hi all,
a month back my car got stuck win an 'Econ' mode and I ran VAGCOM to find that I have a 00819 issue.
Following online instructions I have replaced my G65 sensor but the issue did not go away which leads me to believe it may be a refrigerant issue. As I have no idea where refrigerant resides on my car, I have decided to turn to you fine gentlemen.
My car is 2007 Audi A4 2.0TQM S-line Titanium
running VAGCOM i have a:
2 Faults Found:
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
09-00 - Adaptation Limit Surpassed
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
the first issue only arose after i went into basic settings of VAGCOM, while the other was the reason why i went into the basic settings in the first place.
my pressure measuring blocks are the following:
A/C Valve (N280) current is 0, so is the duty cycle
High-Pressure signal (G65) is 9.5%
Refrigerant Circuit pressure is 1 bar
Any help is greatly appreciated.
