There is a PDF version and Power Point Presentation you can download if you want, that resembles this write up. Hopefully this will be helpful!
2001 Audi A6 Turn Signal Fix
BACKGROUND:
While driving to lunch one day I found that my blinkers suddenly stopped blinking and went solid. I confirmed this by getting out of the car and looking at the blinkers when engaged. They were solid for both left and right. I found a circuit diagram and found the flasher relay is integral to the hazard switch. Like so many of you do, I searched the forums and youtube for a fix. I confirmed the relay is in the hazard switch. After a few days of using the blinker switch manually to make the them blink, I suddenly found the blinkers quit coming on all together. CRAP! I thought maybe I broke the multifunction switch, but after “tapping” the dash a few times, the lights came back on solid. The blinker relay has died altogether. I found a “how to” on removing the hazard switch (too easy) and a video on how to disassemble the switch. The video was older version, and the relays were not encased. Mine are encased. I looked up how much a hazard switch would cost and found them to be from $25 (ebay) to $46 from various online stores. Being a “Do-it-Yourselfer” I decided to see if I could fix my hazard switch for cheaper, rather than buy a new one.
After it was all said and done I had spent $10.30 plus shipping, and the blinkers worked as designed.
DISCLAIMER: PERFORM THIS FIX AT YOUR OWN RISK. I AM NOT RESPOSIBLE IF YOU RUIN YOUR SWITCH (or car) PERMANENTLY. This was a fairly simple fix for me, but I do have some circuit board repair experience. I am not an expert at soldering, but I am not a beginner by any means. I also have an above average (self-proclaimed) understanding of wiring diagrams and circuits.
First you need to remove the red lens. One side is larger than the other, you can use a small screwdriver or a pick to pop the tabs on each side.
After red lens is removed, use a screwdriver to pop the tab shown, and repeat on the opposite side. Be careful not to break the tabs, they are very thin.
Remove the lock bar that holds the connector casing on the pins. Use a small screwdriver or pick to push through. You may be able to pull through at this point.
The bar was in too tight for me to remove in the last step, so I inserted the screwdriver in the center and pushed it through.
The circled relay is the turn signal flasher relay. It was encased like the one next to it, but I removed all the casing to check for corrosion. There was none so the relay just went bad. The casing was marked Omron G8N-1, after a little “Googling” I found that www.mouser.com sells a G8N-1. I ordered the relay with the hope that it would be the correct one. It cost $10.30 before shipping.
Until it arrives I decided to remove the relay and use a solid piece of wire to allow me to manually make the blinkers flash.
The other, bigger relay is the hazard flasher relay.
Omron G8N-1
Another view of the bad relay.
Hazard Switch Pin Out
Hazard Switch Wiring Diagram (the quality is much better in the PDF version)
These 5 soldered points are the turn signal relay contacts. If you want to remove the relay you will have to heat these point up and de-solder them. The yellow numbers reflect where the connector pins are soldered to the board.
Point A is the power input from the ACC +, point B is the power output when the relay is energized. These are the 2 points that I soldered a piece of solid wire between to allow power to be at the turn signal switch all the time.
***NOTE*** I did this because my relay was completely dead. If your relay is latching but not blinking this is not necessary for you. I do not recommend keeping this setup for an extended period of time. I don’t know the integrity of the piece of wire I used. Also using your blinker switch manually for a long period of time may cause premature failure of the multifunction switch .
I soldered a piece solid wire between the 2 points to allow this circuit to be powered all the time. This allows me to use the turn signal switch to manually make the turn signals blink. This was a temporary fix until I receive my new relay.
***NOTE*** I did this because my relay was completely dead. If your relay is latching, but not blinking, this is not necessary for you. I do not recommend keeping this setup for an extended period of time. I don’t know the integrity of the piece of wire I used. Also using your blinker switch manually for a long period of time may cause premature failure of the multifunction switch .
I ordered this relay from http://www.mouser.com/.
As soon as the new relay arrived I removed the solid piece of wire and prepared for the new relay.
Solder the new relay. Make sure all 5 points have good contact.
At this point you are done. Re-assemble and try it out.
