Results 1 to 17 of 17
    Veteran Member Three Rings Ko4S4WI's Avatar
    Aug 02 2008
    2001 S4
    Milwaukee
    S6 manual swap finished! Quick question
    Just finished my swap project and it went well aside from doing a few things twice.
    I have no check engine lights at all, the manual file worked well.
    The only question I have is about the accelerator pedal. My car seems a bit "laggy" for lack of a better word. Has anyone else had this? Perhaps normal programming to keep the car smooth? Any input is welcome.
    TIA!
    Ten years ago if you had 500HP you were the man. Now days that means you bought a new car.
    AKA: VastKo4S4WI
    Veteran Member Three Rings Castor Troy's Avatar
    Dec 17 2008
    Billings, MT
    nice. did you use one of the online instruction sets?
    did you swap the entire pedal assembly? or were you able to install the clutch pedal onto the assembly thats in place?
    AEB: Boost goes in, valves come out.
    2003 Audi S6
    Sep 16 2010
    Central Wash
    Laggy? As in...? You touch the accel and there's a delay in response? Or it's just slow? RPM's hang a little..?
    You might try a throttle body adaptation, can't remember what measuring block/ basic setting it is..56?
    Should not be laggy, as a matter of fact mine hits a little TOO HARD when you touch the gas- almost jerky. What engine 'soft coding' did you use?
    Aug 02 2008
    2001 S4
    Milwaukee
    Quote Originally Posted by Castor Troy View Post
    I used the google docs writeup.
    I moved the pedals over to the bracket already in place. I did not want to loosen the brake booster.
    AKA: VastKo4S4WI
    Aug 02 2008
    2001 S4
    Milwaukee
    Quote Originally Posted by rollerton View Post
    After flashing the 559E file, recode it to a manual (10712 if using said 559E file)(03283 NRS^ pre)
    Clear ECM fault(s)
    Login to your ABS module (either 07497 or 07495 {IIRC} depending upon which motor you have) and then change the last digit of your current coding to a 5, i.e. if your coding was 06397, change it to 06395.
    Select login for your steering angle sensor and input value 40168. Do it.
    Select basic settings and from the drop down menu select steering angle sensor. Do it
    AKA: VastKo4S4WI
    Mar 27 2014
    Kaimas
    what about brake swich? Have u put it back correctly? It is 2 stage unit. Using VCDS check it...could be, that after u release brake pedal, one stage is still engaged and then shit happens with throttle and response ( my own expierence). Try moving it closer to pedal to be 100% sure.
    Aug 02 2008
    2001 S4
    Milwaukee
    Quote Originally Posted by Takumi View Post
    Good call, I will take a look at that. I just threaded in to where I 'thought' it should go.
    AKA: VastKo4S4WI
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    After my swap, I am still getting ABS and ESP light.
    But even more 'disturbing':
    - cruise control doesn't work
    - interior lights don't work (DO work when opening the doors)
    Note: car has coil over conversion, so the suspension height warning is always on. But all of the above worked prior to the swap
    Also note: I swapped entire manual pedal cluster over, but brake switch was different style. So I had to cut the old (auto) connector off and solder in the pigtail for the new (manual) switch. Since no one seemed to have the 2 wiring diagrams, and just matched the wire colors.
    Any thoughts on the above?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Aug 25 2010
    Sounds like a clutch switch issue. Did you install the clutch switch? If so, use vagcom to check if it is working properly.
    Veteran Member Four Rings khalimadeath's Avatar
    Nov 18 2009
    70 VW Bus, 64 VW Bus, 13 Q7, 18 S5 SB
    Reno NV
    Quote Originally Posted by vtraudt View Post
    you have to wire up the clutch switch to the ECU and ground it to the white wire off the brake switch for cruise control.
    Your ABS and ESP light are on cause your car is still trying to talk to the transmission, from what I understand is some of the ABS/ Traction control runs through the auto trans.
    Weird your headlight sensor level light is on. Mine has been lowered for quite some time and never givin me issues.
    You can use either early or late brake switch, doesnt make a difference.
    -Zach-
    The C5 Union////////////
    The United States Constitution
    (c) 1791. All Rights Reserved
    Jun 16 2011
    London UK
    The pump timing on my 2.5tdi allroad was just out of spec. Took a lot of cranking when the engine was cold. I would get randomn ABS, levelling suspension and brake warnings. Cruise would cutout and I would have to pull over, restart the engine to reset it.
    Fixed the pump timing and still got ABS & suspension faults & no cruise. I thought it was the Bosch 5.7 unit. VCDS said there was a problem with the ABS controller. It turned out it was the brake light switch. Fixed it and no more problems. We had 2 weeks of snow in the UK. Driving in the snow with summer tyres and no ABS wasn't much fun.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by khalimadeath View Post
    Suspension light (its and Allroad thing) is on due to coil over conversion.
    05 Golf TDI
    Jul 22 2014
    Lincolnshire
    Hello, I've just done a tip to 6sp conversion on mine and the engine only just runs, very rough and thick smoke
    Veteran Member Three Rings Sparkstack's Avatar
    Oct 13 2012
    Bits of a 2003 S6, 1990 turbo Miata, 1996 LS400
    Naperville, IL
    Hello. I just had a coffee and a snickers bar. Figured I'd thread jack the OP's post since 3 other people have already done so....
    Creating new topics must be harder than I thought. But if it isn't, can you guys bugger off to your own thread?
    2002 S8 - Daily driver.
    2003 S6 - R.I.P. (parting out - PM me if you need anything)
    1996 LS400 - Wife's whip. Thing is bullet proof.
    1990 Miata with FM Turbo - Pocket rocket.
    Aug 31 2013
    United States
    That's a lot of caffeine
    Sep 16 2010
    Central Wash
    Cheap IPHONES for sell!!
    Please too contact for supreme IPHONES 4/5/6 !!!
    What's this about again..?
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    Orange juice and potatoes.
    But for real I didn't know the brake switch out of spec can cause a laggy throttle. I'm going to adjust mine tommorow. Learn something new every day.
    Edit: after I changed plugs and o2 sensors I adjusted the clutch and brake switches to factory spec. One of those things completely fixed my laggy first gear hesitation. Completely different car. Awesome
