Results 1 to 15 of 15
    Dec 05 2009
    New York
    Tires with Thicker Sidewalls
    Does anyone run tires with thicker sidewalls? I live in NYC and the roads are covered by tire popping suspension breaking potholes and was exploring options. TIA
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Take the metro
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Feb 24 2010
    And have never been happier
    Here is my personal view on this:
    While thicker sidewall may give you the added benefit of saving suspension or other parts, it also makes for a slightly harsher ride. Run flat tires are commonly associated with thicker sidewalls and more mass as well of course. This is because tire manufacturers are expecting all of the car's weight to drop on to the sidewall if tire goes flat (in run-flat tires of course).
    What about running bigger sidewall tires instead of thicker sidewall - 50 instead of 40 and so on.. Cushioning effect will soften the impact from pot holes if city driving is what you do most.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    correct, ride will be harsher. wrc made this change in 2014 when they disallowed the runflat technology -- forced the teams to soften up the spring/damper rates to compensate.
    run flats also handle worse.
    Just get a tire warranty. every tire store in the world (including tire rack) offers a road hazard protection program. this is an additional purchase that you must make, and is not covered under the manufacturers mileage warranty.
    afaik there are no street tires that have beefed shoulders, although I suspect there are some variances between tires.
    softer suspension and taller sidewalls (smaller rims) will help as mentioned above.
    Aug 05 2011
    Memphis, TN for now!
    Read the tire specs... you can find the sidewall ply information. Look up the specific tire because depending on size the construction will be different. Also look at cornering ratings and load...this can give a clue to the sidewall design.
    My experience is that depending on the hole in the ground this may or may not help you. If the hole is big and takes your entire tire in then you want the tire softer otherwise your suspension takes the hit... if the hole is smaller then you want the tire harder otherwise the tire gets damaged.
    Proper air pressure and insurance is the way to go.... you can also get money from the city for damage... but you need to go to lower manhattan and also have a report and pics. Good luck with that because it takes a year to happen.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    Quote Originally Posted by bps4 View Post
    What tire size are you running now?
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Dec 05 2009
    New York
    Quote Originally Posted by ilyafil View Post
    Stock
    Jun 21 2014
    WA
    Lol @ living in nyc
    Sent from the woods
    Active Member Two Rings _drew.potts's Avatar
    Feb 23 2012
    New Paltz/Queens
    Same here, I've gotten 3 bubbles in the last year on stock tire size. BQE is garbage
    Nov 03 2011
    Bay Area , CA
    Stock
    WOW! NYC streets must be really bad. Move to Cali.
    Dec 05 2009
    New York
    Quote Originally Posted by _drew.potts View Post
    exactly this - I've practically memorized the pothole layout
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    This is why I like my 17s and don't want 18s or larger.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Sep 11 2009
    NE
    get a higher load tire (these are stiffer and more sturdy) and no, stiffer tire won't save your suspension - the opposite actually since stiffer tire will be less flexible and more vibrations/shocks will travel through the rubber to suspension.
    And move out of that garbage city. With millions of square miles to choose from, people still choose to live in cities - I don't get it - they even defend it... rats like it in garbage piles too so maybe why. I got out the moment I had an opportunity, once I turned adult and went to live on my own.
    Dec 05 2009
    New York
    so it sounds like a tradeoff between punishing tires and suspension - I guess I'll just buy insurance the next time around and deal with it for now.. thanks for all the great info!
    Jan 16 2006
    LA CA
    Always buy the insurance
