Results 1 to 24 of 24
    Veteran Member Three Rings srcrash715's Avatar
    Jul 15 2011
    VW MQB Tiguan, VW Rabbit. HD Street Bob, Mercedes E320 CDI
    Frederick/Maryland
    Intercooler Piping Keeps Blowing
    For a little backstory, I have a CTS turbo FMIC that I installed around 6 months ago. I never had a problem with it up until I installed a K0R and/or had work done to the car and tuned. The reason for the and/or is because it didn't pop off right when I installed the K0R but I also wasn't pushing it because I was still on a Revo 2 tune. The work done to the car was: the cam, cam follower, hpfp, timing belt and oil pan replaced. So I can't say for sure if it was something the shop did or not but I never had the problem before.
    As for the hose attached to the turbo outlet is the one that keeps popping off, I have pulled it apart and re positioned the piping multiple times but it still keeps coming off. Does anyone have any ideas on how to keep the pipe on?
    Sidenote:
    I feel like it is also more difficult to line up the piping with the K0R then with the k03...
    Current: Sprint Blue MT B7 S4 Avant
    Mods: OCarbon Reflexive Silver Trim | VMR 701 19x9.5 with 265/30 Yokohama Advan Neova's with a wee bit of rub
    R.I.P. 2005.5 BAT Quartz Gray Tip
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    tighten it harder? A bit of hairspray always helps to make things sticky. Take some sandpaper and scruff up the turbo outlet to give the silicone some adhesion....not much you can do aside from that.
    You could have an alumnium bend welded into the turbo so that it comes out already directed in the correct position
    Jul 15 2011
    Frederick/Maryland
    I have tightened it and gone through tons of hose clamps and fixing it on the side of the road. I was contemplating welding a bracket to keep it all in place but I would rather not. I will give the hairspray a try and if it doesn't work get some new piping.
    Thanks for the input
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Yeah, I was going to suggest hair spray also. I blew my intercooler piping off like 3 times. Found that one of the clamps that I thought was good, was actually a little too big, and it wasn't tight enough when it war completely tightened.
    Sent from my SGH-M919 using Tapatalk
    2021 Audi S4, P34 Intake
    Jun 17 2013
    jersey city nj
    Hair Spray mine the 1st around. on wood. Been good. Used Treseme brand if that helps you
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by vce1232000 View Post
    headbang on wood? this seems excessive.
    Dec 03 2008
    2018 SQ5
    Could mean BJ?
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    What clamps are you using? Pics of said clamps?
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    T-Bolt clamps are the only way to go and that's what comes with the CTS kit. My guess is that whatever shop you took it to didn't tighten the t-bolt enough the first time.
    Martin is 100% correct. Scuff the outlet, wipe the silicone down with Isopropyl, allow it to dry and then spray some hair spray on it. I myself prefer Aquanet for such jobs cause it's cheap and has a Loctite-like hold.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Hmm makes sense. I'll have to check out aquanet. Every now and then usually after dismantling part of the intercooler system one of my coupler blows off. Nothing huge just a bit annoying, might be worth the effort to check out
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Could mean BJ?
    Lol
    What ever makes sense go with the opposite and you got it
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Could mean BJ?
    You're spot on, he always disguises his inuendos but we know what he likes to do in his free time
    Dec 03 2008
    2018 SQ5
    OP, always remember, if you blow an IC hose, you can still limp home by unplugging the MAF. saved my ass a couple times.
    Jun 26 2012
    Reading, PA Area
    You've gotta get the aerosol can though. Not that bullshit pump one.
    Jul 15 2011
    Frederick/Maryland
    Never thought about that good to know but hopefully I wont have to worry about this any more.
    I am gonna pull it apart and today and do the hairspray and scuff up the connection. Give it some time to dry then give it a whirl and hope all goes well.
    Unfortunately the original Tbolt clamp is long gone, I will have to order one.
    Jun 26 2012
    Reading, PA Area
    You're not going to be able to hold 25+psi with a regular worm-gear clamp.
    Feb 06 2009
    328d, Tacoma
    Quote Originally Posted by LoKisSpYdR View Post
    Pretty sure I ended up using a worm gear, and it held.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Jul 15 2011
    Frederick/Maryland
    Picture of clamp
    I decided to go with white rain unscented extra hold
    Sent from my SM-G900P using Tapatalk
    Jul 15 2011
    Frederick/Maryland
    Any suggestions on time frame?
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    White rain? As opposed to chocolate rain?
    Jul 15 2011
    Frederick/Maryland
    Jun 17 2013
    jersey city nj
    Mec does look fit a aquanet type of a guy.
    Whiterain. Isnt that Dollar General supllies?
    Jul 15 2011
    Frederick/Maryland
    It's what I found at the in laws
    Jun 26 2012
    Reading, PA Area
    That worm-gear looks like it could be at the end of its adjustability.
