First post. I've never seen this idea anywhere, so thought I'd share.
So I found this out the hard way: when you install an aftermarket head unit (non-Bose), the front speakers are powered from the new head unit. The rear speakers are fed from the pre-amp outs. The stock head unit has 10 volt pre-outs, so if you install something with even 4volt outputs, its still way low.
You can purchase the enfig adapter thats about $99 and will fix the issue.
Or you can do what I did.
The key is purchasing a unit that has a subwoofer line-out and allows the subwoofer level to be controlled and have full range outputs.
I installed a Kenwood DPX-500BT. It has pre-outs for front, rear, and Sub. So, install whole things per usual. Then hookup the rear speakers to the sub out. You'll have to crank the subwoofer almost to max, and keep it at default setting for 'full' range output. Volia. Works good. You do lose fader control, but you can adjust the rears manually using the sub level output.
Hope this helps someone.
As a sidenote, I hooked into fuse 5 which comes on in key pos 2, but not 1. I am yet to find a fuse that is switched to ACC or key position 1. Anyone point me to specifically which fuse is switched to position 1, I'd greatly appreciate. The red wire coming off the speedo cluster...Im not sure which one its switched for.
