Results 1 to 3 of 3
    Jan 18 2014
    2 Victory motorcyles, 1 Triumph motorcycle. Volvo 850 Wagon.
    Nashville, TN
    Panel rattle from speaker bass
    I have a 2009 A5 S-line with a Bang & Olufsen system. I have started to notice rattling at loud volumes. I am pretty certain it is not speaker distortion. Any tips on how to locate, fix rattling panels?
    2009 A5, S-line
    Aug 29 2013
    Mt Pleasant, SC
    Quote Originally Posted by superswede View Post
    Play some music with good bass and walk around the car and listen to where the rattle comes from.
    Some of the usual suspects are the rear deck panel and door panels. Press on a panel when you located the rattle sound and see if that cures the problem.
    If pressing the panel is the cure, then find some felt padding or closed cell foam, then remove the panel and sandwich the padding under the panel and replace it.
    Test for results. Most rattles are caused by panels vibrating and hitting a solid surface underneath, such as the car's metal frame. Wedging soft material between those surfaces will normally fix the problem.
    The next level would be to add some sound dampening material, such as Dynamat. This is basically an asphalt material with adhesive designed for sticking to metal surfaces to prevent resonance. In the aftermarket car audio world, sound dampening is major first step in preparing for any high-end installation. We used over 80 sq ft of sound dampening in my car during my install.
    If you want to get REALLY specific, you can find a test signal CD such as the AutoSound 2000 series. They will have test frequency tracks that cover the full audible spectrum from 20Hz to 20kHz. That's really useful for checking speakers for resonance and finding rattles that are frequency-specific.
    Veteran Member Three Rings broker23's Avatar
    Nov 03 2013
    2014 Shelby GT500
    Chicago
    Check you center brake light in the middle of the rear window
    2018 Audi S7 Prestige Loaded
    EPL Stage 1
    21x10.5 Vossen HF-1
    Factory Bang & Olufsen
    2010 Audi A6 3.0t Prestige SportPackage
    G.I.A.C Stage 1
    Stasis Exhaust
    JL 12W7 JL 600/1. SOLD
