Results 1 to 18 of 18
    Active Member Two Rings KStartz's Avatar
    May 26 2014
    Somewhereville
    Change water pump without removing front end?
    Is this possible for the A4 B5? Has anyone done it? Does anyone have any opinions IF it is possible? Thanks!
    Oct 30 2009
    Miami, FL
    Yes.
    2018 S5 Coupe - stock for now
    Apr 12 2013
    San Diego
    It might be possible if you have small hands and a lot of patience but the lock carrier is designed to be [relativeliy] easily removed for service on the front of the car. Swing that out of the way (you can leave the AC lines and stuff attached) and you can just sit down right in front of the motor with everything at eye level. It's actually almost comfortable. Beats the hell out of leaning over the bumper and trying reach down for everything or getting on the ground and reaching up.
    May 26 2014
    Somewhereville
    That's good to know. I've looked around online, but I'm still scared to tear into it to that degree. Are the water pumps designed to leak when they're about to die? Mine is not, and I'd like confirmation before I spend the time/money...but on the other hand, I have changed all cooling system components except for the pump and thermostat and the car still overheats when stopped.
    Apr 12 2013
    San Diego
    If you're scared to pull the front end off, you're really not going to like changing the water pump. I'd try the thermostat first.
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Possible? Yes. Realistic? No.
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Oct 30 2009
    Miami, FL
    You do realize that you have to take the timing belt off the change the water pump and thermostat in the 2.8? If you're afraid of pulling the lock carrier off you should probably stay away from the timingbelt. If you do decide to tear into it, don't even think of doing it with the lock carrier in place because that's just asking for trouble.
    Not trying to be discouraging, but the 2.8 timing belt is a whole lot more difficult than the 1.8t.
    Dec 05 2007
    I changed the tb tensioner without removing the front clip or placing car into service position. Most PITA job I have done on my car. So the WP isn't just possible, but also very doable. Would I suggest you do it, though? Nope. If you are asking this question there is a good 98% chance you will f*ck something up to the point you will end up placing the car into service position anyways.
    May 26 2014
    Somewhereville
    I should have specified that messing with the belt is my concern, not so much removing everything to get to it, but I guess the responses and end results would be the same X_x haha
    Dec 05 2007
    What year and engine is your car?
    May 26 2014
    Somewhereville
    2001 Audi A4 Quattro V6 2.8L 30V
    Dec 05 2007
    I would listen to Mad Cow on this. Don't have any experience. Mine was on a 1.8T and was the most PITA job I have done on my car. And I have done a few.
    May 26 2014
    Somewhereville
    Dang I have a new fan clutch, I'm pretty sure my radiator is not clogged, there is no air in the system, and the auxiliary fan is working fine. Am I missing anything else that might cause it to overheat?
    Dec 05 2007
    Cooling sensor. Car isn't really overheating. But incorrect readings from a sensor will say that you are.
    Mar 17 2014
    2000 gmc sierra
    Ontario Canada
    I did my 98 2.8 tb water pump without takin front end off and I did my 2000 1.8t tb water pump without takin it off to and I didn't think it was that bad to do. Just unbolt it and pull the front clip ahead you get three four inches, and I got big hands and arms
    Dec 05 2007
    I am thinking service position versus nothing at all. Not front end removal.
    May 26 2014
    Somewhereville
    I replaced the cooling sensor a week or so ago as well.
    Dec 05 2007
    Oh!
