Results 1 to 14 of 14
    Established Member Two Rings perrytcolts's Avatar
    Feb 12 2014
    London, United Kingdom
    New PCV valve is faulty
    Diagnosed my current PCV valve as faulty by trying the standard opening of the filler cap whilst the engine is running and turns out it does run rough.
    So installed a new valve but upon starting it, it started choking and struggling to idle. So took it off and noticed that one of the openings on the new valve was missing a sort of plunger/piston compared to the old one.
    See below for photos to get an idea of what I'm on about. Manufacturing fault? Bought it off JHM about a month ago and only got around to installing it now.
    Senior Member Three Rings SwiftA4's Avatar
    Aug 20 2012
    FYI, the engine will run rough when you remove the fill cap whether the valve is faulty or not. You now introduced a huge vacuum leak when that happens. Hopefully Jake can chime in on whether the new valve is defective. GL
    2008 A4 S-Line | APR Stage 1 93 | Ibis White | 2.0T Quattro Tip | Koni FSD/Eibach | Debadged | R8 Coilpacks | BKR8EIX | OEM Roof Rack | VEI/Podi | 15% Side, 5% Rear | Rev. "D" DV | 034 Snub |
    Retrofits: S4 Power Folding Mirrors | Warning Triangle |
    Feb 12 2014
    Quote Originally Posted by SwiftA4 View Post
    Yeah that's what I thought! I don't why people are saying that it symptom of a bad PCV valve.
    Anyway I'll see if I can get my hands on another valve and see if it's got the plunger thingo.
    Veteran Member Three Rings funky_snowman's Avatar
    Dec 31 2010
    US
    Blow through the plastic corrugated tube connected to the pcv. If it's broken it will not seal and it will let air through.
    I don't know where the oil cap test came from, but it's les poop.
    Sent from my Nexus 5 using Tapatalk
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    Quote Originally Posted by funky_snowman View Post
    Exactly, blowing through the corrugated tube is the only real way to check it.
    -Chadwick
    FULLY BUILT ENGINE!
    Aug 20 2012
    Quote Originally Posted by perrytcolts View Post
    Agreed. I don't know why that is floating around either lol.
    But honestly, the original PCV may not have been bad. Do what the guys have listed, blow through it. Usually when it is bad you get the exact same problems when you put the "new" one on. You'll also get very erratic idle fluctuations.
    Don't forget too, you can pop the plastic circular piece off that houses the diaphram and inspect the diaphram for rips/tears.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Look at the part numbers of each, specifically the final letter. This indicates whether they should be the exact same part or not. I just installed a new revision PCV and I don't have the plunger you're referencing. Audi regularly changes the design of parts through new revision; they may have decided what youre looking for is not necessary, and therefore removed it from the design. A part with a different letter at the end is a new revision.
    Feb 12 2014
    Ah I'll pop it open and suss it's innards out. Thanks Swifty
    Quote Originally Posted by PNW Avant View Post
    Yeah just trawled through the different revisions and apparently the "R" version is what I need.
    This looks like my current one - view the second photo to get a good look at the plunger. http://www.ecstuning.com/Audi-B7_A4-...lve/ES2715561/
    Jun 27 2011
    The 2006 and earlier 2.0t use a different version of the PCV and Breather tube than the 2007+ 2.0t. You probably got the wrong one.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Some revisions have that valve and some don't. Did you order the correct early vs late PCV?
    Are you sure everything was installed correctly? If the PCV was indeed bad to begin with we will warranty it.
    Let me know!
    Early: http://jhmotorsports.com/shop/catalo...0t-p-1882.html
    Late: http://jhmotorsports.com/shop/catalo...0t-p-1983.html
    NOTE ON BUILD DATE SPLIT:
    There is a split on this part for B7-A4 2.0Ts. If you have a B7-A4 2.0T with a build date before December 16th, 2005 (displayed as 16.12.2005 in your car) you will have the EARLY version of this part. If you have a B7-A4 2.0T with a build date AFTER December 16th, 2005 (displayed as 16.12.2005 in your car) you will have the LATE version of this part. If that's the case, please go back one section and select the LATE part and add it to your cart.
    Common confusion is that people will see the non OEM PCV for 39.89 and order it for their late car even if it is early.
    Rep Early: http://jhmotorsports.com/shop/catalo...0t-p-1984.html
    Senior Member Three Rings nan07's Avatar
    Jul 07 2011
    Frisco, Texas
    Quote Originally Posted by Jake@JHM View Post
    i dont understand the difference, might be the beer though
    Feb 12 2014
    Let me know!
    I'm not sure what my build date is. It's an '06 but I'm assuming it was built just before December 2005.
    Now that I know the differences between the valves I've obviously ordered the wrong one!
    No need for warranty Jake, this is purely just a case of retardation on my account!
    Jun 27 2011
    There is no visual difference between the parts which makes it even more confusing.
    -CP
    2017 Q7 3.0t
    Feb 12 2014
    Funnily enough, this is the exact reason I stuffed up in the first place. I couldn't tell which revision I needed so I clicked on the one that looked identical to what I had lol.
