Originally Posted by
BBear
Thanks for the summary. I did some of my homework around the options and this is what I think I have learned:
1. It seems like this would be used, no new parts on the market? And if I understood this correctly, I would need to buy used parts from MMI AMI 3G cars? Price range around $450 and I would need to replace the CD changer with the new AMI?
2. New/used parts on the market. Their website lists nultiple options for my car, although not clear what the differences are. Approximately $500 to $600 solution.
3. Xlink USA website was down yesterday? Weird.
Did I get this right?
You have it all basically right.
For the AMI you will need the following:
the unit : Part no 4E0057785F
CD removal tool : 4D0051530
ipod connector cable : 4F0051510L
If you are removing CD changer in the glovebox and replacing with AMI, you shouldn't need anything else. Just unplug CD changer and plug in AMI. If you are keeping CD and adding AMI next to it, you will need power wiring harness #4F0051592A and fiber optic adapter #4E0972645. These are basically splitters that you plug into back of CD and AMI together then they plug into car. These can be found on ebay and such for as cheap as $250 or so.
If you go with the Dension 500, make sure it's the correct one - GW51MO2. They sometimes can be had for under $350
For Xcarlink, here is the one others have used:
http://www.xcarlink.co.uk/product.ph...8&cat=4&page=1
Good luck and as RJB linked to, the enfig install vids are EXCELLENT tutorials.
Lastly, RGB appreciate the props :)
