Results 1 to 12 of 12
    Dec 18 2012
    Winnipeg, MB, Can
    Interchangeable 4.2 ngines
    Hi guys, i've been searching for a bit tonight interchangeability of 4.2 engines and haven't found much other than: http://www.audizine.com/forum/showth...4-2-aka-A8-4-2.
    Do we have a definitive list of chain driven 40v 4.2's that can be swapped into our b6/b7 s4's?? I would like to know what other chassis' a 4.2 longblock can be pulled from and still plug & play.
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    Here's some reading material>>>http://audirevolution.net/forum/index.php?topic=487.0
    I wouldn't say any Audi engine can be called 'plug & play', any engine swap involving complex electrical systems are going to have some issues. Depending on your reasoning for doing a swap, you have tons of options. If you want to stick to the MPI 4.2, then the only sensible options are to send it to JHM or find another B6/B7 S4. Using an FSI engine is going to get very expensive, so you'd probably better off with the JHM option. An A6 or A8 4.2 could be swapped in, but you're going to run into little issues that make it a hassle, and end up with less power. Conclusion, any of these swaps could be done(as well as 4,5,6 etc. cylinder engines, but that's another topic) , but the only sensible thing would be to find another BHF or send to JHM.
    Biggest thing is, why are you considering a swap?
    2004 Light Silver 6MT S4
    Dec 18 2012
    Winnipeg, MB, Can
    You have basically answered the questions that I had. My reason for asking the question is to know what longblocks can directly drop in while still using the s4 intake and wiring etc, (IE no custom work). So I had thought that the A6 and A8 block+heads could potentially be interchanged even if they weren't a BHF.
    I have no intention of swapping another engine to achieve higher power or any other function; just simply thinking that in event that I stumble across a great deal on an S4 with a blown engine or head, I would like to be able to open up my engine search to the widest search field possible!
    Veteran Member Three Rings vacsimile's Avatar
    Nov 15 2008
    2004 Audi S4, 1991 Nissan D21, 2001 GTi VR6
    Outer Space
    Just know that this engine never appeared in A8's, as they went directly from the belt-driven MPI engine to the chain-driven FSI engine. Well, here in the states anyway... Not sure about Canada or anywhere else. B6/B7 S4's, C5 Allroads, and C6 A6's were the only cars to get this engine.
    Dec 18 2012
    Winnipeg, MB, Can
    After continuing to read more, I am starting to come to the conclusion that you can only pull a BHF replacement motor from a B6/B7 S4. Nobody seems to be convinced that the BHF or anything similar enough for direct swap can be pulled from any other vehicle. I'm surprised!
    May 13 2008
    MQBs
    San Francisco
    A6 4.2 SHORT block can be utilized. Obviously a little bit of work is required to mate it up, but nothing too crazy.
    Past: B7 S4 Avant | Glacier White 8V S3 Build ig: @harithalbadri
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Can the b6 s4s use the 4.2 out of the 2nd gen s6?if so could the jhm supercharger work with it. Supposedly the internals in that engine can handle more power than the b6/b7 engines
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Id consider donating a left nut to science if someone put a v10 from an s6 in here....
    Veteran Member Four Rings gcoy's Avatar
    Apr 06 2009
    2005 B6 S4 6mt Avant & 2001 B5 S4 6mt Avant (Sold) & 2007 VW Passat 3.6 4Mo wagon
    Boise Id
    Holy !@#$% ^^^You Crazy^^^
    Senior Member Two Rings thomasskull666's Avatar
    Feb 11 2013
    St. Louis, Missouri
    I'd donate my right nut so we could make a man to drive that crazy contraption
    2007 Daytona Grey RS4
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by S4orgy View Post
    No, the ANK/AQJ engine is fairly different. Similar in a lot of it's general design ie. (chain driven cams, 4.2 liters, 5 valves/cylinder etc.) but too different for it to work.
    Nov 11 2008
    Or better yet could we use the pistons and rods of let of the 2nd gen s6/or rs4?
