Ok - first can anyone confirm what the exact dims are for the stock OEM wheel lug bolts on the post-facelift S5 (if that males any difference)?
Are they 14x1.5 R14 ball seat 17mm hex with 27mm shank ?
If so, the OEM ones fitted are the open top type but I want to get the closed/solid type. The problem is that the 20" Niche Targa wheels are about 3mm thicker than the 18" stock wheels and so I don't get the same amount of rotations to torque the bolts fully. Now 3mm may not be much but I'm hoping I can get some longer shanks and was wondering what size would be suitable?
Assuming the OEM are 27mm shamks and I need another 2/3mm (= 29/30mm), and if I can only get 32mm long shanks, will that be an issue? Do shanks that are a couple or so millimeters longer make any difference eg will they bind?
