Page 32 of 34 FirstFirst ... 223031323334 LastLast
Results 1,241 to 1,280 of 1342
  1. #1241
    Jan 31 2009
    2016 RS7-P
    Quote Originally Posted by @llroadC7 View Post
    Bone stock at the moment.8,5x20 ET43 with 12mm spacer at the rears = ET31 with 255/40 Bridgestones.
    Did rub on the expressway with passengers in the back. Only lowered in dynamic mode, yet to be edited ride height values.
    Looking into possibility for running 10x20 but yet missing what ET i should go for.
    You have the extra body cladding but unsure how much more actual clearance you have for offset? Standard body cars the body edge is pretty flush without too much of a fender to roll flatter.
    Standard 6 with a 10" wheel, 40-45 is run on other cars. You'd probably need to cut overhang of the All Road cladding to get the best fitment.
  2. #1242
    Junior Member One Ring
    Sep 27 2022
    Audi 90 V8 quattro
    Norway
    Thats right, I do have some cladding and room for more. I see others in this thread are running 10/10,5" with ET37-42. (Especially thinking of @nthusiastt post )
    Was thinking more in the region of 245/40-10 with 10x20" not to rub, and since I need to chicken out on perfect fitment due to this being a daily, I need to compromise and avoud cutting / trimming.
  3. #1243
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    I picked up a set of theese Momo wheels in 20x10.5 45 Et. With deep concave option. hoping i can get away with 8mm spacers so they dont poke too much.
    Car is 2013 a6 with eibach springs and blistein shocks.
    i went with 265/35 20 Falken tires. curious to see how stretched they look. the tire called for 10.5 rim max.
  4. #1244
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by chuckgotboost View Post
    20x10 ET25 Avant Garde M520R with 275/35/20 tires
    Attachment 281505Attachment 281506Attachment 281507
    looks great. any rubbing?
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
  5. #1245
    Feb 11 2021
    Upland, CA
    Quote Originally Posted by f4m0u5 View Post
    https://tyrestretch.com/10.5-265-30-....5-265-30-R19/
    Above is a general idea of what your stretch will look like. Of course tire brand will effect stretch being some brands can tend to run wide or narrow or can also have different sidewall construction. I could be wrong, but I think I've heard of A/S6's going to low 30's before encountering problems/needing to run aggressive stretch to avoid rub, so your effective ET of 45-8 = 37 should be a good classic aggressive yet safe fitment. That is unless you drive at full weight all the time and take corners like a madman... Post pics when they're mounted!
  6. #1246
    Jan 31 2009
    2016 RS7-P
    I don't think the 35 sidewall will stretch much on a 10.5, Falkens aren't too broad on the shoulders.
  7. #1247
    Aug 04 2014
    Gloucester MA USA
    thanks guys!
    im hoping the 35 wont be as stretched, we will see soon. i will mount for fitment either this week or next week but its winter so wont get them on till march
  8. #1248
    Feb 11 2021
    Upland, CA
    thanks guys!
    Viet is right, I didn't realize above but I accidentally linked a pic of 265/30 stretch on a 10.5, so being you are running a 35 profile, it will probably be a very minimal stretch and not very noticeable.
  9. #1249
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by aaronsananikone View Post
    not mich stretch if any, they look good!
    now need my spacers to get a good test fit.
    WISH WAS SPRING TO MOUNT THEM!
  10. #1250
    Junior Member Two Rings regnirps01's Avatar
    May 04 2016
    2016 Audi S8 plus,
    cali
    http://https://audiocityusa.com/shop...21-inch-Wheels
    I’m the worst at this so hope the link works but this is my RS7 before the KW HAS where installed
  11. #1251
    Feb 15 2011
    Northern VA
    Got some R8 Performance reps for my S6 with some decent concavity.. look pretty good, especially when moving.
  12. #1252
    Mar 23 2019
    New York
    Quote Originally Posted by Yeoman View Post
    they look good. what specs are they?
    2018 S6 Premium+
    2021 SQ5 Prestige
    2006 S4 Cab (gone)
  13. #1253
    Feb 15 2011
    Northern VA
    Quote Originally Posted by NewYorkS6 View Post
    thanks - they're 20x9 30et
  14. #1254
    Oct 18 2022
    Oxford, MS
    Quote Originally Posted by IllusionalTA View Post
    20x9 rfx11 et 35
    Love the fitment you have here but what size tires you running with this setup?
  15. #1255
    Veteran Member Three Rings Speedooooo's Avatar
    Sep 13 2015
    Cincinnati, OH
    Looks great! I always liked the black with machined look.
    2018 Glacier White A6 3.0T | Driver Assistance | Sport | Black Optics
    2016 Mythos Black Q5 3.0T SOLD
  16. #1256
    Feb 15 2011
    Northern VA
    Quote Originally Posted by ttka3884 View Post
    255/35
  17. #1257
    Sep 13 2015
    Cincinnati, OH
    What pressure are you guys running on your 30 and 35 series tires?
  18. #1258
    Dec 27 2015
    2008 e60 m5 2015 suburban ltz
    Bethlehem Pa
    Show Us Your Wheels - 20"
    20x9 et25 BBS CH-R 265/35 Michelin Pilot Sport 4S
  19. #1259
    Veteran Member Three Rings MTV10's Avatar
    Apr 29 2020
    Montreal
    Wow very clean. No rubbing?
    2018 /S6 | Mythos Black / Arras Red | Stage II ECU | APR TCU | ARM Downpipes | AWE Touring Exhaust | SRM Intakes | CETE Lowering Module | 034M DSG Mount Insert | HRE P43SC
  20. #1260
    Senior Member Three Rings mrdouble99's Avatar
    Mar 31 2018
    Montreal
    that's rubbing for sure in the rear
    Mythos Black Metallic 2018 Audi S6 current
    Moonlight blue 2015 Audi S6 sold
  21. #1261
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by Speedooooo View Post
    Daily Driving: 35 winter / 38 summer.
    I run 275/35 series in winter. 265/30/21 in summer
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
  22. #1262
    Dec 27 2015
    Bethlehem Pa
    No rubbing, front fender screws removed and Cete set to -15F -20R on dynamic
    C7.5 Oolong Grey s6 Prestige//Black Optics//Sport Package//Cold Weather//Drivers Assistance//Arras Red Design Interior//Milltek Non Res Valvesonic//SRM Intake//BBS CH-R 20x9 et25//Cete ASC// Blacked Out Badges
  23. #1263
    Apr 29 2020
    Montreal
    Quote Originally Posted by Bigsteiner5 View Post
    I'm really liking your setup man. Very clean.
  24. #1264
    Aug 04 2014
    Gloucester MA USA
    Momo barletta wheels in 20x10.5 ET 45. 265/35 falken fk510 tires.
    12mm spacers in front, 5mm in rear( lowest that would fit but switching to 12s to look beter and closer to fronts)
    sorry dirty car broken lip...
  25. #1265
    Established Member Two Rings benlaud87's Avatar
    Jan 23 2023
    '03 Corvette, '06 mini Cooper S, 16' A7 TDI '22 Tahoe HC
    Raleigh, NC
    20x10 Rohanna RFX 10
    265/35 Continental pro contact tires. I'll go to 285 once these wear out
  26. #1266
    Feb 11 2021
    Upland, CA
    Quote Originally Posted by benlaud87 View Post
    I ran 285/30's on some 21's I had back in the day and I chewed up my driver side fender pretty bad coming down a steep driveway... Granted I don't know your exact offsets or suspension setup (I was pretty low at the time), but when you do go with 285's please do be careful
  27. #1267
    Jan 23 2023
    Raleigh, NC
    Interesting. Thank you for the heads up
  28. #1268
    Sep 12 2022
    Syracuse, NY
    OEM 20in 10 spoke wheels powdercoated chrome bronze. Falken Azenis A/S 275/35R20 tires.
    Sent from my SM-G998U using Tapatalk
  29. #1269
    Established Member Two Rings cts4b5tt's Avatar
    Apr 14 2010
    2012 Audi A7, 2015 Wrangler JKU
    Naugatuck, CT
    Quote Originally Posted by will.k.315 View Post
    oooo i like that color
    Edit Signature. Enter. Edit Signature. Enter. Back. Enter. Refresh. Edit Signature. Refresh. Save Signature.
  30. #1270
    Mar 31 2018
    Montreal
    OEM wheel powdercoated silver :)
  31. #1271
    Established Member Two Rings Rodrigla619's Avatar
    Mar 26 2021
    2017 Audi A6 Competition, 2011 Chevy avalanche, 2015 Audi Allroad
    Middletown, DE., USA
    AWE carbon fiber intake | EPlabs stage 2 | CTS SC pulley | Merc HX, 034 trans-rear dif mounts | JXB carrier | 034 motor mounts | H&R lowering springs | APR 15mm front spacers | APR 20mm rear spacers | AWE resonated downpipe and exhaust | IE TCU tune | CAP CF diffuser | CAP CF side skirts | CAP CF front splitter | JR20 20's | MICHELIN PILOT SPORT 4S | P3 gauge | Titanium werks dress up bolts
  32. #1272
    Feb 21 2019
    JKU with LS motor, 2016 3.0 TDI ,2017 Q7 Prestige, '04 CC Magna 42' '84 streached CJ7 with a 6.0ls
    Wellington Nevada
    Tire choices
    I'll be needing a new set of summer tires and I've been thinking about going from a 255/35/20 to a 265/35/20 or maybe a 255/40/20.
    I have a 2016 A6 TDI Prestige S line so its factory lowered a little.
    I do not want rubbing.
    Its on RS5 20/9 et26 factory rims.
    Thoughts..pictures.
    Thanks20210506_155843.jpg20210506_155838.jpg20210429_131907.jpgAttachment 303095
    2016 3.0 TDI Tornado Gray Metallic Prestige Black Optic Package S Line Sport Package.
    2017 3.0T Argus Brown Metallic Prestige Adaptive suspension Driver assistance 21's
  33. #1273
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by Caryt View Post
    Thoughts..pictures.
    i think the 265s will give you what you want. they are wider. and only slightly taller. the 255 40 will not be any wider and only taller. and
    even taller then the 265/35/20
  34. #1274
    Feb 21 2019
    Wellington Nevada
    Thanks..if anyone has a similar setup would love pictures!
  35. #1275
    Feb 21 2019
    Wellington Nevada
    Looking at summer tires for my A6, 265/35/20's any recommendations?
    Seems the MICHELIN PILOT SPORT 4S is the benchmark but pricey.
    Pirelli P Zero (PZ4) good and has better wet performance..being near the Sierras weather can change quick.
    ExtremeContact DWS 06 Plus is the favorite all season..sure wish Tire Rack would test the best summers against the best all seasons..might not be such a big difference.
  36. #1276
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    You can't go wrong with either PILOT SPORT 4S or DWS 06 they're both great tires.
    I have the 4S's now but my next tire is gonna be--> https://www.michelinman.com/auto/tir...-pilot-sport-5
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
  37. #1277
    Feb 21 2019
    Wellington Nevada
  38. #1278
    Apr 14 2010
    Naugatuck, CT
  39. #1279
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    Wheels: NEUSPEED RSe102 Lightweight Wheel 20" 5X112 Black - Glossy 5x112 / 20X9.0 et40 / cb66.5
    Tires: Michelin Pilot Sport All Season 4 - 255/35/20
    and after a car wash...
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
  40. #1280
    Veteran Member Three Rings base14's Avatar
    Jun 01 2017
    OR
    Forgestar F14 20x9.5 et30. Third Audi these wheels have been on . I have to say they look the best on the nardo.
    2018 A6 3.0t P+ Competition Package| 034 Stage 1 ECU+TCU (his)
    2015 Q5 3.0t P+ S-line | EPL Stage I (hers)
    (SOLD)2013 allroad Prestige | APR Stage II | E85
    (SOLD)2010 Q5 P+ | OEM+ Build Thread
