Results 1 to 19 of 19
    Junior Member Two Rings
    Jul 15 2012
    Hamilton,ON
    Excessive soot/carbon on tailpipe
    My wife's 2013 A4 2.0 has what I would consider excessive carbon build up on the tailpipes. I clean them almost every week. By the end of the week they are completely covered in carbon. More so on the outer exhaust tip. Is this normal? Bad injectors? no lights or warning codes.
    Senior Member Three Rings Rollin Thunder's Avatar
    Aug 14 2012
    2008 F150 FX4
    Central New Jersey
    When I had the stock exhaust I experienced the same thing on my 13, I thinks it's normal. It's even more noticeable now with the Stasis Exhaust and Hi-flow cat. It's wipes right off though.
    MODS: Pretty close to everything and the kitchen sink.
    Jul 15 2012
    Hamilton,ON
    Quote Originally Posted by Rollin Thunder View Post
    thanks for the reply. The carbon is near impossible to remove. 0000 steel wool with P21 polish won't remove it. I may have to break out my mini air die grinder with some Stainless cut polish and buffing pads.
    Veteran Member Three Rings B8Phil's Avatar
    Mar 13 2010
    Lorton, VA
    Are you consuming excessive oil?
    APR Stage II SPM street downpipe Remus dual exhaust S4 shocks & rear sway Eibach Pro-Kit 19x9 OEM S5 Peelers 245/35R19 Nexen N7000 Eurocode HFIP Eurocode inlet hose aFe Pro Dry S
    Active Member One Ring lord2464's Avatar
    May 18 2014
    Forest Hill MD
    I have the same experience with my '14
    Aug 14 2012
    2008 F150 FX4
    Central New Jersey
    Quote Originally Posted by Denaliman View Post
    Neverdull always worked for me.
    Jul 15 2012
    Hamilton,ON
    Quote Originally Posted by B8Phil View Post
    I haven't really noticed any excessive oil consumption.
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    This -- works well!
    I've read that the soot is caused due to our cars running rich.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Senior Member Two Rings Stuck'ite's Avatar
    Apr 04 2011
    Jacksonville, Fl
    I have to same thing on my '11...and it is white. Had it on the stock everything, APR Stage 2 & APR Exhaust, and now on my K04. Nature of the TFSI beast. Keep the back bumper clean and well waxed. That color WILL stain your paint if you let it build up. NEverDull is great on the tail pipes.
    2011 Ibis Ti, Prem+ Pwr Mods: APR K04 V2, APR Full Exhaust, Carbino, dyno corrected 248BHP-376 lb/ft @ Stg 2, EuroCode(EC) FMIC, EC Rotomas, 343 CatchCan, Okada Coils, APR BT Dongle Handling Mods: Bilstein PSS10, SPC Control Arms, EC Sways/Links, StopTech ST-60 380mm & Sport Rear Brakes, stock Ti 19x8.5 et43 (28lbs), BFI Spacers 5/10 (eff et38/et33), Mich PSS 255/35/19, Other Mods: P3Cars Gauge, Curt hitch, AL E-Code Headlights, HID Fogs
    Senior Member Three Rings BaysideS4's Avatar
    Feb 25 2004
    Tampa
    Every Audi I've had does that.
    2009 B8 A4 2.0TQ Premium Plus; 18" Sport Package; Meteor Grey; 125,000 miles / New OEM Piston Heads / Ecodes / Eurocode HFC / Revo / 15mm spacers / Bilstein B12 / Alu Kreuz / ÜSS Sway Bars / EC charge pipe and outlet adapter / 3.0TDI IC / RS5 pedals (hecho en China) / AWE exhaust / RIP: Rotamass pulley
    Previous:
    2007 RS4
    2005 S4
    2001 S4
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I thought I was doomed because I had tried so many different products with no luck. Off to buy Neverdull today!
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Where is this sold? I'm compulsive about having a clean car and the dirty exhaust tips always look like crap.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Aug 14 2012
    2008 F150 FX4
    Central New Jersey
    Quote Originally Posted by ProjectBlackout View Post
    Pepboys and or Autozone
    Mar 07 2014
    Texas
    Neverdull @ Walmart too
    Sent from my Nexus 7 using Tapatalk
    Mar 24 2014
    Thanks guys, have to look into grabbing that.
    Established Member Two Rings Afor's Avatar
    May 12 2013
    Kentucky
    Aluminum foil w/ water or ceramic cook top cleaner also work great. The aluminum foil [preferred] doesn't get dried white cleaner on the bumper either and makes those chrome tips shine.
    Feb 22 2009
    Ottawa
    How exactly does the aluminum foil work? You just rub a sheet of it on the tailpipe and the black stuff magically comes off?
    Apr 16 2010
    Leesburg, VA
    Adam's All Purpose Cleaner and 0000 steel wool works for me.
    2012 A4 2.0T P+ | 6MT | Quattro | Sport Package | Apikol | APR Stage II | EC HFC | EC Meisterwerk STS | VAG-COM | 35% Tint
    May 12 2013
    Kentucky
    Quote Originally Posted by belzebutt View Post
    Crumble up the aluminum foil, dip in water, scrub the tips, and yes, the black stuff magically comes off. Then, finish with a soft dry towel and admire the shine.
