Results 1 to 22 of 22
    Veteran Member Three Rings tuner culture's Avatar
    Jul 19 2007
    1.8T Q 1+, Honda Odessy
    Florida
    Power Steering Fluid leak?
    Looks like i have power steering Fluid leaking, I was low, I filled it up, a week later it was low and a puddle was under the car....
    Does anyone Have ideas what could be the issue or the best way to trace the problem? Is this something that can be done on jack stands?
    Thanks
    2003 A4 1.8Tq
    19" RPM | Bridgestone Potenza RE960AS
    APR stage 1+ | Forge 007 | Kerscher | AWE | Race tec | RS4 pedals | S4 Grille |
    Dec 25 2004
    Earth
    Yes...
    The two rubber hoses going into the steering oil cooler tend to rott and leak...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jul 19 2007
    Florida
    Do you know where they are located? can i see them from top or crawl under?
    2003 A4 1.8Tq
    Dec 25 2004
    Earth
    Quote Originally Posted by tuner culture View Post
    Under left side....
    Jul 19 2007
    Florida
    thanks... will take a look
    2003 A4 1.8Tq
    Dec 25 2004
    Earth
    Leaks occur around clamps #27
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by MikTip View Post
    Good call. Mine was leaking from there. Changed out the clamp and all is well.
    Senior Member Three Rings johnwiz's Avatar
    Sep 08 2012
    2021 RS5, 2004 Audi A4 USP
    Leesburg Va
    +1 Had the same thing happen on our '01.
    2021 Ascari Launch Edition RS5, BC Forged RZ 21 (20 x 10 ET 22); 2004 Audi USP, B&B Sport Exhaust, VMR Rims, Stoptech BBK, Motoza Hybrid K04 Tune, ER Sport FMIC, Frankenturbo F21.
    Dec 25 2004
    Earth
    Thanks Old Guy!
    My two hoses actually dry rottted there and leaked...had to cut them back a slight and reattach with new new clamps.
    Jul 19 2007
    Florida
    Thanks! will check it out and let you know! Appreciate the help!!
    2003 A4 1.8Tq
    Feb 11 2014
    Dallas
    What side is it leaking from? I had a bad leak last year during the winter and Ordered a rebuild kit for the rack. Was a PITA, but leak is gone and didnt have to pay 800 for a new rack. set back a full day, so if that's the case with yours it can be done.
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    Thanks Old Guy!
    how hard was it to reconnect the lines after cutting off part of it? was there enough slack to reattach without much difficulty? i actually have a leak at both clamps right now. two weeks ago i had my mechanic do a timing belt job, and he actually removed the whole front end, versus service mode. i wonder if there was a possibility that had any impact on the leak?
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Apr 07 2011
    Should be plenty of slack to cut a small piece of the hose off. You can try some different clamps on there for starters before you cut anything.
    Mar 05 2013
    CA
    Quote Originally Posted by sinistervii View Post
    If you haven't already, please post info on the rebuild kit.
    Quote Originally Posted by BlazinB5 View Post
    The lines are not hard to work with at all. They're just rubber hoses held on by clamps, nothing special. IDK about slack as I have a 3.0, and I did end up being able to cut mine up (had to) to install a Magnefine in-line P/S filter, so you can do that as well if you want. I assume service mode and/or tampering with the hoses could cause a leak. For example, I had a poor connection/clamp-force on a coolant line. I jacked up the engine to replace motor mounts. That pried open the line a little, enough for coolant to leak. As soon as I put the engine back down, the leak stopped.
    Corbin-style clamps apply constant pressure. I don't believe this style does. So maybe the clamping force reduced over time and resulted in a leak. Any legitimate hardware store will have these clamps for a few bucks at most. Home Depot has them in "bulk", meaning no-less than a pack of 7 or something. I forget what section they're in, but its not in the section that has the bite-style. By bite, I mean the perforated ones that bite into hoses. Some employees know what they are, some don't (in case you ask them to help you find it). I assume Lowe's is like Home Depot in that aspect. There's also the dealer. I'm against bite-style clamps. I don't believe corbin-style clamps apply enough clamping-force for this application.
    AFAIK, front end removal or service mode shouldn't affect the P/S system, but maybe for some reason (I have 3.0, not familiar with 1.8T), he nudged (or smacked) the hoses or something so they leaked a bit - IDK. Or like MikTip said, they dry-rot/leak over time, and yours just happened to do that at this time.
    Jan 09 2012
    MA
    Just a comment on this. A used spark plug makes the perfect sized plug for these hoses if you need to disconnect them for any reason.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    A new power steering cooler with new hoses would be an inexpensive fix/upgrade. It should cool better and will increase the fluid capacity just a bit. A few feet of tubing and a couple of hose barbs are the only additional parts you need.
    http://www.summitracing.com/parts/hda-402/overview/
    2019 SQ5 Prestige
    Oct 17 2012
    Phoenix, Arizona
    Been dealing with a leak from that exact spot for a bit now after I put on the fmic. The hose clamp I originally put on when I was reconnecting punctured the line next to it so I had to cut it back some, creating a steep angle while the hose was still attached to the plastic hose retainer on the side of the frame going to the bumper crash rods. Freed up the hose and put on a new clamp becuase the old one broke and good as new. Was considering buying a replacement hose when I thought the angle couldn't be helped, and came across this: http://www.autohausaz.com/search/pro...0Return%20Hose
    About $80-100 cheaper than ones I found online for my vin, but it was under the 8D vin, so any idea if the bottom hose would still fit at the rack connection?
    Mine: 2002 Audi 1.8t CVT---cc mod, stern engine mounts, 710N DV, FMIC, soon to be motoza stage 1+ w/ 550cc and CVT->Quattro manual swap.
    Nov 21 2014
    Montreal
    Is this visible only from underneath the car and have to remove belly pan?
    I have a B7 A4 and I'm leaking a lot of power steering fluid. Soon as I fill it up, after a minute it loses most of it and starts making whining sound.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by AudiKilla View Post
    Yes and no. You can see the lines from the d/s engine bay. They terminate at the P/S cooling tube mounted in front of the condenser. You may be able to see them when you pop the hood. It's been a while since I had the OEM setup. I replaced mine with an aftermarket unit and AN lines that I adapted to the oem rubber lines. Good luck!
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Senior Member Two Rings jquattro's Avatar
    Oct 15 2011
    02_A4_1.8TQMS
    Oregon
    That picture was from under the car. Everything is easy to get to from underneath, for these two hoses.
    '15 S5 6MT
    Nov 21 2014
    Montreal
    Ya thanks I checked it out and they were fine. In my case it was the steering rack itself leaking.
    Apr 03 2016
    Up North
    That sucks man. I'm still on my original, but I've read good reviews of Rack Doctor for replacements: https://shop.rackdoctor.net/A4-SERIES_c65.htm
