Results 1 to 25 of 25
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Oil filter compatibility
    So as far as I understand, there are two versions of the oil filters for the 1.8T, the standard filter and a larger version of the standard filer. Apparently both filters are compatible with the engine. I've been doing my own oil changes for 6 years with the standard oil filter without any issues. This time though, I ordered the larger filter and could not get it to fit. The opening on the filer was larger and would not screw onto the engine. What gives? I had a similar issue a few years back when I mistakenly bought a Mobile 1 M1-303 filter instead of the M1-301 filter. The M1-303 version looked exaclty the same as this larger version and I had the same issue with it. The guy in this DIY is using the larger filter that Im having issues with and doesnt have any issues. So what am I doing wrong?
    P.S. I feel like an idiot asking this question, this feels so trivial.
    RS4 Rear Sway :: KW V1 Coilovers :: B5S4 Calipers :: W&L Catalytic Converter :: 30% black tint :: S4 Door Blades
    Senior Member Two Rings 00passat's Avatar
    Jul 31 2012
    2005 Gmc sierra 2500hd 6.6 dirtymax
    Lancaster,ca
    What is the part number of the filter that doesnt fit? I know my b6 a4 wont fit a napa 1333 , but they will fit my passat, due to the length.
    Dec 25 2004
    Earth
    Wrong thread pitch....
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    May 28 2008
    2005 A4
    Quote Originally Posted by MikTip View Post
    Im unfamiliar with that term. Is that the spacing between each of the grooves?
    May 28 2008
    2005 A4
    Quote Originally Posted by 00passat View Post
    Its a MANN oil filter and the part number listed on the box is W940/25.
    Veteran Member Three Rings NathanGrayW's Avatar
    May 17 2014
    Akron
    Quote Originally Posted by ApexIt View Post
    Yup, the pitch is the distance from peak to peak.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    I've used the huge Mobil filter before. I think it cross links to a big American V8 engine
    Aug 26 2005
    The MANN W940/25 is the correct filter for the 1.8T, and has a 3/4"- 16 tpi pitch thread, according to the MANN oil filter catalog. Make sure the threads on the oil filter mounting flange base are not stripped causing the filter to not tighten up.
    Vorsprung durch Technik
    Dec 25 2004
    Earth
    I had an OEM Audi fiter once which could not thread onto the filter mount on the car....
    While "rare" it is possible the threads on the filter can get damaged or were not properly formed when the filter was manufactured...
    Only happened to me once in 30 + years of changing my own filters!
    Closer examination on the threads should reveal the problem...which will be the threads are wrong or not correctly formed
    To allow the filter to thread onto the protruding pipe end on the car.
    Easy fix....get another filter. However no one expects not to be able the thread on the "new" filter and generally dont carry spares.
    Or the threaded pipe end on the car has damaged threads....
    The "starter" thread is usually the issue....
    Veteran Member Three Rings g huns's Avatar
    Aug 13 2012
    Lexus RX350
    Wakarusa, Indiana
    Wonder why. I use the 1333 on mine and it fits by a mile. It's longer than a Mann 940/25. I was thinking about ordering a few Mann 940/4 which are even bigger than the 1333.
    Is your B6 a front wheel drive?
    2012 A6 3.0 Premium Plus w/Sport Package
    May 28 2008
    2005 A4
    The threads are fine and I never had any issues with them. On all my oil changes the filter smoothly glided on the threads without any resistance until it was fully mounted. The issue isnt with the filter tightening up but rather the opening on the filter is larger than the piece that sticks out on the oil filter mounting flange. The opening on the filter itself seemed so large that I could push the filter up on the mounting flange without the sides touching the piece that proturdes out from the mounting flange. Its not an issue with it not threading on or not tightening on. Does that make sense?
    May 28 2008
    2005 A4
    Quote Originally Posted by g huns View Post
    Yes, the car is front wheel drive. Did the FWD varaiants of the A4 differ in respect to the mounting flange?
    Aug 13 2012
    Lexus RX350
    Wakarusa, Indiana
    I can't imagine they would be different. The FWD just has less room for the longer filters due to the transverse mounted engine.
    If it's a 940/25, it has to be defective or improperly labeled. Measure the hole in the filter, if it's bigger that 3/4 of an inch, then it's not a 940/25
    Mar 14 2014
    North Texas
    what?
    __________________________________________________ ____________________________
    2003 Avant 1.8T 5spd - Silver / Motoza Stage 1+ w/ 550 injectors / Valeo HD clutch kit
    Koni FSD + Hotchkis Sways / 034 snub bracket and mounts / USP lower
    2005 Allroad 2.7T 6spd - Atlas Gray / Motoza Stage 1 / Hotchkis Sways / BC Racing coilovers
    Aug 13 2012
    Lexus RX350
    Wakarusa, Indiana
    Quote Originally Posted by 5spdJunkie View Post
    what?
    Don't mind me, just having a dumbass attack.
    TTs have the engine turned the wrong way.
    Apr 07 2011
    LMAO!! At least you caught your mistake.
    Established Member Two Rings 2stroke's Avatar
    Jun 01 2009
    SWEDEN
    Exclamation FYI
    FYI
    Here comes some OIL filters that fit the Audi/VW 1.8T engine perfectly.
    Smallest ( 1 ) to Biggest ( 4 ) in oil volume:
    1. * VW/Audi part # 06A 115 561 B ----> MANN part # W 719/30
    2. * VW/Audi part # 068 115 561 F ----> MANN part # W 940/66
    3. * VW/Audi part # 074 115 561 ----> MANN part # W 950/4
    4. * VW/Audi part # 068 115 561 B ----> MANN part # W 940/25
    // Regards from Sweden.
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    oil filter large version from audi only cost u $9 same filter work just fine for my audis with 1.8t 2.8 3.0 and 2.7t
    Jul 31 2012
    Lancaster,ca
    No mines a quattro, the filter hits the engine mount ,when trying to screw it in, so i used a mann 940/25 if i remember correctly.
    Aug 26 2005
    The filter mount flanges are the same, because both engines are AMB specification code. Also, AMB = longitudinal orientation. The AMB has no transverse installation orientation.
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Can someone verify he thread? Was expecting a metric thread size!
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by vtraudt View Post
    It is the correct filter for a 1.8T. Clicky clickŪ
    Feb 20 2010
    Brighton, MI
    Link does not state the THREAD (is it really "1.8T, and has a 3/4"- 16 tpi pitch thread" considering metric car?)
    05 Golf TDI
    Dec 28 2006
    Western Maryland
    Feb 20 2010
    Brighton, MI
    Thanks Old Guy!
    Filed for safekeeping.
    Who would have thunk!
    05 Golf TDI
