Results 1 to 10 of 10
    Active Member One Ring harryzwd's Avatar
    Dec 13 2009
    2003 A4 3.0 Quattro 2004 VW R32
    Northern NJ
    A4 B6 Headlights - S4 compatible?
    i have a 2003 A4 sedan 3.0 quattro with oem xenons...does anyone know if the oem xenon headlights (entire headlight housing) from a 2004 S4 will fit? the part numbers are different, but looking at the headlights themselves, they look identical except that the S4's are blacked out inside the housing, where the A4's are chrome. i've looked here and online for a parts number cross reference, but can't seem to find a definite answer.
    thanks in advance for any info...
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    they will work, I am running the euro style S4 headlights right now the Bixenon mine were a tight fit but they work great, the normal s4 xenons fit with no problem
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
    Veteran Member Four Rings nananana4k's Avatar
    Sep 10 2005
    A4 B6 3.0, Q5 B8 3.2
    yup. they plug right in. If you go for euro ecodes you should also get a plug extension because the passenger side barely/does not reach.
    Dec 13 2009
    Northern NJ
    was just hoping to pick up a pair of oem s4 headlights and bolt them right into place, same harness, connector, etc. almost easier to find used than stock a4 headlights
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    You may need the harness extender for any bi-xenon housing in the A4, but otherwise, they are plug and play.
    Aug 18 2011
    Stuff
    Minnesota
    Quote Originally Posted by imnuts View Post
    yup like he said, I got mine to work and plug in without having to extend wires though
    200k daily tank
    My Build Thread
    Dec 13 2009
    Northern NJ
    my A4 has xenon's already (not exactly sure what bi-xenon's are) and the S4 headlights look identical, the harness connection appears to be identical in shape and location - hopefully they'll fit no problem
    A4 Front
    S4 Front
    A4 Rear
    S4 Rear
    Aug 18 2011
    Stuff
    Minnesota
    Here is the rear of the bi-xenon:
    much bigger then normal xenon this is when I was doing my clear corner mod
    200k daily tank
    My Build Thread
    Dec 13 2009
    Northern NJ
    oh, got it. pictures really are worth a thousand words
    Aug 18 2011
    Stuff
    Minnesota
    Quote Originally Posted by harryzwd View Post
    cant agree more
    200k daily tank
    My Build Thread
