Results 1 to 19 of 19
    Jun 18 2009
    Phoenix, AZ
    Calibrating the speedometer?
    For months I've been wanting to figure out if the speedometer can be calibrated. Mine, for example, will show 80 mph, but my GPS, my phone, and my radar detector all show exactly 75 mph. So the speedo is "optimistic" by about 5mph.
    Is there a way to go in via vag com or something to fix this? My speedometer in my girlfriend's S4 is dead on accurate.
    2017 Camaro SS 1LE
    Veteran Member Three Rings 993140's Avatar
    Oct 14 2012
    GT3 Touring
    Way Out West
    Don't know if it can be calibrated, but mine's the same and pretty much all cars I've owned before were exactly like that. My daily driver 2014 B8 S4 is dead on as is yours, but this is my first ever car with such an accurate speedo.
    Viken
    2024 RS3
    2023 S3 Premium Plus
    Jun 18 2009
    Phoenix, AZ
    Yea, seems to be a fairly common issue - http://www.audizine.com/forum/showth...te+speedometer
    Well, I just take that percentage difference and apply it to the mileage my odometer is showing, haha.
    And yea, the S4's is perfect, all the way up past 120mph. The RS4's gets worse and worse. There's gotta be an option somewhere in vag com to make this adjustment..
    2017 Camaro SS 1LE
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    In Europe it's a legal requirement for the speedo to over-read by up to 10%, so most EU manufacturers setup their speedos to over-read by 5% to make allowance for tolerances, tyre wear, etc.
    Jun 18 2009
    Phoenix, AZ
    But the S4 is dead on..
    2017 Camaro SS 1LE
    Oct 11 2007
    Suburbia
    Use the digital speedo in your navigation, its the most accurate
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Veteran Member Three Rings gesTTalt's Avatar
    Oct 10 2004
    You can't via vag. I swapped to 265/35-19 tires and now my speedo is pretty close to my gps and the RSNE speed. I also used vag to entire a new tire size, but system will calibrate it over time on its own.
    07 Daytona Grey RS4
    Jan 14 2007
    Hampshire, U.K.
    Quote Originally Posted by FWP! View Post
    How worn are the tyres? As the tyres wear and the rolling radius reduces the speedo becomes more accurate.
    Jun 18 2009
    Phoenix, AZ
    Brand new PSS's
    2017 Camaro SS 1LE
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by WinterRunner View Post
    Wat?
    I went into engineering mode, saw that that speed is dead on accurate, but I want my speedometer in the instrument cluster to be accurate too. It's exactly 6 MPH higher than actual speed at 80 MPH (actually going 74 MPH).
    2017 Camaro SS 1LE
    Jan 14 2007
    Hampshire, U.K.
    As already said by others there is no VCDS method to change the speedo calibration, you'll either have to have your speedo professionally recalibrated or live with the error.
    Jun 18 2009
    Phoenix, AZ
    Well, it sounds like you can modify the tire diameter via vag com so I may try that.
    2017 Camaro SS 1LE
    Jan 14 2007
    Hampshire, U.K.
    AFAIK that only affects how rapidly the RNS-E learns the distance calibration factor it uses and has no effect on the instruments.
    AFAIK there's nothing on the Ross-Tech wiki about tyre calibration on address 17 (instruments), only adaptation channel 1 on address 37 (navigation).
    Sep 27 2011
    Tomatoes
    Eastern PA
    Quote Originally Posted by PetrolDave View Post
    That's what I've been told as well. Can't confirm either way though.
    Suzuka Gray 2015 S3 Thread
    Misano Red 2003 RS6 Thread
    IG: @Flying_Tomatoes
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    I recently went with one size wider tire and my speedo is now accurate. First time in 14 years of driving an Audi.
    Feb 21 2010
    RS4, R8 V10 Plus, 911 GT3, Z8
    Chicago, IL
    No wonder the car seems so fast...when in reality it isn't quite as fast
    Feb 01 2012
    nyc
    Well I was going 80 and change according to the speedo and got ticketed for 82.
    Jan 14 2007
    Hampshire, U.K.
    Quote Originally Posted by B-Time View Post
    If you've kept the same profile of tyre then that's increased the rolling radius = more distance per turn of the wheels = actual speed increased compared to indicated speed (which just counts turns of the wheels in a given time).
    Dec 05 2006
    So. Cal.
    What does this do to the mileage on the odo.
    Back when I first got my car, I tested it with mile markers on the way to Las Vegas. For ever mile marker I passed, the odo increased by 1.2 miles.
