Results 1 to 24 of 24
    Feb 24 2011
    Derry, NH
    4.0TSFI Throttle Lag Solved
    I don't post on here as much, but wanted to try and spread the word: those of you with S6s (particularly 2013s, but also some 2014s) may have observed a pronounced throttle lag, most noticeable when trying to accelerate from a rolling stop (i.e., slow for a red light, turns green before you stop). This issue has become increasingly annoying to me over the past year, and numerous complaints to my dealer (as well as trying things on my own like replacing the brake sensor switch) hadn't helped.
    I had my 15k service the other day, and on the way to the dealer the car threw the EPC light. I shut it off, turned it back on, and it was gone, but I mentioned it to the dealer when I arrived (along with reiterating my complaint about the lag issue).
    My SA called me later that day and told me there was a TSB for a software update to the ECM to address the EPC light which would also correct my lag issue. I was doubtful of the second claim, as I hadn't heard anything about it in any of the forums. However, to my surprise, it WORKS: the throttle lag is now completely gone. Word is that your car must throw the EPC light (thereby causing a DTC to register) before AoA will pay for this update, but I think those that are persistent may get it done even without throwing the code.
    I'm posting this here because if you're experiencing this, you know how frustrating it is to have a car that is 99% perfect, but with one nagging issue that completely ruins the driving experience. Good luck.
    http://www-odi.nhtsa.dot.gov/owners/...nK!-2015685618
    Service Bulletin No.: TSB-01-13-36
    Component(s): ENGINE , FUEL SYSTEM, GASOLINE NHTSA ID Number: 10054273
    Manufacturer: Volkswagen of America, Inc.
    SUMMARY:
    AUDI: SOME VEHICLES ENGINE WARNING LIGHT SPORADICALLY ILLUMINATES, WOULD HAVE REDUCED PERFORMANCE WITHOUT LOSS OF POWER/STALLING OR NOISE COMING FROM ENGINE COMPARTMENT DUE TO LOW SYSTEM VOLTAGE, AND NOT ENOUGH ON/OFF RATIO TO KEEP FUEL METERING VALVE CONSTANT IN ALL AREAS, THE ENGINE CONTROL MODULE SOFTWARE NEED TO BE UPDATED. MODEL 2013-2014 S6, S7, A8, S8. *PE
    Note: my dealer also referred to this as TSB 2035235/2.
    2016 Cardinal Red Mercedes Benz C63 AMG S
    2018 Navarro Blue Q5
    *HEX-USB+CAN VAG-COM Available for those in Northern MA/Southern NH: Will Mod for Beer!*
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    TSBs should be free of charge under warranty. Just bring the number up if you're also having this issue and it should be done for free.
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Feb 24 2011
    Derry, NH
    Quote Originally Posted by Fourplay View Post
    TSBs are only free of charge if you meet the specific criteria. My point is that there are many people who are complaining about this lag that have NOT thrown the EPC light, which apparently is a condition of the TSB (on the full version that Audi uses).
    Veteran Member Three Rings Packy's Avatar
    Dec 12 2011
    2009 Audi A4, 66 Corvair Corsa Turbo (future project car).
    Arizona
    Quote Originally Posted by nobbyv View Post
    2 nagging issues, the heads up display rattle!! Well, those and the fact nobody will stop light drag me. Cowards!!
    2013 S6, 2009 A4,
    Senior Member Three Rings Pip's Avatar
    Aug 31 2010
    Singapore
    Quote Originally Posted by Packy View Post
    Mine too !!! Cheap plastic covering the HUD projector ! *Faints !
    2013-Current
    AUDI S6 C7 | 4.0L TFSI | Quattro | S-Tronic | Phantom Black
    S6 Air Suspension | Lowered 17mm | K&N E-1983 Air Filter | VOLK G25 20 x 8.5j et 36 | PSS 255/35 R20
    Eurocode ÜSS Stabilizer Bar | Eurocode ÜSS Billet Aluminium End Links
    Jul 27 2013
    Australia
    The rattle on the head up display has a dealer fix. Mine was fixed last time it was in. I also have a rattle from the rear auto blind when its down and I play music load. They have ordered parts to fix this. The centre speaker cover rattles on coarse roads but they don't have a fix for that yet.
    I too have the ongoing problem of no one prepared to give me a go at the lights - hard to fix that one
    Jul 27 2013
    Australia
    I used these referenced TSB's but they said they were not for my car. Maybe different codes for different countries. The good news is they did 2 updates (one steering response the other engine/transmission) and I think they got it. Need to do more driving to be sure but it feels a lot better including they way it takes off from a stop now.
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    Quote Originally Posted by dannybear View Post
    Would love to know what parts they're replacing. The last time I complained about it, the dealer said sorry they can't fix it. I've since started going to a differenct dealer for service, but it's a 20 mile drive instead of 5 -- not normally a big deal except I usually have to go during rush hour and in the opposite direction of work.
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Jan 21 2014
    2014 Toyota Sequoia Platinum Black
    Cummington MA
    My 5K is coming up and this is my only complaint, glad to see that I am not alone here. Going to make sure ahead of time that they are ready to fix this.
    FYI, mine only makes noise at specific temperatures and then only at certain speeds, usually 30-45ish. I had no faith at all that I would be able to reproduce this at the time of my 5K so I am glad to see that it is known and documented.
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    To be clear this TSB will only apply if you've seen your EPC light come on and a fault code was thrown. Otherwise they won't apply it.
    Of course you could try saying you saw it and cleared the fault code and they might be willing to allow it.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Senior Member Two Rings TunTap's Avatar
    Oct 17 2013
    LA
    I took the car in and tried convincing the service dept. into applying the tsb, they said the same thing - they won't do it unless there is a code. I hate the throttle lag on these cars, especially paired with a wandering gearbox that S-tronic is unless you're already moving at full throttle.
    '05 S4 Avant
    Gone: '13 S6 | '14 SQ5 | '13 S5 | '11 Q5 | '06 A3
    Jul 27 2013
    Australia
    After almost having another accident due to the throttle lag I took my new s6 to the dealer again AND told them its in because I almost had an accident and I am scared. They had available and done two updates, one to adjust steering weight and the other listed for engine/transmission. The change is significant. In the past (not in sports mode) you could really feel the clutch packs engage from a dead stop similar to a beginner driving a manual as such I would often take off in sports mode. Now it feels more like a typical auto. However the biggest thing is it feels like its more responsive after slowing down but not stopping and I think the throttle lag is gone. Need to do some more km's to be sure. Still have the expected reduced power until the revs pick up but haven't been able to repeat the zero response I used to get.
    Oct 17 2013
    LA
    Could you share which updates they performed? Should be on the repair order. I've been in the same situation trying to make a left hand turn and nothing happening.
    '05 S4 Avant
    Jun 09 2013
    Those sound like older TSBs, not the throttle EPC one.
    - Chad
    Mar 28 2014
    The Big Apple
    I brought my car in last Thursday and after driving it all this weekend I can confirm that the lag is essentially gone. They said the TSB doesn't apply to my VIN but they called Audi TAC (Technical Assistance Center?) and was told to apply software update 24702599. This update, plus the other one that fixed the harsh downshifts in sport mode, have now made this car perfect.
    Jun 09 2013
    Quote Originally Posted by turbonator S6 View Post
    That was a different one that should have solved harsh downshifts. Though the original OP TSB doesn't really apply.
    - Chad
    May 19 2010
    Cypress, Texas
    It would be nice when everyone talks about these issues if you would also post your cars build date. It's easier to keep track of cars based on build dates then it is to say it's based on your VIN. Most don't know their VIN but most would remember their build date. And most TSB's that are based on VIN numbers usually coincide with build dates.
    Just my $.02
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    I have been having rough downshifts too but its on my A6. I guess I will have to get it flashed back to stock and take it in.
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    Quote Originally Posted by agent47 View Post
    Not to thread jack...but i've noticed my downshift to 3rd upon acceleration feels a bit harsh it lurches forward ..almost like the feeling you get when you downshift 2 gears.
    It may be normal but it's just not a smooth transition when you're giving it some gas and picking up speed.. Is that what you're describing?
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by 07S6 View Post
    You nailed it. Thats what happens on my A6. Last evening on my drive back home, I was driving like a dbag coz of the shitload of traffic. Swiping down into the right lane and nailing the gas, hitting triple digits often. But the downshifts were noticeably rough.
    Jul 27 2013
    Australia
    I rang the dealer to try determine the two updates codes that were done on my car as it appears to have fixed the throttle lag. One update was an older recall for the steering weight (I asked for a tsb number and was told recall 48k8)? I was told the engine/transmission shift update was not a recall and had no code but they contacted and connected my car to Audi h/office and addressed my concern of the throttle lag and 2 near accidents. Sorry but that's all I got and I don't have the paperwork until they close my job sheet at the end of the month (waiting for a special key from Germany so they can fix the squeeling brakes).e/transmission shift update was not a recall and had no code but they contacted and connected my car to Audi h/office and addressed my concern of the throttle lag and 2 near accidents. Sorry but that's all I got and I don't have the paperwork until they close my job sheet at the end of the month (waiting for a special key from Germany so they can fix the squeeling brakes).
    Jul 17 2014
    South Lyon, MI
    Thanks to maherladki's attached bill with the TSB number(from audiworld). I asked my service manager to look into this throttle lag issue as at times my car takes its sweet 1 sec to respond when i kick the accelerator. He not only did TSB 2035235/2 but also bunch of others. TSB2039267/1, TSB2036392/3
    I am 100% sure now, the throttle lag is gone and the transmission shifts much more faster to lower gears even in Auto mode. The car now is more fun to drive.
    I am not sure if there is any update done for the steering too as it now weights right at high speeds.
    Senior Member Four Rings eyeloveteeth's Avatar
    Jan 07 2015
    weed wacker, lawn mower, some tools, air compressor
    NoVA
    Quote Originally Posted by tarunck View Post
    interesting, i'm 650 miles in now, and i've thought it odd that sometimes i feel like the steering seems overboosted. maybe i need to ask them about this.
    I've also noticed the lag, but always attributed to just turbo lag and non-aggressive shift pattern from 1st to 2nd. Thanks for the heads up!
    Jul 17 2014
    South Lyon, MI
    Quote Originally Posted by eyeloveteeth View Post
    Its definitely not turbo lag as i can see a lot of difference now. The throttle response is more instantaneous and also the transmission shifts are butter smooth even in Dynamic and all the harshness(4-3, 3-2) is gone.
    I agree with the overboost for the steering and I wouldn't say its day and night difference but its good and get bit more tight with speed. I still doubt if there is any specific update done for the steering or if its just my feeling.
    I think these updates are valid only to 2013 and early 2014 models. But you can check with your service guy.
