headliner took me abou 2 hours but I basically went for it blindsided. If anybody needs guidedance I can explain by phone and then that person could post it for the rest.
Let me know.
I just finished this job this past weekend.
First off I got a good laugh at the dealer. The car came with a third party warranty, and like a rookie I assumed it would cover the sunshade, nope. So i drop it off at the dealer who charged me $170 to look at it and then tell me that they wanted $1500 in labor plus $400 in parts. $1900. Yeah thats reasonable
So i ordered the part, think it came out to $310, and i received the black metal case where the sunshade rolls into and the sunshade, but you should never have to replace the metal case, you should just order the sunshade instead.
Anyway So i take my car from the dealer, let me tell you this job is cake.
The headliner does not have to be removed. You simply have to loosen it in the rear. So pull out the plastic center piece that covers the end of the headliner in the trunk, then there is a button in the center that holds the headliner into the rear section of the car, Just use a flathead to push in the tabs on each side and pull down. next you need to release the two side pillars on the very rear, remove the coat hanger on each side and then pull the pillar back and it will pop out.
Next you need a t20, pull down the head liner, should be loose enough now, find the two t20 screws that hold in the sunshade metal housing, boom its out.
Now to remove the sunshade fabric, hop into the drivers seat, retract the sunroof glass and then turn the knob a little more, this will push the glass into service mode. There are 2 t20's that need to be removed here one on each front corner of the rear glass panel. Remove those. Note that between teh chassis and the glass there is a pair of spacer washers, don't lose those in a second. Ok now go inside of the car, into the rear seat, grab a flathead and find the rubber lining that goes next to the rear glass panel. Run the flathead through the sides of that panel in the rubber gasket, and you will find that behind the gasket there are two notches for two more t20's on each side of the glass, remove those. Cool, now push back the front glass into its regular position, and pop out the rear glass. put the rear glass on a towel or something soft. move the sunshade all the way to the rear position so it is at the far back, now you will find two t20's at the rear of the place where the glass panel used to be, remove those, and then right next to those screws are a set of tabs, pry them outward and up with a flathead or pick, and you will now see that you can remove the metal bar that pulls and pushes the sunshade fabrick. Remove the two grey tabs on each side and then simply slide the bar off of the fabric.
Took me 2 hours to do this whole thing, not even close to 15 but I suppose thats why they call it the stealership
