Results 1 to 4 of 4
    Established Member Two Rings FrozenCommunist's Avatar
    May 30 2014
    Does Audi MMI charge the iphone 5S?
    Quick question for someone out there who may know the answer as Google has yielded mixed results.
    Will the Audi MMI connector cable charge the iPhone 5S? The cable that came with the car does not fit my iPhone (need a lightning cable adapter) so I can't test it out. However, before I go out and buy an adapter, I want to know whether or not it will actually charge the phone as this would likely affect my decision to even go out and get one.
    Thanks.
    Dec 23 2013
    Yes, but slowly. I don't know if its 0.5 or 1 amp, but if you are using the iphone for nav it basically charges enough to keep it at the same battery level. If you need to charge it quickly, get a cigarette lighter adapter. http://www.amazon.com/gp/product/B0088U6OZY
    2011 S4 Prestige | Ibis White | Black/Silver Nappa | DSG | Sport Diff | B&O | Nav | 19" Peelers | Roc-Euro Intake | LED Conversion | Supercharged Badges | VAG COM | BlackVue DR500GWHD | Passport MAX
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    yep it does charge with the lightning adapter cable. I use a cig adapter instead to charge, get the kensington one, it will clear the ashtray door when the cable is unplugged.
    .http://www.ebay.com/itm/Kensington-U...item56583a8dd0
    There are 10 kinds of people in this world, those who know binary and those who don't.
    May 30 2014
    Thanks for the reply guys!
    2014 Audi S4 : Ibis White : Black/Brown Interior : Navigation Package : Rear Parking Sensors : Fuse #5 (SoundAktor) Removed
