Results 1 to 40 of 42
    Active Member One Ring sambi's Avatar
    Jul 28 2011
    Collierville, TN US
    Temporary fixes for torn Front Bumper
    Not a great way to start vacation but things happen.
    Got to the hotel and while parking the car torn off the front bumper. Both sides are now detached supported only by screws in the middle.
    I am 6hrs away from home and need ride for next 3 days of vacation. Any ideas for temporary fixes.
    Pictures:
    Veteran Member Three Rings Vittorio's Avatar
    Jan 19 2012
    Boise/Idaho
    Not sure if this would work without being able to see it in person, but from the looks of it you could use zip ties to hold it up.
    Sent from my Nexus 7 using Tapatalk
    2006 Audi A4 Quattro 2.0T FSI
    Established Member Two Rings redcon1's Avatar
    Oct 22 2009
    '99.5 GTI VR6, '13 Touareg Sport V6/FSI
    South Central PA
    Yep, small drilled holes and black zipties FTW. I've done it defore and you can barely see them, provided evertyhing lines back up.
    Dave
    2013 Touareg Sport V6 FSI
    2000 BMW Z3 2.3
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    ^all of this Zip ties are your best friend
    -Chadwick
    FULLY BUILT ENGINE!
    Veteran Member Three Rings Noel Artiles's Avatar
    Jan 12 2009
    2011 E90 M3 , 2006 B7 Audi A4, 2016 Chevy Suburban LTZ
    Miami
    This has happened to me before after encountering a slightly high parking bump. You can just push everything back on and it should be fine. I drove around a week with my bumper ripped along the sides while I waited for my new parts and it never flew off . For added safety zip tie like mentioned above. Freaking sucks.
    Jul 28 2011
    Collierville, TN US
    Thanks for your help guys.
    Pushed it back and used couple of zip ties. I am back home with no issues and it is holding the bumper pretty good.
    Now comes the $$$ part, multiple options:
    1. Go to dealer and claim it with insurance
    2. Classifieds or ebay for used part (No repainting)
    3. Explore options to see if existing bumper can be repaired.
    @Noel, How did you fix your bumper?
    Jan 12 2009
    Miami
    OE bumper brother, nothing like it. I would take advantage and order something better like s-line or DTM if you can. After market bumpers won't really have the same fitting. Paint shouldn't be more than like 250-300+part cost.
    Established Member Two Rings seco007's Avatar
    Jan 06 2013
    Omaha, Nebraska
    Something similar happened to me not that long ago....I went to a body shop...they patched me up for 20 bucks.....maybe you can look at some around your area.....
    BEFORE (hit high concrete barrier at parking lot)
    AFTER
    Jan 12 2009
    Miami
    I think his bumper might not be salvageable as the seam along the top side completely detached and it's pretty long. Only way I can think of them fixing it properly would be to plastic weld that baby. If you are on a budget and your a little brave you can always plastic weld it from the inside yourself. They have joint mesh and you should be able to weld it together pretty easily.
    I have this one and it works well:
    http://www.harborfreight.com/80-watt...kit-60662.html
    Rods:
    http://www.harborfreight.com/50-piec...ods-41602.html
    Might be overkill but this works as well:
    http://www.harborfreight.com/plastic...ent-96712.html
    Jul 28 2011
    Collierville, TN US
    Quote from Dealer body shop is $1460 minimum.
    @seco007, your's seems like small detach, mine was torn-off under headlight as well. Will check local body shops to see if they can patch me up.
    Jan 12 2009
    Miami
    Rip off dude, I think I paid like 500 for bumper and 200 for paint using OE parts.
    Jan 19 2012
    Boise/Idaho
    There are so many options. I would definitely look into buying your own parts and doing it yourself or finding a good shop to do it much cheaper.
    You should use this as an excuse to upgrade your bumper.
    Sent from my XT1060 using Tapatalk
    Jul 28 2011
    Collierville, TN US
    Took out the side panel screws over the weekend to analyze the damage and found that most of the nuts are in place. Pushed bumper tabs back into the position and put the screws:
    Seems like it will hold on pretty good.
    Missing parts:
    - 3 bolts underneath the bumper. (will order OEM parts for this)
    - missing bolts to the two white screws on the passenger side (tried 1/4" bolts with 12 mm socket but it didn't fit) any ideas?
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Dude take it off and support that entire side tab with like 10 sticks of jb weld before it rips off completely. That is the only thing that can be used ot hold the bumper at the correct angle. Otherwise it keeps popping out and only those tabs on the side are the only thing holding it in.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    May 21 2011
    Ca, fontana
    Use zip ties to pull the bumper back more and make it look more even to the body. I just ripped mine off when I went to close to a sidewalk and pulled away. I had help pushing the bumper into place and used zip ties inside the bumper to hold everything together. I used multiple sizes though to make them not noticeable on the outside of the car.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Quote Originally Posted by alexisprz View Post
    I don't get it where the hell did you put the zip ties i had no idea where to put them to hold it in.
    Sent from my C5306 using Tapatalk
    Ivan
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by Noel Artiles View Post
    Rods:
    Has anyone tried plasting welding? I ripped my bumper off a few months ago and it broke those side tabs completely off. JBWeld wouldn't hold it back. ^_^
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Jan 06 2009
    The B7 that I just picked up had it's bumper torn off by the previous owner. I picked up THIS 3M adhesive and will be trying it out on the weekend in order to re-attach the ripped off tabs.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    I used JD weld on both sides and they are still holding up. Knock on wood
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by Copen-cisco View Post
    Quote Originally Posted by ADCS View Post
    Let me know if that works. The JB Weld I used wasn't durable enough. It just didn't get enough bite into the plastic and always ended up snapping back off.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    JB weld didn't work for me. So i designed my own fix. Quik Latches
    http://www.quik-latch.com/
    put one on each side, and now the bumper is secured but i can remove it super easily, takes me like 30 seconds
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by JDillon15 View Post
    I did jbweld and after about 6 months it all broke, so i sanded it all off and plastic welded. Got a really good firm hold and it held up against me pushing/hitting it from various angles.
    Only downside is i heated up the bumper a bit too much and there is a slight dip in the outside now that is visible, but that is much better than having a bumper broken off.
    BUTTTTT since then the plastic weld has also broke in the middle of itself (still attached on bumper and bolt, just plastic weld broke in the middle)
    -James
    May 20 2014
    e92
    Jb weld failed, plastic weld failed. My passenger side bumper is completely torn at those two 10mm nut holding piece.
    Now I am going to try lord fusor 143 with some mesh. If it doesn't hold, quick latch it is. Mec, I will need to replicate the latch system.
    Jul 11 2014
    Chicago, IL
    You know, I would love to see a photo of that. Only one side is broken for me, but I kind of like this idea.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Go on my YouTube channel, pretty sure I. Have a video of it that I titled "fastest record b7 bumper removal" otherwise I can snag a picture this weekend.
    Sep 06 2013
    Dublin, CA
    I looked into that when I broke mine - I actually reached out to Mec for that. Decided to go with JD weld first to see if it would stay on.
    In my search for references I bookmarked this Youtube video - although its a B5 you get the idea.
    Kristian
    Aug 19 2013
    Miami
    mec i noticed that my bumper only needs to stay on in the drivers side only. like that strip that holds the bumper is broken. the rest is held in good. is there i way a body shop can patch that part in the corner near the headlight is sticking out. so i have duck tape in there is not noticeable but it bothers me lol.
    Ivan
    Jul 11 2014
    Chicago, IL
    Alright. I tried plastic weld and it didn't work. I think I'm going with the snaps. Martin, you mind grabbing a photo of the install? Mostly curious where you mounted them on the inside.
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    Bumper is like 500 shipped from GAP, and if any paint shop quotes you more than 350 to dead panel a bumper they are ripping you off.
    May 20 2014
    e92
    I already tried plastic weld. Does nothing. Broke on the first try mounting the bumper. I am going to try lord fusor 143 or the latches. Check lord fusor bumper repairs. It seems pretty good. I know Phil used the same for his dtm mesh grills.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Sure shoot me a pm to remind me.
    Veteran Member Three Rings Kingzilla17's Avatar
    May 05 2011
    Arlington, Texas
    That quick latch system is pretty cool. My bumper is torn on both sides as well but the sides stay in place. The top corners towards the headlights are what stick out on my front end.
    06 Arctic White Audi A4 Quattro: |Solo-Werks Coilovers, OEM Bi-Xenon blacked out w/ STi Clear lens & CC mod, Hoen yellow fogs, 18'' Avus wheels, LED reverse lights, Thule Aero roof rack w/ Thule Evolution 1600 box|
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by trj View Post
    Yeah I had the same problem with the plastic weld. I'm done trying. I figure it's $40 to TRY lord fusor and hope that finally does it or $60 and i get the latches fix that over complicated system. 5-900$ for a new bumper is a little out of the budget at the moment for a non-essential repair.
    Aug 19 2013
    Miami
    Same here i just put duck tape on there for no until i find a way get this thing to stay on. Phil recommended fusor but i don't wanna mess with any of that. I don't wanna fuck things up even more
    Ivan
    Jan 06 2009
    I used this stuff on the weekend. It sets VERY quickly (10 seconds) and is fully cured in about 15 minutes. Pretty easy to work with but you need several tips as they get filled with cured epoxy. I used 13 tips. I don't have any road use on it yet but the repaired sections feel strong. Like most things, the prep is what makes it last. You must thoroughly clean the surfaces, degrease with IPA, scuff it up and then spray an adhesion promoter. I also drilled small holes in both adjoining pieces so that the epoxy could flow to both sides. This gives a much stronger bond.
    B7 2.0t
    Aug 19 2013
    Miami
    Did anybody find a way to fix this strip of the bumper in the drivers side? did any body use a body shop to fix it without getting a new bumper???????
    Ivan
    Jan 06 2009
    Yes I fixed it myself with the adhesive mentioned above which you can buy on Amazon. It has held up great.
    B7 2.0t
    Aug 19 2013
    Miami
    Can you prove me with the link please?
    Ivan
    Jan 06 2009
    Sure. Check out post #18. There is a link to the 3M product that I used. Search for that 3M # on amazon. If you read the 3M link it will also tell you the part number for the dispensing gun if you don't have one already as well as the primer, tips and plastic sheets.
    3M 04247 adhesive
    3M 08193 tips
    3M 04903 contour sheets
    3M 05907 primer
    I use this dispensing gun instead of the super expensive 3M one: COX M200LVMR
    B7 2.0t
    Veteran Member Four Rings mpv314's Avatar
    Apr 06 2012
    Audi A4 2006 Quattro
    New York, United States
    Well I'd just get ready to buy this
