Given that its actually fairly easy to install it properly, I would repalce it.
Anyway, if you discover it IS leaking, then your clutch swap is on hold until you get one. Because only a complete moron (or a masochist) would buttone the clutch up and put the tranny on KNOWING that a $25 seal located behind the flywheel is seeping and you could have addressed it...
My advice, buy it. If you don't need it great. If you do, you are prepared.
FWIW, my Rear Main Seal was leaking when I replaced my clutch at 95k this past fall. Very glad I saw the warning signs (dirty oil dripping out from between the engine block and tranny bellhousing) and deduced it must be the RMS. Would have been a VERY annoying way to have left the job half done while I tracked down a rear main seal on a Sunday....
