Results 1 to 30 of 30
    Registered Member One Ring StangGT5's Avatar
    Jun 19 2014
    Jacksonville Fl
    Unhappy 2007 C6 A6 Sedan 3.2 CVT MMI DEAD
    2007 C6 A6 Sedan 3.2 CVT MMI Problem
    I bought the car a couple months ago with the MMI completely dead. The car runs,drives, and looks great. A/C blows cold, everything but the MMI and trunk release switches work (key fob opens trunk so I dont care). The screen is completely dead and the control buttons do not light up. I scanned it with my VAGCOM 12.2.2 HEX CAN and did a Optical Bus test. Every single component showed electrical and optical ERROR. Deciding I did not feel like dealing with it I sent it to the only local Audi dealer. They had it for three weeks and said they couldnt figure it out.
    Getting it back, I checked all the fuses three times and found the telematics fuse was blown. I found the bluetooth/tele module with corrosion all over it. I left the module unplugged, replaced the fuse, and did the optical test again. This time I found about 3/4 of the system showed "OK". I ordered a new module, went to plug it in and the fuse blew. I took the connector apart to find two wires in the larger of the two slides melted together. I replaced the larger portion in the 54 PIN electrical connector with a pig tail from a 2008 A6 , plugged in the replacement module, and replaced the fuse. Now I am at this point:
    Control Module Part Number: 4F0 910 468 A
    Component and/or Version: Gateway H11 0070
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK ERROR
    07-Control Head(High/D3) OK OK
    0E-Media Player 1 OK OK
    77-Telephone OK ERROR
    47-Sound System OK ERROR
    56-Radio OK OK
    37-Navigation ERROR ERROR
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 27 37 42 46 47 4E 4F 52
    53 56 5E 61 62 65 72 77
    Mileage: 160650km/99823miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    27-Ctrl Head, Rear -- Status: Cannot be reached 1100
    37-Navigation -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: Cannot be reached 1100
    4E-Ctrl Head RR -- Status: Cannot be reached 1100
    4F-Centr. Electr. II -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    5E-Ctrl Head LR -- Status: Cannot be reached 1100
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Control Module Part Number: 4F0 910 468 A HW: 4F0 907 468 D
    Software Coding: 6CFE53C51FB105
    Work Shop Code: WSC 07109 444 10332
    VCID: 275D40FF96B5AC26FAD-8072
    2 Faults Found:
    00470 - Combination comfort Databus in Single Wire
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 160658 km
    Time Indication: 0
    Date: 2006.07.06
    Time: 14:11:30
    00384 - Optical Databus
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 160658 km
    Time Indication: 0
    Date: 2006.07.06
    The MMI is still very dead and I am stumped as to where to go next. Although the modules electrically show "OK" other than the Navigation, the only module I can communicate with is the CAN Gateway. Basically, the only thing that changed after replacing the bluetooth/tele module was that the Telephone now shows "OK" electrically
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    Am i reading that correct and seeing that the Audi dealer had it for three weeks and didn't even notice that the fuse was blown and that your bluetooth module was corroded? I would go to a new dealer, that would be the most expensive but easiest way to figure out what's wrong. If your date is right on your car, the fault codes started when the car was brand new. So it could even be faulty MMI hardware, but there is almost no way to tell...
    Anyways, this could really be a nightmare to diagnose. I wish I could help you more but I don't have any suggestions besides to check every fuse (not by sight) and check all the wiring in the MMI system with a fiber optic bypass loop and hope that something isn't working or connected all the way. The most common points of failure are from the AMP and the MMI circuit board.
    If you haven't done a hard reset of your MMI since replacing the module, I would try that. Or just unplug your battery for a couple minutes then plug it back in.
    Jun 19 2014
    Jacksonville Fl
    I couldnt believe they did not catch a fuse...the local dealer either did not want to spend the time to diagnose it or they are incompetent. The next closest is hours away. I have a great background with Audis pre 05 when all this tech came about. I owned a 2005 3.2Q A6 years ago and never had a problem with anything but the abs module (typical audi). I have an Audi loop adapter, do I just plug it in everywhere there is an optical port and try it each time I bypass a module? At some modules I get the red light, others I do not. I saw the AMP is a common failure on Avants but this one is a sedan and dry as a bone back there even in wet weather. Ive seen people with similarly dead MMI systems replace the control module behind the glove box with success but it just seems odd when tested that the modules all say OK except the navigation and yet I cannot connect to any of them save for the CAN gateway.
    May 02 2010
    Milford/ma
    Could be the MMI control unit like you read or the connection to and from the control unit hers ross techs on the one wire mode http://wiki.ross-tech.com/wiki/index.php/00470.
    The open circut looks like its the only culprit be it bad controler or bad connection on wires .
    Jun 19 2014
    Jacksonville Fl
    UPDATE: This morning I decided to take the negative cable off the battery for a while, say 10-20 mins. After reconnecting I noticed the screen was still dead and the buttons were not lit up. The same codes were in the gateway module and the optical test showed the same results. However, the screen came on after I did the optical test! Albeit for a few seconds just to show the black, red, and silver AUDI MMI logo, but it did come on so that has to mean some progress has been made. It comes on maybe 30 secs to a minute after an optical bus test is completed and is fairly consistent. I also noticed when I do the Optical test wit the rear seats down I can hear a click in the trunk. I have the whole bracket/assembly with the radio module and amp laying out of its cubby on the trunk floor so maybe Im just hearing the amp power up?
    Jul 17 2011
    Sin City, USA
    I got nothing for this, but I am watching the thread so I can learn. Keep the updates coming and good luck!
    '09 C6.5 A6
    May 02 2010
    Milford/ma
    Ok you said you tested the optical with Vag right did you do both Standard to 3dB Attenuation? Do you have a Most optical loop to test to go through each piece ?
    Jul 02 2013
    406, MT
    Quote Originally Posted by StangGT5 View Post
    I couldnt believe they did not catch a fuse...the local dealer either did not want to spend the time to diagnose it or they are incompetent. The next closest is hours away. I have a great background with Audiis tech came about. I owned a 2005 3.2Q A6 years ago and never had a problem with anything but the abs module (typical audi). I have an Audi loop adapter, do I just plug it in everywhere there is an optical port and try it each time I bypass a module? At some modules I get the red light, others I do not. I saw the AMP is a common failure on Avants but this one is a sedan and dry as a bone back there even in wet weather. Ive seen people with similarly dead MMI systems replace the control module behind the glove box with success but it just seems odd when tested that the modules all say OK except the navigation and yet I cannot connect to any of them save for the CAN gateway.
    With the fiber optic loop in these cars, each component isn't connected individually. So if one part of the loop or a module isn't working, then it won't allow data past it. With the bypass you can cutting out each module one at a time, and resetting the MMI to see if it will turn on, but without that specific module. What all modules do you get a red light at? You might want to try bypassing all of them and seeing if your MMI will turn on. This is a great resource for some info and has information on getting a MOST bridge adapter http://http://a6retrofit.tripod.com/...ostbridge.html . With that article in mind, and seeing that your Nav module cannot be accessed... Maybe the bridge adapter there in place of the module is loose, disconnected or bad? Did your car even come with Nav?
    I still do believe this could be a fuse hidden somewhere or one that looks ok. I would use a multimeter at each of them. I'm not sure where every fuse for the MMI system is at in these cars but i've read on other Audi models there's MMI fuses in the fuse boxes in the front left and right of the car, along with under the dash on the drivers side, and a couple in the engine department. I will go check my car and see if i can find/pinpoint where all the MMI fuses are.
    Jun 19 2014
    Jacksonville Fl
    First, thank you all for helping out. Second, I checked the fuses in the left and right side of the dash as well as the trunk with a test light at least 3 times. I also checked to see if there were any missing fuses but the empty slots only had one receptor meaning my car didnt come with whatever accessory that fuse goes to. In the left side of the trunk where the nav module would be on the bottom rack it is empty and just has a MOST loop connector in place. I assume this car being FWD may not have had NAV. My 05 3.2 Q A6 didn't have it either.
    I do not remember exactly what modules I've got light to/from I'll go check again to be sure but I believe the glovebox cd player, the MMI control module, and the radio module have light. I tried plugging in the most loop connector I bought new from an Audi dealer at different modules and running tests as well as trying to boot the MMI. On modules where the test showed optical "OK" it would show "ERROR", probably because the modules were plugged in and saying something different than what the adapter supplies. I did both regular and 3dB tests, both showed the same results as far as the "OK/ERROR" values go.
    Another UPDATE: I left the battery off again, for 30mins this time, and when I turned it back on I was accosted by a lovely screaming beep telling me my automatic wipers/ headlights were inop. This message came on after I bought the car months ago but pulling the fuse and reinserting it did the trick and the wipers/lights worked fine. Not so much this time, as it is throwing a code for no communication with the wiper module (motor/module one piece in the C6) and no communication with the rain/light sensor. I tried the fuse pull a few times and no go. Goodie, because not only will the auto wipers not work but the wipers are completely inop. According to VAGCOM measuring blocks in the Central Elec. the stalk is sending the appropriate signals when I move the stalk but the light/rain sensor and wiper module show no communication. Oh well, separate issue. If it didn't have such cold A/C, drive so well, and look so good I'd be inclined to push it off a cliff....too bad Florida is flat.
    May 02 2010
    Milford/ma
    I have a friend in duval county that could make it disappear jk. I do no have nav and was supposed to let me go vag it real quick for a optical to see what I get as a compare with your read out.
    Jul 02 2013
    406, MT
    It really seems that water has somehow gotten places to be having all of these problems. The car i bought was in florida for the first 8 years of its life and has no electrical problems aside from the TPMS antenna acting whacky and making the TPMS come on/go off randomly. It has been replaced 3 times in the car's life and still has problems so IDK....
    BTW dont pull the negative cable from the battery, pull the positive so that all the excess power can safely drain from the components. I don't think it really matters, but i feel since the frame/grounded components connect to the negative side of the battery its safer to pull the positive. I would try unplugging the battery off for a while longer then connect it and turn your car on. Don't run your VAG-com for at least 5+ minutes after your ignition/car is on.
    as far as your MMI goes, don't test by using your VAG-Com, do a hard reset of your MMI to test and see if it will work after bypassing a module. If a module was there then not anymore, it will probably cause problems without resetting the MMI and show up as error when you scan for faults. Remember, the electrical components of this car never actually turn off unless the battery dies or is unplugged. To hard reset the MMI there's info here http://www.audizine.com/forum/showth...how-to-do-this In theory, you should see the startup screen like when you first plugged the battery back in.
    Quote Originally Posted by steel2040 View Post
    I have a friend in duval county that could make it disappear jk..
    Haha... OP do you have full coverage/GAP protection?? Easiest route to go! JK
    May 02 2010
    Milford/ma
    19-CAN Gateway OK OK
    77-Telephone OK OK
    47-Sound System OK OK
    56-Radio OK OK
    0F-Digital Radio(SAT) OK OK
    Optical Bus Diagnostic : 3dB Attenuation
    77-Telephone OK OK
    56-Radio OK OK
    So your Test below shows you have optical communication with the gateway,Telephone,sound system and nav to me that so what controllers did you not get light on when you Looped I am defintly feeling a controller isnt comming out or the optical could be pinched between to of them.
    56-Radio OK OK
    Vag and the comp always list things in order so if you reset or get rid of the nav I would work backwards with the last thing that the optical gave error to see if your unit comes back on.
    Quote Originally Posted by FormulaElement View Post
    I second that also since my nav does not show up but I am sure you could disable it through vag.
    Last edited by steel2040; 06-21-2014 at 01:40 PM. Reason: added more of my 2 cents
    Feb 06 2013
    CA
    I've got a gut feeling that the control module associated with your MMI has gone bad. I've seen a number of threads with similar types of issues related to the MMI and bad CM. You can purchase a used CM for a reasonable price of CL and your dealer may need to be involved to remove the CP. But that might do it...good luck and i'll be watching the thread
    May 02 2010
    Milford/ma
    Quote Originally Posted by sun_dance View Post
    But his control Head isnt throwing codes and his optical test said it was good coming in and going out. I still think its something to do with the gateways end or the nav not being there.
    I kinda take that back the control panel might be at fault he has always said it never lights up time to see if some one is nice enough to let you borrow a spare to bad your in florida I have one I am selling on ebay and would of let you try it out to see if you need to buy one.
    Last edited by steel2040; 06-21-2014 at 05:45 PM. Reason: More 2 cents people I know I Love to hear my voice to much haha
    Jun 19 2014
    Jacksonville Fl
    Haha yes trust me if I hadnt got a great deal it would be a ghost. I've been trying hard resets since day one with no luck. Here is the results of the "see who's got red light test":
    TELE/BLUETOOTH- NO LIGHT
    CD PLAYER- LIGHT TO IT
    MMI INTERFACE MODULE- LIGHT TO IT
    GATEWAY MODULE- LIGHT FROM IT
    AMP- NO LIGHT
    RADIO- NO LIGHT
    DEAD END/NAV- NO LIGHT
    Here is the junk in my trunk sort of speak. I assume the navigation, if my car had it, should be in the lower slot and Im guessing thats why Audi just threw a loop connector in place on cars that came without it.
    [IMG][/IMG]
    Could someone walk me through doing a test with my loop connector? Do I simply replace one module with the loop adapter (leave the module plugged in electrically?) and try to perform a reset each time?
    06 650i M-Sport/ stock rocket
    01 740i Sport/ M5 goodies, loud
    07 A6 3.2 CVT/ cursed.
    May 02 2010
    Milford/ma
    Have you tried 3 button reset the mmi at all if so does it bring anything up like the optical test? And to make sure I got this right the mmi controls around the shifter are not lighten up at all during any of the test you perform?
    Jun 19 2014
    Jacksonville Fl
    Correct, the only button lighting up on the console is the E-brake switch. No MMI control buttons are lit up at any time. Pressing the three buttons for a reset does not get any kind of response. I have tried multiple times, even some in angry succession, and nothing happens.
    May 02 2010
    Milford/ma
    Man have you tried unplugging your MMI control panel and turning on the car? I am leaning towards the fact you said the blutooth was corssive I wounder if the panel got wet. I know if something got sticky they tend to turn off 3 seconds after being on I wounder if its fried. Unplugging it and turning on the car the rest should turn on for 15-20 seconds befor going into protect mode if I am right.
    Jun 19 2014
    Jacksonville Fl
    So you're saying unplug the actual control panel in the console? I could try that to see if the screen at least comes on.
    May 02 2010
    Milford/ma
    I know when they start to go the system turns on and off randomly and if they are really messed up I could see them telling to go into protect mode quickly. When you did the optical test you said the system came on for a few seconds that means it works and that it has to be one of the componets that is shutting it down; the buttons are the only things I can think of and they tend to get wet alot.
    Jun 19 2014
    Jacksonville Fl
    I suppose that would make sense, it does act as sort of a brain for the system. I'll pull it today and get back with the results.
    Jun 19 2014
    Jacksonville Fl
    I pulled the control panel and unplugged it with the key off. I turned the key on and the screen did not come on.
    Jun 19 2014
    Jacksonville Fl
    UPDATE: Im retarded, I didnt plug the panel back in, just the emergency brake. After plugging the control panel back in, the screen came on reading "Audi MMI" for about 15-30 secs then went off. I pressed the 3 buttons to reboot and sure enough, the screen came back on and did the same thing. I waited and did it a 3rd time, the screen did the same thing. I suppose thats progress.
    Jul 02 2013
    406, MT
    Any updates?? Did you have anything bypassed when the MMI splash screen came on?
    Not sure how you could have a car without music!
    Senior Member Two Rings Cobra357's Avatar
    Sep 13 2011
    VW Jetta
    Brooklyn
    I had a similar issue but it work when I place Audi updated CD in the cd player.
    ALL MOTOR 3.2...................
    Active Member One Ring AdamVanLewen's Avatar
    Jun 26 2014
    2002 Audi A4 3.0L quattro
    Lakewood, Co, USA
    Any progress since then? I just bought an '08 A6 Avant with nav and all of the other goodies. It's the main reason I bought the car. However, before selling the car to me, the dealership replaced the bluetooth module. Can this be the cause of my MMI to act up? It is intermittent, the buttons work rarely. Otherwise, it's unresponsive. It'll play the radio and I'll have to change the station from the steering wheel. I have an appointment at the dealer for them to look over it because they were the last ones to fiddle with anything. I've only had the car two days.
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by AdamVanLewen View Post
    If everything works (bluetooth, nav, radio, etc) then the issue sounds to be located in the MMI control unit itself. It is spossible it has been exposed to liquid; often occurs because of its location in front of the cup holder. Did you buy the car from an Audi dealership? I would take the car back and show them the issue and get them to fully diagnose and replace any malfunctionng parts.
    '09 C6.5 A6
    Jun 26 2014
    Lakewood, Co, USA
    Oh, I apologize. I forgot to mention that it only works when I first start the car. The buttons will work for a few minutes, then stop working. The radio can be changed from the steering wheel, but everything is frozen. During the drive or the next time I turn the car on it will immediately shut off. I'm wondering if anyone has had a fix for this issue. I just bought the car, I'd go mad if I had to put another $1000 or $1,500 into the damn thing.
    Jun 26 2014
    Lakewood, Co, USA
    Can a bad replacement of the bluetooth module cause this? The last thing the dealer did before selling the car to me was replace the bluetooth module. They (ever so generously) said they'll run a free diagnostic test. I hope it's their fault. That's a $15,000 pain in my ass if not. The problem is that my appointment isn't until March 3rd and I can only get a RWD Mercedes C Class as a loaner. I've never wanted a Mercedes, they're basic trash. Gah.
    Jun 26 2014
    Lakewood, Co, USA
    Audi had figured it out. When they replaced the bluetooth module, the programming wasn't done correctly (or something to that effect.) Now they just have to reprogram the MMI and it should work. Thankfully they're covering all of it. If I had pay for it, I'd kill myself.
